Old 03-05-2009, 09:41 PM   #1
amitch45
Member#: 203500
2002 vf30'd WRX
Default HVAC color change question
So I tried changing the color of my HVAC to blue by using blue bulb covers over the 2 bulbs in the back. I have a 2002 WRX and I read somewhere that the faces on 2002's as well as the knobs were clear and only have the bulb covers affecting the color. However, when I changed the covers and turned the lights on, the color was sort of a greenish blue. More blue than green but definitely not as blue as I wanted. Has anyone else changed the color of their HVAC on an '02 to blue with good results? I didn't know if the HVAC had to be take apart and scraped or something like that. Thanks for the input.
amitch45 is offline   Reply With Quote
Old 03-05-2009, 11:13 PM   #2
amitch45
Member#: 203500
2002 vf30'd WRX
Would I need to change the bulbs completely?
Old 03-06-2009, 10:55 AM   #3
Rodwrx23
Member#: 170948
I used these http://autolumination.com/74.htm (first ones on the page going down)
and got this result
Rodwrx23 is offline   Reply With Quote
Old 03-06-2009, 11:41 AM   #4
Jncominco2
Member#: 170212
no it doesnt have to be taken apart
i think the bulb covers you used were just too light of a blue, or at least they are once the light is on
try finding a darker one, or put 2 on each, it will come out darker
Jncominco2 is offline   Reply With Quote
Old 03-06-2009, 07:05 PM   #5
Spore
Member#: 100117
2009 Impreza 2.5i
Satin White Pearl
I would suggest you to go for the LED route. Blue bulb covers aren't blue enough for your needs.
Spore is offline   Reply With Quote
Old 03-06-2009, 08:17 PM   #6
amitch45
Member#: 203500
2002 vf30'd WRX
Thanks guys, I ordered some leds so hopefully it will work out
By the way Rodwrx23, that looks sick. you just used 2 leds for the hvac?
Old 03-06-2009, 10:13 PM   #7
Rodwrx23
Member#: 170948
Thanks. Correct, I just used two of the 3-way led bulbs from the link I showed you. I recommend you get the sockets )twist lock bases) for them to in case your's give you problems; they're only .29 each anyways.
Old 01-01-2012, 02:14 PM   #8
thorracing160
Member#: 304830
2004 STI
i have a 04 sti on my HVAC i have 4 long twist and lock bulbs. witch leds do i need?!
thorracing160 is offline   Reply With Quote
HVAC Color Change 07 tricchio Southern California Impreza Club Forum -- SCIC 14 09-22-2009 01:48 PM
sti 06 hvac color change to red? gilbert_0004 Electrical & Lighting 1 02-18-2009 12:03 AM
Instrument Cluster, Radio, and HVAC color change murph32 Electrical & Lighting 7 08-11-2008 03:50 AM
HVAC color change to blue? g8rvictor Electrical & Lighting 16 11-21-2006 03:42 AM
05 HVAC color change? FostersAFB Interior & Exterior Modification 2 10-19-2004 01:11 PM
