Old 03-03-2009, 06:44 PM   #1
Wrx_Fan_0717
Member#: 152080
6266 Precision'd Big
Cam'd 2.55l 6spd Bugeye
Default Closed Deck EJ20G swap in 02 WRX??? What esle do i need?
So i found a Closed EJ20G....i was thinking of swapping it in my WRX. But, how hard would this process be? Can't seem to fin much info on it???
What i was going to buy:
The bare EJ20G block w/ piston squirters (freshly hones)
JE 8.5 pistons
ACL Race bearings
What else do i need?
I was thinking a EJ25D or EJ22 crank knife edged/polished/hot tank'd etc.
Rods
APR Head/Rod Bolts
Thicker head gasket (size unknown)
Ported WRX heads w/ 272s or 280s/ valvetrain
Use the current WRX Fuel/IM/TGVs (deleted), or anything that touches the head.
I am guessing my header will bolt up to this block also.
What about oil pan/ pickups etc?
GT-35R
Would this even work?
Will the flywheel wheel bolt up and work with a 02 trans?
I haven't heard much of this swap and confused as hell when trying to find info? Need to know before i purchase the block. The only thing i did hear was rumors that they had cooling issues from the coolant port being to small? Can anyone confirm or deny this?
Thanks Guys,
Anthony
Wrx_Fan_0717 is offline   Reply With Quote
Old 03-03-2009, 07:13 PM   #2
Fongers
Member#: 118239
2002 Built Wagon
Wife- 2004 Outback SE
search for "hybrid" threads, I think Drink has a good one taht will walk you through it...
Fongers is offline   Reply With Quote
Old 03-03-2009, 07:21 PM   #3
Wrx_Fan_0717
Member#: 152080
Awesome man....usually good at searching but didn't find **** this time.
Old 03-03-2009, 07:21 PM   #4
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
well its just like rebuilding you 2.0 except it has a closed deck & piston squirters.
not sure if it would really be a "hybrid"
aftermarket aluminum radiator wouldn't hurt.
Old 03-03-2009, 07:36 PM   #5
Wrx_Fan_0717
Member#: 152080
Have a aluminum rad already and will be swapping in the 160 thermo also and having the fans kicking sooner.
I'm sketchy becuase the thick headgasket i would have to use for the piston to clear the head........with the already problematic overheating issue.
So once i get the clearances sorted out it would just be a straight drop in of sort.
Anyone know crank i should use?
Good to hear.......boggles me is to why no one ever uses them? Cheap closed deck 2.0s.
Old 03-03-2009, 07:40 PM   #6
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
Ever think about Arrow cranks? its 79mm so you will have a 2.2 on stock lenght rods.
http://www.rogerclarkmotorsport.co.uk/
scby rex is offline   Reply With Quote
Old 03-03-2009, 07:49 PM   #7
Wrx_Fan_0717
Member#: 152080
I did when i saw the link, but they're like 900 bucks.
edit: okay 700.
Old 03-03-2009, 07:50 PM   #8
scby rex
Member#: 104878
02 wrxbastardchild
its forged^^
Old 03-03-2009, 07:54 PM   #9
Wrx_Fan_0717
Member#: 152080
True......damn decisions......
But i need the -------- (forgot name) on the middle of the crank (older style) with this block; instead of, on the end like the newer cranks.
Can't think of the verbiage right now.....gosh whats it called.
Old 03-03-2009, 08:35 PM   #10
Fongers
Member#: 118239
2002 Built Wagon
didn't search too hard eh?
http://forums.nasioc.com/forums/show....php?t=1082001
Its a hybrid but more important, it walks you though an entire engine rip out and install. He calls out most of the items that we need to to do hybrid (not much) so just use oem there and you're good.
"Thrust bearing" is the word you're looking for.
Old 03-04-2009, 01:38 PM   #11
Wrx_Fan_0717
Member#: 152080
I've read that one but......that is for a EJ257....i was trying to fin the main differences for swapping in a EJ20G. The old school V4? (i think) STi motor.
Problem with the swap i found so far is piston clearance to the heads. I'm more asking who has put an older (phase 1) 2.0 with newer (phase 2) heads, fuel, oil pan, pickups etc.
He is swapping a Phase 2 Motor with Phase 2 heads and externals.
Thrust bearing thank you. I went through the alphabet trying to figure out what the hell it was.
Old 03-04-2009, 07:37 PM   #12
burm
Member#: 153807
2001 Impreza rs
Aspen white
Its very doable, there are tons of threads here and some on rs25 about using almost everything off and ej205, and using a 20g block. And yeah old ej blocks have the thrust bearing the the center, but new ones have them in the the rear. Having the thrust bearing in the rear of the block is a better place for it. so if you didnt want to drop the cash on a fancy center thrust forged crank, you can take the 20g block and have it machined, the the thrust bearing is in the rear.
burm is offline   Reply With Quote
Old 03-06-2009, 02:19 PM   #13
Timmy P
Member#: 134521
2010 WRX Stg 2 +
Try bbs.legacycentral.org they have alot of info on there.
Look through the forums and find a screen name with 555? in it, (im at work and that site is blocked) and search his posts/threads he knows alot. Also in the build journal i have a thread started with my build the guys in my thread know alot too. My build is 94' legacy wagon turbo started by iluvdrt. That should get you started.
Timmy P is offline   Reply With Quote
Old 03-06-2009, 05:01 PM   #14
Wrx_Fan_0717
Member#: 152080
Thanks guys....will check that out and start reading.
closed deck ej20g shortblock in PA blackbart Engine/Power/Exhaust 12 09-29-2010 12:08 AM
2.5 RS swap in 02 WRX...What is needed? Tr2laozboi Newbies & FAQs 7 01-01-2010 11:11 PM
VF39 Swap in 2008 WRX What do I need? x Mr Awesome x Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 21 10-03-2008 04:47 PM
what esle do i need? noni47 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 02-07-2008 01:18 AM
Need help for JDM STi version 7 swap in 02 WRX mathroch Subaru Conversions 3 08-11-2006 10:14 AM
