Old 03-04-2009, 01:09 PM   #1
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
Default wheel and tire drag setup?
I am looking for a drag racing setup for a 07 wrx with stock brakes. I was thinking on going with 17x7 lightweight wheels with motorcycle slicks but I heard they are really difficult to mount.
The wheels can be 16" or 15" but they have to clear the calipers and that I can fit with the stock wheel studs. So what wheel size, offset do you recommend? And which tires, drag radials, slicks, something sticky? Please keep weight and traction in mind.
Thanks
Old 03-04-2009, 02:11 PM   #2
MattPersman
Member#: 139385
you aren't the dude mounting the slicks are you? let the tire kids have fun mounting those slicks, they will give you the best traction over a radial tire for all out traction. only problem I ever had was balancing a few slicks or ET streets, mounting was never an issue
MattPersman is offline   Reply With Quote
Old 03-04-2009, 02:16 PM   #3
xdrian
Member#: 104200
828 WHP BUGEYE
Street Proven Performance
Thanks
16 inch rim with some 26inch slicks from hoosier, you should be good
xdrian is offline   Reply With Quote
Old 03-04-2009, 02:47 PM   #4
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
But all the cool kids in PR are running the MC tires. I'd ask them if you really want to know but honestly, are you that serious about dragging to justify the hassle? Are you running 11tybillion HP to the earf?
Old 03-04-2009, 02:52 PM   #5
Junior2JZ
Member#: 64908
10.8 [email protected] GR+
9.1/157mph 2015 STI
Depending on the HP you are making
16" will let you run a taller tire and you can benefit from gearing that way.
Junior2JZ is offline   Reply With Quote
Old 03-04-2009, 03:24 PM   #6
juanmedina
Member#: 133146
Truth
What offset wheel and width? What size of tires?
Good, the same questions as xdrian
Originally Posted by kellygnsd View Post
But all the cool kids in uPR are running the MC tires. I'd ask them if you really want to know but honestly, are you that serious about dragging to justify the hassle? Are you running 11tybillion HP to the earf?
the wheels and motorcycle slicks come out at 1k that's a great price and they provide excellent traction EVOs have cut a 1.3 . Also, weight savings I think it will save me 70lbs.
My car has a V39 on E85 and is a WRX, and I am not going to go to the track with 18x9.5 wheels
Old 03-04-2009, 03:34 PM   #7
cucamelsmd15
Member#: 122980
2010 F150, 2013 CX-5
92 Miata 15 TTF/PTF/E3
IBblowntransmission/diff/axle
cucamelsmd15 is offline   Reply With Quote
Old 03-04-2009, 03:39 PM   #8
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
Im with kelly on this one.
Spend the money on a 20g and injectors. You're gonna spend $1000+ on wheels/tires that you're gonna use like 6 times a year.
Might as well spend it on something you get to use everyday....
this too. hooking up like that is gonna shock the hell outta your driveline.
Old 03-04-2009, 03:48 PM   #9
juanmedina
Member#: 133146
I just want to see what this thing can do? I either buy them or borrow them.
Old 03-04-2009, 03:54 PM   #10
Phatron
Member#: 36033
CEO PhatBottiTuning
Is it worth $4000 for a new tranny to "see what she can do"?
I'd rather bench race on this one.....go run a 12.5 and then assume you could've run a 12.1 with the slicks.
Old 03-04-2009, 04:02 PM   #11
juanmedina
Member#: 133146
I am already making more power than my tranny is suppose to handle, what's the point of moding if you are not going to race. Probably my big ass wheels put as much stress as the lightweight wheels with slicks. My car will be on the mid to high 2700 lbs with the slicks, and 6k for a new tranny
Old 03-04-2009, 04:05 PM   #12
kaos200
Member#: 2692
You've cut 400+ pounds out of your 07?
Inquiring minds want to know how
kaos200 is offline   Reply With Quote
Old 03-04-2009, 04:32 PM   #13
jasv11
Member#: 117862
2006 STi [email protected]
96 impreza 9.55e.t.146mph
The MT motorcycle slicks are only difficult to mount on a 8 inch wheel.
If your putting them on 7 inch wide wheel it wont be as bad, the tire shop just needs to use a air blaster to get the bead to grab.
Stock turbo?? just buy a set of Drag radials that you can use on the street and get more use out of them that way.
Also go to the track when the higher HP cars run as they usually prep the track much better those days then they do on the test and tune nights where Honda's drag the water up to the line with there back tires
jasv11 is offline   Reply With Quote
Old 03-04-2009, 05:09 PM   #14
Phatron
Member#: 36033
CEO PhatBottiTuning
i broke mine with a vf34 on.
your 18" arent doing a thing compared to a clutch drop with slicks on.....
Old 03-04-2009, 06:28 PM   #15
juanmedina
Member#: 133146
from EVOM
posted by Warrtalon
EvoCrazy, you should see our argument in the Drag forum, although it's deep within a 900-post thread. Slicks are NOT more damaging - they are less damaging to the drivetrain unless you do something wrong. Street tires and DRs will be more prone to wheel hop (street tires are worse) while slicks will take all the shock and put it into traction due to the tire walls wrinkling.
Old 03-04-2009, 06:34 PM   #16
STi Mikey
Member#: 114631
2009 GTR, 735whp
13' Benz, 15' WRX
from EVOM
Juan, you only have a 39 on your car. Before getting crazy, try what I will be doing this weekend. Im on coilovers, so I'm jacking up the back and reducing tire pressure form 30psi to 20psi. Last weekend I spun and spun, this weekend, I expect to hook. I think hooking alone will give me the record given conditions and driving are relative.
My car is currently slammed. I figure if I relieve 33% of tire pressure, and loosen up the rear, there should be plenty of give into hooking. Ive always dragged these cars almost as is. Sometimes some weight reduction. This weekend I will be dragging my STi as a drag car. Weight out, low tire pressure, and plenty of rear suspension play. I pray for 1.60-1.65's. Those 60 ft's should yield high 11.5 to low 11.7's
STi Mikey is offline   Reply With Quote
Old 03-04-2009, 06:36 PM   #17
SubyWill
Member#: 166830
2003 WRX
IBtrannygoboom
SubyWill is offline   Reply With Quote
Old 03-04-2009, 06:41 PM   #18
juanmedina
Member#: 133146
you use Mikey thompson's on the 08 sti, correct?
Old 03-04-2009, 06:45 PM   #19
juanmedina
Member#: 133146
I have coilovers as well, someone told me to set them to the stiffest settings, maybe I go to the track with the car as it is. How wide 16" wheels and what offset will work in my car? maybe I get the nitto r555 I heard they are drivable on the street and the don't wear out as fast.
Old 03-04-2009, 07:03 PM   #20
wrxwhat
Member#: 87653
500 hp STI / 1100hp
Supra T / Stock G35
if you can't do 1.6x with all that power on the stock turbo, then you fail
wrxwhat is offline   Reply With Quote
Old 03-04-2009, 07:05 PM   #21
n2oiroc
Member#: 141952
03 11 wrx/13 brz
my buddy has the 555r's on his camaro. they handle like a decent summer tire at full pressure. they only get squirmy when you air them down to 25 psi or less. they arent as good as the full on drag tires, but handling/driveability/wear is 10x better.
n2oiroc is online now   Reply With Quote
Old 03-04-2009, 07:07 PM   #22
jasv11
Member#: 117862
from EVOM
osted by Warrtalon
Ha ha ha Warrtalon has never launched his car with slicks and is talking out his arse.
If he thinks the slicks will krinkle and save his drivetrain.
yes they will krinkle..........and then they'll hook..........bang all in one thousands of a second.
Heres a vid of what happens when you launch with slicks with stage 2 DSS axles
listen for the snap
http://www.youtube.com/watch?v=BUxJasJw-SQ
Old 03-04-2009, 07:07 PM   #23
n2oiroc
Member#: 141952
03 11 wrx/13 brz
and the 60' times better be in the 1.5 range. heck, quite a few guys on stock tires get mid 1.6's on stock sti's!
Old 03-04-2009, 07:13 PM   #24
wrxwhat
Member#: 87653
500 hp STI / 1100hp
Supra T / Stock G35
17psi on 225/45/17 kdw2's got me 1.57 with way less power than this kid has
Old 03-04-2009, 07:29 PM   #25
n2oiroc
Member#: 141952
03 11 wrx/13 brz
exactly my point. if he goes and pulls 1.8's with slicks then he better get ready for a flaming. my first time down the track with my stage 2 sti and i pulled a 1.70 60'. more practice and i bet i could have pulled some lower 1.6's.
WTB winter wheel and tire setup fred6870 Private 'Wanted' Classifieds 2 10-07-2009 08:23 PM
My wheel and tire setup (370Z) - need expert advise. DannyGT Tire & Wheel 8 02-14-2009 02:58 AM
FS: Race wheel and tire setup - 18x10's and 18x8.5's with V710's.... AndrewSS Suspension/Brakes/Handling 10 09-21-2008 10:13 PM
Whats The Best Wheel And Tire Size Setup? Turk Technical Forum Archive 4 07-26-2000 10:35 AM
Whats The Best Wheel And Tire Size Setup? Turk General Forum Archive 1 07-25-2000 10:15 AM
