#76 | |
Member#: 78165
South East
Vehicle:05 STI 35r + e85 |
Not a lot of work was done to the heads, but whatever was done seems to have worked. Here are some pics: http://aftracingheads.com/project6.htmlI know they got pics when the uppipe was off the car for the v-band flange, I just emailed the shop owner asking for pics... should have them soon.
#77 |
Member#: 194804
International
Vehicle:2004 VF43 WRX - sold WRB |
Crazy numbers good job man wow
#78 |
Member#: 104200
Vehicle:828 WHP BUGEYE Street Proven Performance |
#79 | |
Member#: 104200
#80 | |
Member#: 56945
Vehicle:08 STI Base Model Black |
I have used and tested 8-10 turbo cams on a F.I BMW which again SUPPOSEDLY supposed to pick up power and torque, guess what it may have shifted the power and up a bit due to the duration but the stock cams have been tested in house to produce 996 whp.. a non turbo camshaft. It's basically all about the combination, we actually made 655whp on a piston and rod engine, stock heads again mild port and polish, heavy duty valves, springs retainers on pump gas and methanol, simple set-up EJ257 Engine. The moral of the theory is that bigger is not always better... i some cases it is. ![]() But not with forced induction applications at times, hence the air is being forced in by some type of charging. Great numbers anyhow. ![]() -George Kakaletris |
#81 | |
Member#: 129631
Vehicle:06 Obp Sti back to slow lolz |
Awesome man, I would appreciate it. Ive been meaning to do something along the lines of what you did, I'm tired of replacing gaskets every few weeks. ![]() -Vic |
#82 | |
Member#: 108051
Vehicle:2005 TickingTimeBomb Jr tuned TT Sleeved |
I feel some of your info is correct. But not all of it. Again as stated the car is out of turbo. If he had a 1.06a/r hot side with a 3" outlet and possibly a T4 housing I'm sure it would make 650 or more. You say the head's are mild P&P have any pictures I'd like to see them. ![]() But not that that matter's Al Jr Tuned car's perform at the track and that's what most of us care about. I could care less if I built my motor and made 550whp as long as I'm running 10.40 or better at 135mph. I'd like to see what this car your talking about run's at the track. The one that made 650whp one piston and rod's with stock head's. I think P&P and Cam's and bigger valves is a bit much for a turbo this size. But Jay has the right idea of .5 mm over sized valves mild P&P and cam's. Anyway's enough high jerking lol. Good job Jr and Jay. I seen the you tube vid's and that thing rip's. Perfect daily driver. Should easily see mid 10's and 130mph+ traps. BTW what size pistons are in the car? How do you feel it will hold up? I wanted to do sleeves but I am hurting for cash right now. The girlfriends got a lot of wishes and in my book she comes first. |
#83 | |
Member#: 108051
I get a slight clunk when i hit the gas and let off but it sound to be coming more from the tail shaft of the transmission viscus coupler maybe? Idk I'm gonna let it ride out and see what happens if it breaks then I'll just do 1-4 PPG's 5th and 6th high speed syncro gear's. |
#84 |
Member#: 78165
South East
I don't DD my STI and it gets treated well. I beat on it much less than I would a 300-400whp car. The pump gas map is retartedly fast and very loud and there aren't many situations on the street where it is wise or safe to unleash it. So I think that will help with longevity compared to somebody that gets a built block and beats the **** out of it every day.
I agree with George that more is not always better with headwork. I got a good price on the headwork that was done and I think we got the max effect for the min effort and cost. I still don't have the uppipe pics, when I go pick my car up in a day or two I will nag them about the pics again. |
#85 | |
Member#: 108051
Yea once you have over 500whp it's like you mature a lot you realize that it's no longer a toy. And you must keep thing civil on the street. In most situations lol. Mind if I ask how much you spent on doing just the block and head's all together. I'm just trying to get some Ideas if I want to do sleeves or not. Because I will be very happy with 650whp or so. How much boost did Ron say the motor can handle? |
#86 |
Member#: 120100
South East
Vehicle:2004 WRX stage 2 Soon to be vf43'd |
#87 |
Member#: 108051
#88 |
Member#: 84482
Vehicle:2005 STI.UR gt4088r E85 pro comp sti |
#89 | |
Member#: 78165
South East
For the block it's hard to say how much I spent because it has been pulled apart and put back together a couple times before I started dealing with Ron. The block has been resurfaced twice, the heads 2-3 times, and it's been honed 3x now. The cost of rework really adds up. 27-28psi and 77-7800 were the limits that Ron and I discussed for this motor. So I had Junior stay within those parameters. Boost is just a measure of a restriction, this setup flows like crazy and I think the custom FMIC is helping a lot with that. |
#90 | |
Member#: 104200
#91 |
Member#: 156268
Vehicle:2011 WRX 5 Door Satin White Pearl |
I don't miss my built motor STI one bit
#92 | |
Member#: 109948
Vehicle:. Most famous car on Nasioc ever. :/ |
![]() No worries bro! If you piece it together, try russel or earls fittings. What core does Jay have again? 24.5x10x3.5? Damn, I want that one, but instead I just got the full-race one for 750hp 24.5x10x3 Last edited by D Money; 04-03-2009 at 11:50 AM. |
#93 | |
Member#: 78165
South East
I can't believe you spent all that money then sold the thing. Could have just replaced the motor with another stocker.
The IC piping that Synapse made me is all 3" ID, there are no sharp bends or pie cuts, and the IC endtanks are also 3" in/out. I think this FMIC could handle a 42r no problem. |
#94 |
Member#: 109948
yeah that's a beast ass core. lol
#95 | |
Member#: 108051
#96 |
Member#: 78165
South East
I PM'd you the details. What I will say here is it didn't cost any more than your typical (non-ebay) fmic kit. The core we used fits great, the top of the bumper cover sits right on top of it and the bottom of the core is flush with the lip. 2.75" hotside IC piping might be less laggy with little impact on power. I noticed more lag compared to my old SSAC FMIC but the FFS completely negates it.
Lebanon Valley Dragway opening day is two weeks away on April 18, I'm gonna try for 10s on 93oct next. The pump gas map is potent and I wouldn't be surprised if it trapped 128mph or so. Especially after I remove the rear bumper beam and passenger seat ![]() |
#97 |
Member#: 77470
Vehicle:04 sti 10.51@138.5 on e85@ 30psi--spinning |
with the power you made on pump you should be real close to 10.90's on pure pump,it will just take a lot of practice and great driving.Good luck let me know how it goes.
#98 |
Member#: 195623
Vehicle:2002 WRX STi swapped Built, PTE5830, PSM |
Subscribed Jay. Looking good!
#99 |
Member#: 109424
International
Vehicle:06 AW STI TS HTA 3076r 436hp/426tq |
i want it so bad, im jealous. great setup bro.
#100 |
Member#: 108051
Soon the track will be open. Can't wait to see what she run's.
| Thread Tools | |
| Display Modes | |
| Exhaust drone, vent holes in the trunk, and sound absorption ... need input | Hokie-wrx wagon | Interior & Exterior Modification | 12 | 02-27-2013 06:10 PM |
| Do I need more turbo fluid? | MtnMedic | Factory 2.0L Turbo Powertrain | 10 | 12-28-2004 01:51 AM |
| What Gauges and Piggy backs needed for Turbo? | yebokmj | Normally Aspirated Powertrain | 4 | 10-25-2000 01:16 PM |
