Old 03-06-2009, 02:43 AM   #1
bugeye-brawler
Member#: 182337
1997 Impreza Outback
Sport -- White
Default Gas Tanks
Hey guys,
I am having a dilemma w/ the gas tank situation for my swap. I am swapping a 02-03 WRX into my '95 Legacy. My friend said to make it easier I can keep the Legacy gas tank, and wire the WRX harness to it. The problem is the sensors and off in my Legacy and the gas gauge gives me weird readings. So can I just remove the Legacy sensors and just add the WRX ones? will they fit? or do I have to swap over the WRX gas tank? would that be easier than messing with all the sensors?
-Thanks
Josh
bugeye-brawler is offline   Reply With Quote
Old 03-07-2009, 03:38 AM   #2
bugeye-brawler
Member#: 182337
Sport -- White
bump need help
Old 03-07-2009, 04:45 AM   #3
penusai
Member#: 102808
1995 v8 EJ207 v7 6sp
30r swap in progress
take them out and see if they look alike...
penusai is online now   Reply With Quote
Old 03-07-2009, 04:00 PM   #4
bugeye-brawler
Member#: 182337
Sport -- White
will I have to take the gas tank out to check the sensors or can I do it without removing the tank?
Old 03-08-2009, 01:57 AM   #5
Seraphinwolf
Member#: 150922
97 OBS EZ30R
94SVX LSi Bourduex Pearl
There's a cap in the trunk under the trunk liner on the flooring. You'll un bolt the I think it is 6 bolts and lift the cover and pump assembly. On and make sure to unplug the pump controler and run the car till it stalls out. That will clear out the fuel lines other than the return line.
-Gaddis
Seraphinwolf is offline   Reply With Quote
Old 03-09-2009, 01:14 PM   #6
bugeye-brawler
Member#: 182337
Sport -- White
Thanks I will try that...
Old 03-10-2009, 10:08 AM   #7
kirkdunkan
Member#: 205260
Thanks!
kirkdunkan is offline   Reply With Quote
Gas tank problem.. not able to get a full tank. Jim.mEh Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 52 03-23-2010 01:21 AM
FS: 2.5RS Gas tank with filler neck! perfect for smaller L tanks! scobaru MWSOC Private Classifieds 3 01-21-2007 07:56 PM
FS: 2.5RS Gas tank with filler neck! perfect for smaller L tanks! scobaru Drivetrain 0 01-18-2007 03:25 PM
2006 Impreza gas tank fill - fuel tank filler neck problems. Psybin Warranty Issues & SOA Problems 11 01-08-2007 09:48 PM
gas and gas tank question amorenite95 Normally Aspirated Powertrain 5 03-27-2002 02:18 PM
