Old 03-05-2009, 12:06 PM   #1
Skin Irritant
Member#: 157208
2006 Wrx TR Wingless
Default Amp will not fire up?? PLEASE help and advise
My 06 wrx came used with a kenwood deck. I have installed amps and subs before so I thought "no biggie". I got all the wires ran, plugged everything in, and NOTHING! My amp will not fire up.
I started checking connections. I put a low watt fuse in the breaker on the amp main power line, and then touched it to metal. Fuse blew.. so I know I have hot power.
I ran the remote line off the power antenna line (which I have done in almost every install that I have done) so the only thing that I can figure is that I am not getting a good ground.
Is the subaru paint heavier than most where it would require me to sand it down to bare metal? I have never had to do that before, but again this is my first subaru.
Any and ALL help will be much appreciated.
Skin Irritant is offline   Reply With Quote
Old 03-05-2009, 12:13 PM   #2
Giganticprune
Member#: 147662
2006 wrx tr stage 2
ALWAYS sand to bare metal. its not a good ground unless otherwise. make sure its friggin tight too. honestly like 95% of every car audio problem ive dealt with was because of bad grounds.
but on another note, think about it, you hooked up to power antenna wire..most decks will only run that wire hot when youre on the radio, when it needs the antenna. there should be a designated remote wire from that deck. or you can hook up to the red wire from the back of the radio which is a 12v switch.
Giganticprune is offline   Reply With Quote
Old 03-05-2009, 12:23 PM   #3
Audiosavvy
Member#: 150794
Qcab dakota 4x4
LT1 Formula Firebird
Get the remote off the power antenna line, that is the wrong one. Try turning on your radio right now, I bet the amp turns on . You have a blue wire with a white stripe coming out the ass end of the stereo, that is what was meant to be used for your amp turn-on, not the solid blue (the power antenna lead).
And you ALWAYS mount your ground to bare metal, unless you're running it directly back to the battery.
Audiosavvy is offline   Reply With Quote
Old 03-05-2009, 01:14 PM   #4
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
Covered..
Old 03-05-2009, 02:02 PM   #5
Skin Irritant
Member#: 157208
Thank you for the suggestion..... but let me ask this. Even with the remote line possibly connected to the wrong output..... with the hot and the ground running to the amp, would it not still power up?? I throught the remote was there just so it would not stay powered on all the time.
When I get home today I will pull the deck and switch the wire to the other lead
Old 03-05-2009, 02:04 PM   #6
punk
Member#: 169792
2005 STI
The remote tells it when to turn on and off, not just off.
punk is offline   Reply With Quote
Old 03-06-2009, 10:18 AM   #7
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
Switch to radio, doe the amp power up? you could easily take a 1" short of wire and short between B+ and the remote line and test (you might wanna take the remote wire off first, so it doesn't backfeed... but yeah, you need the OTHER blue wire.. lol..
My Car will not fire at all silverbullet830 Service & Maintenance 22 09-04-2008 03:32 PM
Car will not Rev Up, help please mamu Normally Aspirated Powertrain 12 01-12-2006 03:35 PM
Car will not make Boost! Please HELP! Genya Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 05-24-2004 05:00 PM
need help car will not fire 387hardcore Pre-2002 Factory Turbo Powertrain 2 05-03-2004 12:58 AM
Cusco rear swaybar will not stop clunking, please help. Darkstar Brakes, Steering & Suspension 12 01-20-2003 01:51 PM
