Old 03-06-2009, 12:19 PM   #1
abgusaf
Member#: 143122
07 WRB STi
in the werks
Default P1312 and P1420?
Got a CEL and went to autozone to have them read. Threw these two codes and not sure excactly what it would be. I did a search and the P1312 came up seems like most people would just clear them and it wouldnt come back, but i couldnt find any solutions to the P1420. Car still runs fine doesnt seem like anythings wrong. Just wanted to make sure. I tried to have her clear the code to see if it would come back but apperently its illegal for them to clear it idk
P1312 - Exhaust Temp sensor malfunction
P1420 - Fuel tank pressure control solenoid high input
What do you guys think?
abgusaf is offline   Reply With Quote
Old 03-06-2009, 12:25 PM   #2
abgusaf
Member#: 143122
07 WRB STi
in the werks
Just in case you want a mod list
Header
Uppipe
VF22
TBE
800cc modded injectors
STi intercooler
Meth
Cold air
Old 03-06-2009, 02:15 PM   #3
abgusaf
Member#: 143122
07 WRB STi
in the werks
anyone?
Old 03-10-2009, 04:17 AM   #4
abgusaf
Member#: 143122
07 WRB STi
in the werks
bump/
I cleared it and it came back on
Old 03-10-2009, 04:54 AM   #5
eMoneyyy
Member#: 200680
2002 W R X
Rally Blue
Your EGT sensor is very important, and if it was burnt out, you would get the malfunction code. Soon your car will enter limp mode and will barely run. Watch out it doesnt happen when your far from home.
The other code I dont know, Ive never had it.
If your EGT sensor is ok, then you need to clean your MAF and make sure its installed correctly.
eMoneyyy is offline   Reply With Quote
Old 03-10-2009, 04:56 AM   #6
eMoneyyy
Member#: 200680
2002 W R X
Rally Blue
I did however notice your upgrades, which means your probably tuned which would eliminate any EGT codes as you do not have any cats... or do you?
Ask your tuner if he elimnates EGT codes.. check the wires coming off the EGT to see if it has melted anywhere.
Old 03-10-2009, 05:11 AM   #7
abgusaf
Member#: 143122
07 WRB STi
in the werks
No cats at all, i checked the probe the other day and didnt notice any melted wires
Im wondering maybe if it could be spark plugs, ill be honest i havent changed them in a while and just read meth eats spark plugs apperently idk?
I think im going to do that 2.2ohm resistor mod to the egt probe to eliminate it all together,
Old 03-10-2009, 01:17 PM   #8
abgusaf
Member#: 143122
07 WRB STi
in the werks
anyone else with any input
P1312 - Exhaust Temp. Sensor Malfunction Kenneth2000 Warranty Issues & SOA Problems 9 08-31-2012 11:24 PM
cel p1312 Azjon Bay Area Impreza Club Forum -- BAIC 4 12-29-2003 02:29 AM
P0546 and P1312 CEL? wrx2 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 06-15-2003 10:40 AM
what is a P1312 CEL code? juztin180 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 01-04-2003 07:10 PM
got P0546 and P1312 CEL!!! help! SilverWRX02 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 09-14-2002 01:47 AM
