Old 03-04-2009, 07:01 AM   #1
jacky599r
Member#: 137631
2006 WRX
Red
Default how long does it take for a cooling system to be stable?
Im looking at replacing my rad... however, 2 days later, i will be going for a track day. i was wondering if it will be wise to do the upgrade in such a time. i understand theres a need to burp the system. However, may i ask how long does it take for the entire system to be all well and good?
jacky599r is offline   Reply With Quote
Old 03-04-2009, 08:00 AM   #2
Storm
Member#: 5218
96L Most Over-
Developed Beater
It shouldn't take that long. Do a proper bleeding of the system and you shouldn't have any problems.
Jay
Old 03-04-2009, 09:23 AM   #3
MasterKwan
Member#: 98961
2003 WRX
Typically when I replace coolant, I have the front end jacked up into the air. I don't have to burp the system at all. I just add fluid, run the engine and top off the recovery tank after the first time I get the engine to operating temp.
Old 03-04-2009, 11:14 AM   #4
jacky599r
Member#: 137631
2006 WRX
Red
front end jack up?
why would that help? so...its save to do a radiator replacement 2 days before track day? Did u see a drop in level and needed to top up?
Old 03-04-2009, 02:52 PM   #5
MasterKwan
Member#: 98961
2003 WRX
These engines need to be burped because they get air pockets in them. My theory is that jacking the front end up reduces the area for air pockets to form.
As for the track day, watch your temp and come in if the needle starts to move. I never needed more than 1-2 heating/cooling cycles to get mine topped off.
Old 03-05-2009, 11:55 AM   #6
AliBenn
Member#: 487
1998 /2005 STunIcorn
Acadia Green RS-T
^^^^agreed
after an autox, my temp was all over the place
had to burp sytem 2-3 times(add h20 to highest place on cooling system) over 2-3 days
AliBenn is offline   Reply With Quote
How long does it take for Marijuana to clear you system? outbacksport Off-Topic 35 09-20-2006 11:24 PM
how long does it take for money order to get to the seller? MadDogSTi General Community 15 05-02-2006 02:47 PM
How long does it take for a Subaru Tech to get back to the dealership? jk147 General Community 12 04-23-2002 12:33 AM
How long does it take for the CE light to come on? 2yLiTe Normally Aspirated Powertrain 0 06-29-2001 06:28 PM
