Old 03-05-2009, 04:28 PM   #1
powerneedy
Member#: 161242
Default Car cutting out when going wot???
So my dads car is now a 95 with pretty much everything 04 05 sti...
the problem is when you put the throttle 85% the car throws a tps high voltage code. its not the pedal out of wack as we had 2 and both do this. I am un sure how to test if the tps is in check and were it is, is it all contained in the dbw unit? is there a way to adjust this...
thanks guys
powerneedy is offline   Reply With Quote
Old 03-05-2009, 05:43 PM   #2
MasterKwan
Member#: 98961
2003 WRX
With an OBD2 scanner, you can watch the TPS voltage.
Old 03-05-2009, 08:38 PM   #3
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
you cant make any adjustments to the dbw throttle assembly. What code numbers are you getting?
Old 03-07-2009, 07:45 PM   #4
wrxSLEEPER03
Member#: 189820
2009 STI
Check all the wiring, it seems you have a nice swap. So check the wires and check voltage with a scanner. Most repair shops will have one but usually charge minimum an hour labor to do it so good luck.
wrxSLEEPER03 is offline   Reply With Quote
Old 03-09-2009, 05:24 PM   #5
powerneedy
Member#: 161242
i can scan it with the a cobb ap...
I think its code high voltage tps d and e i will get the numbers and post it here shortly
Old 03-09-2009, 09:45 PM   #6
Spiider
Member#: 13680
Also check the vehicle speed sensor, if it is bad you get behavior just like this. It feel's a 4500 rpm cutoff like a stutter box in a bracket car.
Spiider is offline   Reply With Quote
Old 03-10-2009, 10:08 AM   #7
kirkdunkan
Member#: 205260
Where to see code numbers? Don't find.
kirkdunkan is offline   Reply With Quote
Old 03-13-2009, 12:35 PM   #8
powerneedy
Member#: 161242
ok i have the code numbers, I pretty sure these are the only 2 it is throwing
p2123
p2128
Old 03-13-2009, 01:38 PM   #9
MasterKwan
Member#: 98961
2003 WRX
You know there was a discussion about this same thing in the 2.5 forum. It's not happy with the DBW gas pedal (those 2 codes are DBW codes). You're probably getting it to read over 100% at the ECU and it's cutting the power.
The procedure implies you have a wiring problem with the DBW pedal though.
Old 03-13-2009, 02:16 PM   #10
powerneedy
Member#: 161242
ya i under stand that its a dbw issue and its going over 100%
How would i have a wiring issue when the only thing that has been cut on this whole harness is headlight taillight, and stuff for the doors???
could it be a ground? i just need to figure this out and i have completely ran out of ideas...
could it be the throttle body motor has gone bad? It makes a electrical whine when you have power going to it when the car is off... would that imply that its a ground? but i dont understand how if its a ground why it would be telling to that the pedal has more range
TIA
Old 03-13-2009, 03:15 PM   #11
MasterKwan
Member#: 98961
2003 WRX
I'm just telling you what the trouble-shooting procedure says. I have no opinion of whether it's wiring or not. Going over 100% throws the car into limp mode according to the other topic. If it's going over 100% you need to do something to prevent it.
The whine you hear might be the DCCD. I was out dicking with the DCCD controller the other day and it makes a distinctive whine when it's in manual mode and I change the position,.
Old 03-13-2009, 08:13 PM   #12
silentt
Member#: 119995
2004 Outback XT
Peachy
Take a look at the ECS Pedal adapter, their adapter has a fix for that. Check it out on RS25, should be in the vendor section.
silentt is offline   Reply With Quote
Old 03-13-2009, 08:26 PM   #13
powerneedy
Member#: 161242
no no i can here the whine coming from the throttle body
Old 03-13-2009, 08:28 PM   #14
powerneedy
Member#: 161242
i have the pedal adapter... what the fix, im trying to find it and cant?
Old 03-13-2009, 09:24 PM   #15
MasterKwan
Member#: 98961
2003 WRX
My fix was to install the plastic bumper on the floor of the car that prevents the pedal from going too far.
Old 03-14-2009, 05:08 PM   #16
powerneedy
Member#: 161242
so this is not an uncommon thing then ?
if its just a matter of i have to stop the pedal thats fine i thought it was to do with somthing else
Car cuts out then starts again when fuse box is touched. Halps! cazwrx187 Electrical & Lighting 2 08-21-2009 10:14 AM
HELP NEEDED!!! sub install on OEM deck, cuts out when CD plays AustinForester Texas Impreza Club Forum -- TXIC 3 04-12-2008 10:19 PM
Alpine deck cuts out when shutting ignition Airboy Car Audio, Video & Security 1 11-10-2005 11:44 AM
Radio Cuts out when too loud? Stellar1 Car Audio, Video & Security 6 06-19-2005 03:57 PM
car cuts out when wot whats wrong? iDRIVElikeAmadman Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 06-29-2004 08:21 AM
