Welcome to the North American Subaru Impreza Owners Club Tuesday August 23, 2016
Old 04-10-2002, 05:45 PM   #1
dknc
Member#: 8165
2001 RS 2.5
Asspen White
Default STI red manifold
Will the STI EJ20 red intake manifold fit on the EJ25 engine???
I've heard it doesn't, but I just want to confirm.
dknc is offline   Reply With Quote
Old 04-10-2002, 05:52 PM   #2
Graham
Member#: 11931
2001 2.5 RS Turbo
257/FMIC/T3-T04S
Hmm, don't know. I do know that the intake runners for the EJ20 manifold bend differently than the EJ25, to make room for the interooler. I have seen guys just paint them in red, looks pretty cool. I know suberstar2.5 here on i-club painted his red.
Graham
Graham is offline   Reply With Quote
Old 04-10-2002, 05:53 PM   #3
Gerry
Member#: 1829
Gerry is offline   Reply With Quote
Old 04-10-2002, 05:58 PM   #4
Gerry
Member#: 1829
Just have yours powdercoated..It's alot easier..Here is a pic after mine was done..Gerry
Old 04-10-2002, 07:22 PM   #5
Darshu
Member#: 1676
98RS w/ EJ257/Dom
2014 Tesla Model S P85
Thing of beauty
Reversed manifold for a FMIC? Sweet.
Darshu is offline   Reply With Quote
Old 04-10-2002, 08:51 PM   #6
Gerry
Member#: 1829
Yup...I'm getting rid of the power steering.found a quick ratio manual rack and pinion ..and relocating the alternator to the P/S spot so I can keep my A/C. The I/C core I am using is 30"-14"-4"...Need a big intercooler to move big air Plus it's a more direct flow, and shorter distance to the manifold....Gerry
Old 04-10-2002, 10:48 PM   #7
Darshu
Member#: 1676
98RS w/ EJ257/Dom
That's a huge IC core! I'm very curious about the new steering rack though --- I for one am pretty disappointed in the long ratio of the stock rack --- is this an off the shelf part that's easily available or a custom fabricated piece?
Old 04-10-2002, 11:18 PM   #8
Gerry
Member#: 1829
It's actually a custom subaru part. It's out of a 92 legacy. The problem is that the legacy's had P/S...I think this rack was out of a Legacy Mail Man car. The reason I believe this is because I got from upstate NY.. and they use Subaru's as mail carrier cars. All I had to do was some bushing work.Any rack and pinion place shouls be able to modify a Loyale manual R&P setup.
Also I tried to look for a new unit at Metric Subaru and there is no part listing for it in any subaru book...
Old 04-11-2002, 02:40 AM   #9
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
a man after my own heart...i hate people that pull their A/C off to build a car cause it's "weight" sorry i'd rather lose 30 lbs then lose my comfort factor. Manifold looks great gerry.
jeremy
Old 04-11-2002, 11:03 PM   #10
RawCode
Member#: 3115
2002 Impreza 2.5RS
How much work/money did it take to rotate the manifold around like that. For my 02 RS I would perfer a FMIC also, as to keep the "sleeper" look.
RawCode
RawCode is offline   Reply With Quote
Old 04-12-2002, 02:10 AM   #11
Ver.III
Member#: 1185
I flap my gums
and now I'm a specialist
On that engine, just turn it around.....for you, no charge !!
Seeing that is an early 96 EJ20 with the high intake, hope your hood closes !! You may want to consider a 97-98 Wrx intake since the throttlebody chamber is lower.
Looks good, like the polished block. Good luck.
Ver.III is offline   Reply With Quote
Old 04-12-2002, 02:58 AM   #12
Gerry
Member#: 1829
I thaught it was going to be a problem when it was installed but it fit just fine. I actually have a 98 intake standing by for dyno tests.The runners are a little longer and wider on the 98. It is the one that Looks like a squashed "M"...Like the polished block look ..What a pain in the ass, It was well worth it though..Now for polished adjustable cam gears..WooooHooo
FS (OK): 2000 2.5RS Wheels/Tires, TD04, 04 STI Red Manifold jimbobrand TXIC Private Classifieds 14 01-23-2009 06:39 PM
FS (OK): 2002 TD04, 04 STI Red Manifold jimbobrand Engine/Power/Exhaust 10 01-21-2009 05:27 AM
FS: Tanabe exhaust, RA 5spd tranny, STi red manifold, WRX oil pan cubuff Engine/Power/Exhaust 0 06-03-2008 01:25 AM
STi red manifold for flipped use!!! 500hpwrxsti Mid Atlantic Impreza Club -- MAIC 15 12-31-2004 08:05 AM
STi red manifold for flipped use!!! 500hpwrxsti Private 'For Sale' Classifieds 2 12-30-2004 03:01 PM
