Old 03-04-2009, 09:03 PM   #1
gc8awdsti
Member#: 192848
1998 GC8 rsti
BDP
Default ej20g code 45 CEL
OB1 says pressure solenoid. car ran 100% FINE TODAY able to boost and pull all day. well tonight came and i got into boost and BANG, boost cut (fuel cut) car jerks bad. as soon as i get into boost just fuel cut and a CEL came on, pulled over and it turns out to be code 45 which is the pressure solenoid. how can i get this CEL off and get my car running right again?
gc8awdsti is offline   Reply With Quote
Old 03-04-2009, 10:45 PM   #2
rockcrete
Member#: 196721
1993 GF8 WRX Wagon
Probably it has either come unplugged or the wires are broken/shorted.
rockcrete is offline   Reply With Quote
Old 03-04-2009, 11:09 PM   #3
rockcrete
Member#: 196721
1993 GF8 WRX Wagon
How'd you get it running and fix the tranny, anyway?
Old 03-04-2009, 11:14 PM   #4
subartender
Member#: 135652
2007 WRX TR
CGM
Do you hear clicking noise from the engine bay when you key is turned to on?(not running)
subartender is offline   Reply With Quote
Old 03-05-2009, 01:39 AM   #5
sniper512
Member#: 189923
1993 JDM WRX
I believe for the clicking you must plug the green test connectors in under the dash and turn the key on. If there isn't any noise then she's got some issues as stated above.
sniper512 is offline   Reply With Quote
Old 03-05-2009, 05:58 AM   #6
gc8awdsti
Member#: 192848
1998 GC8 rsti
BDP
it has the clicking.
the solenoid seems to actually be fine and working. but i cant seem to clear the CEL.
i fixed it by taking the 12mm nut off the shift linkage and puting the litle round metel cover over the rubber bushing on the shift linkage arm that bolts to the trans. it was tightend up with no metel gaurd, so it wouldnt let the rubber bushing slide bacj and forth...lol
Old 03-05-2009, 09:16 AM   #7
sniper512
Member#: 189923
1993 JDM WRX
So its fixed?
Old 03-05-2009, 09:33 AM   #8
luka
Member#: 194742
1993 Impreza WRX JDM
I threw a 45 CEL because a small line from MAP to the BCS came loose (passenger side strut tower)
luka is offline   Reply With Quote
Old 03-05-2009, 04:01 PM   #9
gc8awdsti
Member#: 192848
1998 GC8 rsti
BDP
lines are new going to it, and the solenoid is working..lol but still has the code.
i fixed my trans problem not the CEL problem.
Old 03-05-2009, 04:48 PM   #10
rockcrete
Member#: 196721
1993 GF8 WRX Wagon
Is your wastegate connected properly AND moving? get a wrench on it and make sure it's swinging.
Old 03-05-2009, 06:24 PM   #11
subaruwrx
Member#: 1818
03 1996 Impreza Wa
Soon to be a v3 STI
Check all the vacuum hoses on teh intake and turbo. I got that error and pulled EVYERHTING apart and replaced the solenoid and it was a hose that had crimped and cracked. Replaced that and no more code!
subaruwrx is offline   Reply With Quote
Old 03-05-2009, 07:30 PM   #12
gc8awdsti
Member#: 192848
1998 GC8 rsti
BDP
everything is new and replaced. still have the code. everything is hooked up correctly.
this is strange. sux bc anyhting above half throttle is fuel cut.
Old 03-05-2009, 07:51 PM   #13
rockcrete
Member#: 196721
1993 GF8 WRX Wagon
It is fuel cutting because your MAP sensor is reading a boost level above the fuel cut level.
Something is disconnected/hooked up wrong or your wastegate is stuck.
You haven't mixed up the hoses on your solenoid, have you?
I was messing with my car one day and forgot to plug the MAP sensor hose back in and that's exactly what it did - fast as hell before it hit that cut though.........
Old 03-05-2009, 07:58 PM   #14
gc8awdsti
Member#: 192848
1998 GC8 rsti
BDP
just checked, everything is fine, im about to go make sure my HKD FCD is still wired in correctly, one of th ewires might have broken loose or something... will update in a few..
Old 03-05-2009, 11:43 PM   #15
gc8awdsti
Member#: 192848
1998 GC8 rsti
BDP
problem fixed!
my HKS FCD had a slight nick in the power wire and kept touching to the ECU bracket, so it was shorting out.
heat shrinked it and re soderd the wire and looks new. car work 100% excellent now.
thanks for the help guys. glad to have my car back on the road. now i just need to buy a few interior pieces and what not.
Old 03-29-2009, 11:42 AM   #16
WRX_RA
Member#: 151188
1997 GC8 EJ20G
2010 W204
off topic but what code reader are you using?
WRX_RA is offline   Reply With Quote
Old 03-29-2009, 12:20 PM   #17
rockcrete
Member#: 196721
1993 GF8 WRX Wagon
You don't use a reader, look under your steering column and you will find an unplugged black connector. Plug it together and then turn your key to the run position without starting it. Now you can count the blinks of your "check engine" light - long blink = first digit, short blink = second digit
ej20g code 43? Rikshaman Pre-2002 Factory Turbo Powertrain 7 01-28-2009 09:57 AM
EJ20G CEL Code 45 - Pressure Duty Solenoid subaruwrx Pre-2002 Factory Turbo Powertrain 5 10-30-2008 11:12 AM
EJ20G Code 42 question TVA Pre-2002 Factory Turbo Powertrain 1 10-12-2007 03:45 AM
Can anyone pull the code for CEL tomorrow (Sat)? Jonathan_Yi Mid Atlantic Impreza Club -- MAIC 8 03-26-2004 11:21 PM
EJ20G codes 14-17... say what? smacksube Subaru Conversions 4 12-30-2003 09:00 PM
