Old 03-05-2009, 10:29 PM   #1
Max Umbarger
Member#: 1112
2006 FXT
RBP
Default Tuning shops still recommend OEM head gaskets.
Of course we are not limited too as we know there are other options, but 3 local tuning shops to me have recommended that in the 300 WHP range (my 06FXT) OEM head gaskets are sufficient. I don't want to have them fail 45,000 miles again later.
My question is what is making them better the 2nd time around? As far as I know for the 06's there have not been a revision. Did the factory do a crappy job installing them, torquing them improperly? OEM material failure? What gives. If it's workmanship I'm assuming a tuning shop will install HG's better to specs than at the factory right? In that case I'd consider going with another OEM set.
I will go with ARP studs this time around to negate any movement, but I've been considering Tomei HG's.
Thanks
Max Umbarger is offline   Reply With Quote
Old 03-06-2009, 12:37 AM   #2
07wrx4life
Member#: 171514
07 DOM 3 WRX
352/326 @ 20psi EQ Tuned
OEM's are fine as long as both the block and heads are decked ( flat surface machined ) and the ARP's are torqued correctly in the correct sequence. I believe its 40 ft lbs the first go around then 60 ft lbs then the final which could be 82 - 90 ft lbs.
I'm no engine builder but thats what I've gathered.
07wrx4life is offline   Reply With Quote
Old 03-06-2009, 01:14 AM   #3
Max Umbarger
Member#: 1112
2006 FXT
RBP
Thanks for the info. I'm certain they will use the revised torquing directions.
Old 03-06-2009, 11:37 AM   #4
Max Umbarger
Member#: 1112
2006 FXT
RBP
Here is a link about the product description...
http://www.tokyoseven.com/T7/product...roducts_id=499
Old 03-06-2009, 11:45 AM   #5
MasterKwan
Member#: 98961
2003 WRX
And it's better than stock because of...what exactly? I'd take OEM parts over aftermarket 99% of the time. I think it's more important that they use the correct head torquing technique than who made head gaskets. I always wondered if the arps stretched the same as the OEM bolts? It's the stretch of the bolt that keeps them tight.
Old 03-06-2009, 11:47 AM   #6
socalLGT
Member#: 89752
08 STI
OEM head gaskets work just fine even at significantly higher power levels. We use ARP head studs torqued in 4 steps to 85 ft/lbs and retorqued the next day and have never experienced a head gasket failure. Of course we also deck both the head and block mating surface to the correct surface finish as well.
socalLGT is offline   Reply With Quote
Old 03-06-2009, 01:29 PM   #7
Max Umbarger
Member#: 1112
2006 FXT
RBP
Okay thanks for the info.
Old 03-06-2009, 01:42 PM   #8
Clark Turner
Member#: 178047
02 WRX STI Spec C
605whp Stock gaskets. Not common for them to fail. I know one Friend/customer that lost one but that was 36 psi on Race fuel.
Clark
Clark Turner is offline   Reply With Quote
Old 03-06-2009, 02:56 PM   #9
Max Umbarger
Member#: 1112
2006 FXT
RBP
Yeah, I think I'm going OEM. I'm thinking the install is important and a safe/reliable yet powerful tune can save the head gaskets.
Old 03-06-2009, 03:55 PM   #10
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
det will kill headgaskets if the pistons dont go first
Old 03-06-2009, 04:16 PM   #11
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
OEM + ARP HEADSTUDDS = STOUT
300 whp is nothing these days
mxpunk is offline   Reply With Quote
Old 03-07-2009, 10:18 AM   #12
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
We use all OEM head gaskets and ARP head studs and have never had any HG issues. We also use copper spray on all of our headgasket prior to installation to help promote a good seal.
Tony
Old 03-07-2009, 02:20 PM   #13
flycaster
Member#: 60142
2011 WRX
Grey
Originally Posted by socalLGT View Post
...We use ARP head studs torqued in 4 steps to 85 ft/lbs and retorqued the next day...
When you retorque the next day, do you usually find they've backed off a little due to stretch? If so, approx. how much?
flycaster is offline   Reply With Quote
Old 03-07-2009, 02:29 PM   #14
MasterKwan
Member#: 98961
2003 WRX
You guys don't polish the threads? When I did the HG on my Type-R motor, I believe it was arp that suggested loosening them 90 degrees and tightening them again several times to polish the threads and get a more accurate torque reading. I know for the same torque, the stopping point on the torque wrench kept moving as I did this.
I assume you're using ARP stud lubricant when you do this (I think it's just assembly lube).
Old 03-07-2009, 07:38 PM   #15
cpunlamd
Member#: 151360
2007 STI RIP
CZ4A/R35
C O M E T I C
cpunlamd is offline   Reply With Quote
Old 03-08-2009, 03:41 AM   #16
Max Umbarger
Member#: 1112
2006 FXT
RBP
OK. I went with OEM. Like I said tho... ARP studs. I need to check my tune and make sure it isn't total chaos since I came from 6500' altitude 91 octane high output tune, into a low altitude 93 octane insanity tune (when I actually want a good reliable tune). I'm gonna check all of this. I don't want detonation to be a problem, granted I've never heard it on my FXT with an STi exhaust minus cats. Funny that I hear detonation on almost all American cars while I borrow them and they have quiet exhausts like my Forester...Who knows I only drive 'em while the FXT is down tho.
Old 03-08-2009, 04:45 AM   #17
DemiSlayer
Member#: 120339
02 WRX
Alliance Motor Sports
Originally Posted by cpunlamd View Post
C O M E T I C
Just to through it out there on my personal build i am running OEM head gasket. The engine is built to handle 1000whp and i have over 15grand into it.
all the true experts will recomend the stock head gaskets.
I am running a 74mm turbo with well over 40psi of boost.
DemiSlayer is offline   Reply With Quote
Old 03-08-2009, 10:48 PM   #18
Max Umbarger
Member#: 1112
2006 FXT
RBP
Dang! What's the problem with the failures then. At the assembly line?
Old 03-09-2009, 10:05 AM   #19
JMS Landshark
Member#: 48773
2004 TiC WRX
also '99 BMW M Roadster
I won't pretend to know the exact equipment or procedure in the Subaru plant, but I know what they do when building the engines where I work (off road OEM).
An operator takes prepped (lubricated) studs and puts them in place by hand. He then activates the automotied assembly which comes down with independantly mointored and torque controlled sockets which run down the studs overtorquing them to yield, then backing off 2 turns, then resetting proper torque on all studs simultaniosly.
Obviously, it is still possible to have some issues, but if Subaru runs an similar process, then I doubt they can be accused of just sloppy manufacturing. Is there a tiem period where head gaskets are suspect? Usually, issues like that show up in batches.
Anyone's favorite name brand gasket can fail given the right circumstance. I see cometic mentioned above, and its a good brand...but a friend blew 2 cometic head gastkets while doing a light break-in cycle on a motor built to handle 1200+hp.
JMS Landshark is offline   Reply With Quote
Old 03-09-2009, 01:41 PM   #20
Max Umbarger
Member#: 1112
2006 FXT
RBP
I understand. Tuning plays a big role as well. Granted there are many EJ25's around with no mods and the gaskets are failing.
Old 03-12-2009, 09:09 PM   #21
cpunlamd
Member#: 151360
2007 STI RIP
CZ4A/R35
C O M E T I C
Old 03-12-2009, 09:09 PM   #22
cpunlamd
Member#: 151360
2007 STI RIP
CZ4A/R35
Do it right the 1st time and remove all doubt.
Old 03-12-2009, 09:35 PM   #23
STimedic
Member#: 104765
02 STi :D
2011 PRP FXT T
(Comment held because I am not a "factory" 2.5L turbo powerplant)
(And no, the mods didn't insert that)
STimedic is offline   Reply With Quote
Old 03-12-2009, 11:45 PM   #24
Max Umbarger
Member#: 1112
2006 FXT
RBP
HaHa! STImedic. I've party'd it up in Fayettenam! I think the place was called Jumpers.
Old 03-13-2009, 11:00 AM   #25
JMS Landshark
Member#: 48773
2004 TiC WRX
C O M E T I C
You offer no redeeming value to this thread.
OEM head gasket vs. Aftermarket cooleys04 Built Motor Discussion 4 04-12-2009 10:52 PM
Recommendation of Head Gaskets islandboy78 Built Motor Discussion 12 01-09-2009 06:02 AM
Socal: Brand New STI oem head gasket set methaddict Engine/Power/Exhaust 2 10-11-2008 03:51 PM
Brand New STI 100mm oem head gasket set methaddict SCIC Private Classifieds 1 10-11-2008 03:50 PM
Recommend me a repair shop in Manassas for head gaskets please silver2004impreza Mid Atlantic Impreza Club -- MAIC 6 12-24-2007 12:02 PM
