Go Back   NASIOC > NASIOC General > Motorsports > Autocross
Old 03-06-2009, 08:15 PM   #1
JamesWilson2
ForumWars Winner!
Member#: 196948
2003 Forester
Thumbs down Stock/ST fuel rule and new Shell Nitrogen Gasoline
So I've been doing a little bit of research, and turns out per the current wording of SCCA Solo Rule 3.6A, Shell Gasoline that contains Nitrogen is not currently legal.
Here is the press release on the new gas, which is now in all grades of their fuel-- http://www.marketwatch.com/news/stor...EC}&dist=msr_5
Here is the wording from the 2009 rulebook regarding 3.6A and 3.6B. Note that the Shell gasoline with Nitrogen is only legal in SP, SM, P, and M classes--
"3.6 FUEL
A. Stock and Street Touring Class vehicles will use service station
pump fuel only. Pump fuel is defined as that which is “Federally
approved for use on public highways.” This includes the pump
fuel known as “E85", but does not allow racing-type fuels which
are available at service station pumps.
B. In addition to fuels which are allowed by 3.6.A, Street Prepared,
Street Modified, Prepared, and Modified class vehicles may use
diesel fuel or any grade of gasoline. Gasolines consist entirely of
hydrocarbon compounds. Gasoline may contain antioxidants,
metal deactivators, corrosion inhibitors and lead alkyl compounds
such as tetraethyl lead. Oxygen and/or nitrogen bearing additives
are prohibited, except for those originally present in service
station pump fuel.
Oxygen and/or nitrogen bearing oil additives
are prohibited in two-cycle engine oiling systems."
For the new fuel to be legal, SCCA has to issue an update to FasTrack to allow the provision of 3.6B to be contained in 3.6A for Stock and ST. Until that time, technically it is illegal. With everyone spending hundreds of postings and nit-picking about the size of a hole drilled for a shock reservoir, and things like that that that do not affect performance, hopefully the SEB will quickly address this to prevent "issues".
Carry on!
JamesWilson2 is offline   Reply With Quote
Old 03-06-2009, 08:38 PM   #2
grippgoat
Member#: 62182
2005 STI
It seems pretty clear to me that if it's federally approved for use on public highways, it's legal. Section B says "In addition to fuels which are allowed by A, ....". A stands on its own, by my interpretation. I'm assuming Shell wouldn't be selling fuel that's not federally approved...
-Mike
grippgoat is offline   Reply With Quote
Old 03-06-2009, 08:41 PM   #3
JamesWilson2
ForumWars Winner!
Member#: 196948
2003 Forester
Right, but the additional wording in B would seem unnecessary if all of the provisions of A were met, correct? And if the additional wording of B is B-specific for those classes, then as it is not listed in A, it is therefor not allowed in A. Right?
I took logic in college, same class twice...not because I wanted to. Just help me think it through. haha
Section A says I can run gasoline, but not race gas. Doesn't say I cannot run Nitrogen, but SCCA's rules are pretty-- "unless is says you CAN, you can't".
Section B says I can run gasoline, and run gasoline with Nitrogen. Says I can specifically, so I can = SCCA happy. But only in SP/SM/P/Mod.
Right?
Old 03-06-2009, 09:24 PM   #4
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
this is easy
This morning at Shell stations across the U.S., consumers received a free fill-up with Shell Nitrogen
station pump fuel
now since Shell is reformulating all its 'pump' fuels....it HAS to be legal
Old 03-06-2009, 10:56 PM   #5
grippgoat
Member#: 62182
2005 STI
Right?
A is A, period. Nothing in B impacts A. The highlighted statement in B just says "you can't add this kind of additive, but it's allowed if it was there from the pump". There doesn't need to be wording like that for A, because all you can do under A is take gas from the pump.
-Mike
Old 03-07-2009, 10:48 AM   #6
rjrutzky
Member#: 30367
2005 Legacy GT
NASA SE PTB Champ
Does SCCA really do fuel testing for SOLO? I wouldn't think there would be a budget for that.
rjrutzky is offline   Reply With Quote
Old 03-07-2009, 12:26 PM   #7
68Cadillac
Member#: 95901
Gives me an evil idea though.
Show up with legal fuel in white 5 gallon jugs with "racing fuel" written on them. While the competition is around fill up your car up while wearing a chemist smock, chem-resistant gloves, eye protection, and an air filter/respirator.
68Cadillac is offline   Reply With Quote
Old 03-07-2009, 02:29 PM   #8
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
-Mike
Concur with Mike. Your logic class(es) apparently didn't take. You're trying way to hard to read into this, James.
"3.6 FUEL
Shell sells service station pump fuel. Service station pump fuel is legal in Stock and Street Touring classes (and every other class, for that matter). End of story.
Pat Olsen
Old 03-07-2009, 06:48 PM   #9
Boxologist
Member#: 21118
its reads a legal. anything from a legit pump is OK. Shell is selling it to the public so u are good to go.
Boxologist is offline   Reply With Quote
Old 03-07-2009, 07:28 PM   #10
JamesWilson2
ForumWars Winner!
Member#: 196948
2003 Forester
Cool. Just did not want to unknowingly use something that is not approved.
Old 03-08-2009, 05:43 PM   #11
KC
Member#: 442
16 SS
00 S2000
James, also the latest fastrack has a reminder:
With regard to fuel, additives such as MTBE, ethanol, and methanol are considered to meet the requirement of 3.6.B, which states that such additives are only permitted if they are ones which are found in service station pump fuel as defined in 3.6.A.
(ref. 08-725)
--kC
KC is offline   Reply With Quote
Old 03-08-2009, 08:15 PM   #12
Illini_STi
Member#: 70634
This is no big deal, as gasoline has had nitrogen in the detergent additives for decades now. All detergents have an amine group, which by definition, have nitrogen.
Illini_STi is offline   Reply With Quote
Old 03-23-2009, 08:51 PM   #13
GullyWagon07
Member#: 164171
08 EvoX <3 Wagon
rear prodrive plate frame
^^ so nitrogen doesn't affect the car/tune/map in any way?
GullyWagon07 is offline   Reply With Quote
Old 03-23-2009, 09:53 PM   #14
digitalseance
Member#: 104400
169k mile race car
Well....ya know.... turbo blue (100oct unleaded) is sold "at the pump" all over the nation...
would that be legal fuel for S and ST??
but does not allow racing-type fuels which are available at service station pumps
I guess not...
but...
how does one know? TB doesn't smell like my 116 leaded go-juice does...
digitalseance is offline   Reply With Quote
Old 03-24-2009, 12:56 PM   #15
Illini_STi
Member#: 70634
No, your car was tuned with fuel that had nitrogen in it. Unless it was on avgas or something like that. Not sure if the racing fuels have detergents, but I would guess they would.
Old 03-24-2009, 01:22 PM   #16
JamesWilson2
ForumWars Winner!
Member#: 196948
2003 Forester
FWIW, the DS WRX was very very very happy on 30% blended E85 and the rest 93 octane pump gas
FS (NH): Stock STI fuel pump and stock 6 disk cd changer darkinc NESIC Private Classifieds 3 06-10-2010 02:17 PM
FS: Stock STI Fuel Pump very new JD_STI Engine/Power/Exhaust 2 07-24-2007 02:14 PM
Stock WRX fuel Pump and uppipe and downpipe subymanny04 Private 'For Sale' Classifieds 0 05-12-2006 11:14 AM
FS; stock WRX fuel injectors and pump Big Joe Private 'For Sale' Classifieds 1 11-23-2005 01:31 AM
FS: stock WRX fuel injectors and pump RussB Bay Area Impreza Club Forum -- BAIC 1 03-22-2004 10:39 PM
