Old 03-06-2009, 07:05 PM   #1
Meat Supply
Member#: 137902
---- so good
it sucks....
Default will the oil pan from a 1.8L fit....
on a 2.2LT? mine has a tiny rust hole in it. why didn't it leak when it was at the lot? who knows. probably snake oil. anyway if any of you know i'd apreciate it. later....
Meat Supply is offline   Reply With Quote
Old 03-07-2009, 11:59 AM   #2
Meat Supply
Member#: 137902
---- so good
it sucks....
really? no takers :sadface:
Old 03-07-2009, 12:48 PM   #3
RP31
Member#: 123574
2005 2.6L 9:1 425WHP
CGM STi
This should probably be in a technical forum.
And yes there's a thread preview feature, but nobody likes it when you leave 3 words out of the subject and instead choose to end it with '...'
RP31 is offline   Reply With Quote
Old 03-07-2009, 05:21 PM   #4
Meat Supply
Member#: 137902
---- so good
it sucks....
well, i would've but they're less frequented. well i wire wheeled the suspect area and jbwelded it by recommendation so we'll see how that goes. thanks anyway
Old 03-08-2009, 11:43 AM   #5
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
probably would fit .. you would need the 1.8 pick up as well
iirc the 1.8 pan has a smaller volume
Old 03-08-2009, 07:19 PM   #6
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Correct. You need the Ej18 pickup and it's about 1/2qt smaller volume.
Old 03-10-2009, 07:32 PM   #7
Meat Supply
Member#: 137902
---- so good
it sucks....
thanks but it looks like the jb weld is holding on! yay me!
Old 03-11-2009, 09:30 AM   #8
leftho0k
Member#: 177589
i say it will fit, but you will want to swap the sump pickup and check the oil level before starting. if you want a turbo oil pan i have one off a 93 ej22turbo i will part with. g/l
leftho0k is offline   Reply With Quote
Will the top hat from a sedan fit a wagon in the rear? ever12 Newbies & FAQs 4 02-18-2009 02:50 AM
How does the oil drain to the oil pan? msm98lw Newbies & FAQs 6 10-29-2005 12:05 AM
How do you separate the oil pan from the block? jasona Normally Aspirated Powertrain 16 10-06-2005 04:54 PM
Will the instrument cluster from 2dr. 2.5RS fit a '98 OBS? RootUsr Electrical & Lighting 3 06-27-2005 09:01 PM
Will the turbo manifold from a 2.2 fit a 2.5RS??? Xscreamer Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 06-10-2001 08:13 PM
