#1 |
Member#: 173164
NWIC
Vehicle:1999 2.5rs 2dr rally blue |
OK here goes, i have 2004 2.0 long block full jdm complete motor with vf34, side fed injectors and tranny. I need to know which usdm ecu and engine wiring harness will be best fit for this motor because i need it to pass emissions. I also need to know which rear differential is compatable with the tranny i know that the final gear ratio is a 4.444. Thanks for all your help!
#2 |
Member#: 177
NWIC
Vehicle:The 93 Imp W/EJ20K flat black |
2002 would probably be the easiest as it has the fewest sensors .. even then it will need tweaking/code removal
#3 |
Member#: 98961
Vehicle:2003 WRX Black |
Normally, I suggest figuring this out before you buy something...
What year car are you installing it into? That's the year emissions you have to pass. |
#4 |
Member#: 173164
NWIC
its going into my 99 gc8
| Thread Tools | |
| Display Modes | |
| I need major help, instant messege 'bigprfed' | fedrex | Factory 2.0L Turbo Powertrain | 0 | 03-14-2004 09:26 PM |
| Need Major Help Quick Please! | BIGRACING514 | Electrical & Lighting | 2 | 07-25-2003 12:42 AM |
| Need Major Help.. | SteveKerr | Tri-State Area Forum | 11 | 07-10-2002 11:07 PM |
| NEED MAJOR HELP | LAYLOW | Interior & Exterior Modification | 3 | 06-06-2001 02:14 PM |
| Need Major Help | bruno | Car Audio, Video & Security | 1 | 03-12-2001 02:10 AM |
