Old 03-04-2009, 07:26 PM   #1
twizzstyle
Member#: 18941
2005 Lotus Elise
Orange
Default 2002 WRX w/16g and water/meth
Just got tuned today by Tim at Dyno Authority in Redmond,Wa. I had my car tuned there last summer when I had a VF39, and it was fast, but I needed more torque down low (the car is really only driven at autocross). The numbers are pretty good, of course I could always use more, but I think this will hold me over for a while.
Mods:
- Forced Performance 16g (standard 16g)
- Walbro fuel pump
- 07 STi injectors (~565cc's)
- CSS top mount intercooler
- K&N short ram intake
- Aquamist 2D, 50/50 water/meth with a 0.7mm nozzle
Results (Mustang Dyno):
275.7whp @ 6000rpm
276.1wtq @ 4750rpm
21psi boost peak by 4000rpm, tapering just slightly starting at ~5500rpm to about 18 at redline
AFR right around 12.5 to 12.75
Compared to my previous setup (VF39, USDM STi tmic, no water/meth) I gained 13.3hp, and 32.8tq. The top end feels about the same, but you can really feel the torque down low. Power feels much more linear and smooth, as its just there the whole time. Before, the good power band felt like it was only 5k-7k, where as now, everything above 3k goes like a rocket.
I don't think there is much more I can do on the 2.0 to get much more power while retaining my low end for autox. 300whp/300wtq would be rediculously amazing, but I'm not sure I can do it (or want to, $$$)
twizzstyle is offline   Reply With Quote
Old 03-04-2009, 08:55 PM   #2
STi Mikey
Member#: 114631
2009 GTR, 735whp
13' Benz, 15' WRX
Mods:
- Walbro fuel pump
Results:
275.1whp @ 6000rpm
276.1wtq @ 4750rpm
Hey man, nice set-up. Good luck with auto-x, its so damn fun!! What dyno?!
STi Mikey is offline   Reply With Quote
Old 03-04-2009, 09:20 PM   #3
twizzstyle
Member#: 18941
2005 Lotus Elise
Orange
Yes, autox is far too addicting... I started about 2.5 years ago, and haven't been able to stop since.
It was a mustang dyno, I suppose I'll add that info.
Old 03-04-2009, 09:24 PM   #4
snwboard4life69
Member#: 166788
2003 subaru wrx
stage 3 race car
hey man i pulled off 320 whp and 300 tq on pump gas with a vf-39 anythings possible
snwboard4life69 is offline   Reply With Quote
Old 03-05-2009, 08:36 AM   #5
wrxhard
Member#: 108091
On a mustang dyno?
wrxhard is offline   Reply With Quote
Old 03-05-2009, 09:02 AM   #6
Paul
Member#: 56203
00 RSTI Coupe
Twin Scroll 2.5XTR EJ207
those numbers sound a lil low for your mods....that wouldnt bother me as much as you swtchin to a better turbo, better ic, and running meth and the top end doesnt real any better. Iam sure the tq helps in auto-x but a lil more top end never hurts
Old 03-05-2009, 12:11 PM   #7
Rudywrx04
Member#: 134273
04 VF 48 P&P
289 WHP 275 WTQ
Good numbers on a Mustang Dyno!
Rudywrx04 is offline   Reply With Quote
Old 03-05-2009, 12:28 PM   #8
Audiosavvy
Member#: 150794
Qcab dakota 4x4
LT1 Formula Firebird
Good numbers, but the torque seems to come on a bit late, and the boost seems a bit low for meth/water.
Audiosavvy is offline   Reply With Quote
Old 03-05-2009, 01:01 PM   #9
Subian
Member#: 202804
2002 PSM Sedan
The 2.0L that could
how much did the css top mount run you?
Subian is offline   Reply With Quote
Old 03-05-2009, 06:25 PM   #10
twizzstyle
Member#: 18941
2005 Lotus Elise
Orange
22psi is low?? I don't think I'd be comfortable running higher than that on the stock motor!
The CSS intercooler was like $250 or something? I can't remember. The intercooler itself is fine, no different than an Ebay intercooler, and their customer service is TERRIBLE. But I can't complain about the intercooler itself, it works great, just took forever to get it.
Old 03-05-2009, 06:39 PM   #11
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
if you autoX why didnt you just keep the sti tmic, plumb it with meth and get a PnP'd td04?
a td04 on meth with alot of boost can make for some NASTY torque numbers.
the 2.5L guys are making like 300+ wtq with the td04.
mxpunk is offline   Reply With Quote
Old 03-05-2009, 06:54 PM   #12
Audiosavvy
Member#: 150794
Qcab dakota 4x4
You said 21 psi. I wouldn't worry about the block around that boost level, but the point I was making is that the boost seems low for the octane level. I run 22psi on California 91 piss gas, and 25-26on meth
Old 03-05-2009, 07:14 PM   #13
STi Mikey
Member#: 114631
2009 GTR, 735whp
13' Benz, 15' WRX
That must be one hell of a car then, I only made 306 last season.
Old 03-05-2009, 07:25 PM   #14
Steve.804
Member#: 68647
07 STI 35R
05 BMW M3 ZCP
How much boost were you pushing with the vf39? I push about 22psi in the midrange on my 07 STI but tapers to about 16 at redline (on 93 pump.) With meth injection 24psi should be achieved realativly safely and offer a really nice mid-range punch!
Steve.804 is offline   Reply With Quote
Old 03-05-2009, 07:29 PM   #15
AWDWRXLOVER
Member#: 50267
02 built hybrid
sr55/meth/sick speed
didnt yours let go and now your building stroker motor?
AWDWRXLOVER is online now   Reply With Quote
Old 03-05-2009, 10:55 PM   #16
boxergq
Member#: 94516
04 WRX
java blk
Not bad...
boxergq is offline   Reply With Quote
Old 03-06-2009, 12:33 AM   #17
boxergq
Member#: 94516
04 WRX
java blk
Here mine. big 16g, modified injectors ,tgv deletes, fuel pump, spearco IC,injen cai, helix up & dp, greddy evo2.
Old 03-06-2009, 02:49 PM   #18
Audiosavvy
Member#: 150794
Qcab dakota 4x4
Yes, but it was not a result of too much boost. It was an oil issue (spun bearing). And it's still very much alive, just slowly dying, but it gave me an excuse to go with a built motor
My problems didn't happen running meth, they happened on a pump tune driving around normally (5psi max during daily driving).
Old 03-06-2009, 03:27 PM   #19
Subian
Member#: 202804
2002 PSM Sedan
The 2.0L that could
Low on oil or was this because you were doing something "spirited driving" related? What's a safe ps1 number to run on the 16g without meth? around 19-20?
97 impreza wagon w/ wrx swap, 16g and many goodies!! Skatermxracer Private Vehicle 'For Sale' Classifieds 11 08-18-2009 09:55 AM
PSI w/ GT30-11 turbo and water/meth (safe) visualsinz Newbies & FAQs 3 07-28-2008 04:57 PM
Discuss: Water and water+meth tuning jblaine Water/Methanol Injection, Nitrous & Intercooler Cooling 29 08-15-2007 02:45 PM
Monster TD04 and water/meth injection. fastwrx05 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 18 08-08-2006 11:46 PM
