Go Back   NASIOC > NASIOC Chapters > New England Impreza Club Forum -- NESIC
Old 03-06-2009, 10:56 AM   #1
DNut
Member#: 151739
Default Delta cams and emissions testing in MA
Anyone here running either the Delta 1000 or 2000 cams in their EJ25?
I’m debating the 1000 vs 2000 grind for my DD, and I’m curious to see if anyone had any problems passing emissions with either of these due to a CEL being thrown from the ECU thinking that the engine is misfiring.
I was thinking that the 1000 would be the way to go because of a lesser chance of a CEL occurring, but if the CEL isn’t too frequent with the 2000s then I might look into getting those instead.
(Yes, I know that there are a ton of threads about this in the NA section, but I’m interested in seeing how guys local to me have gotten around this problem come time for emissions)
DNut is offline   Reply With Quote
Old 03-06-2009, 11:16 AM   #2
SubyMass
Member#: 136493
2015 WRX
GBP
No personal experience here but here are my thoughts.
MA inspection should only be limited to no CEL's being present and visual inspections. With that said, just make sure you dont have a CEL.
I assume the CEL is thrown due to rough idle. Could you temporarily bump up the target idle in order to do this? Once you have your sticker, reset to wherever you want.
SubyMass is offline   Reply With Quote
Old 03-06-2009, 11:30 AM   #3
DNut
Member#: 151739
Yeah, I can bump up the idle, but it's only a temp fix that will go away if the ECU is every reset, such as if I need to reset a code.
I'm going to look more into it and decide from there. I think that I may go with the 2000s after talking to a couple of guys on rs25 in a similar thread I started on that forum.
Old 03-06-2009, 01:16 PM   #4
bigbrakeparts
Member#: 204133
02 WRX
I have 282 Crower Stage 3 in a 2005 WRX built head on a v8 spec c block.
The idle is like a V8, but no CEL.
Just make sure all your readyness tests work and no CEL, you will be all set.
Where are you located?
-G
bigbrakeparts is offline   Reply With Quote
Old 03-06-2009, 01:19 PM   #5
DNut
Member#: 151739
-G
Nothing wrong with idling like a V8; my toy car is a V8 and its got a decent lope to the idle. Its more the threat of almost constant CELs that Im worried about.
I think I'm going to go for the more aggressive cams after looking into it more. Might as well do it right the first time.
Passing the NEW required OBDII Emissions test in PA Questions and Answers!! mrtrex Mid Atlantic Impreza Club -- MAIC 29 03-10-2013 07:23 PM
delta cams and mis fires. aclver1 Normally Aspirated Powertrain 86 04-09-2009 10:56 AM
Catless UP and DP and emissions testing in PA mgoss79 Mid Atlantic Impreza Club -- MAIC 13 02-12-2008 09:18 AM
Question on downpipe and emissions testing in NY CletusTheDwarf Tri-State Area Forum 3 03-30-2007 10:24 AM
AP and emission testing in MA dougkmcse Engine Management & Tuning 4 06-10-2005 10:12 PM
