Old 03-07-2009, 12:37 AM   #1
CHEWY911
Member#: 179450
2004 WRX
Default oem STi rods in built EJ205
Quick question, can I use oem STi rods in my ej205 even if I decide not to do a stroked build. I was going to use Manley or Wiseco pistons and new oem crank.
Thanks!
CHEWY911 is offline   Reply With Quote
Old 03-07-2009, 02:08 AM   #2
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
1994 BC4, 2015 Outback
Yes you can.
Marnix is offline   Reply With Quote
Old 03-07-2009, 02:21 AM   #3
ADAS1223
Member#: 159853
2005 Impreza
wrb
I have these, and JE pistons in mine if that answers your question
ADAS1223 is offline   Reply With Quote
Old 03-07-2009, 02:38 AM   #4
CHEWY911
Member#: 179450
2004 WRX
I wonder why in this chart it indicates STi rods are 1mm shorter? Is this just the physical rod itself, and not the centerline of the big and small end?
Sorry for the questions. Just want to confirm before I start buying parts for my build.
http://www.importperformanceparts.ne...ns_subaru.html
Old 03-07-2009, 07:05 AM   #5
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
EJ205 and EJ255/7 rods are 130.5 mm, the EJ251/2/3 rids are 1 mm longer.
Old 03-07-2009, 08:06 AM   #6
Astartes
Member#: 183813
2006 WRX TR OBP
WRX STi SGM
Is that for compression purposes in NA cars? Just curious.
Astartes is offline   Reply With Quote
Old 11-06-2009, 02:18 PM   #7
Blubullt02
Member#: 221344
2002 impreza wrx
wrx rally blue
btw, I looked it up, AND measured, and ej205 rods are 5.135, and ej257 rods are 5.180.... big difference...
Blubullt02 is offline   Reply With Quote
Old 11-06-2009, 02:20 PM   #8
Blubullt02
Member#: 221344
2002 impreza wrx
wrx rally blue
so you COULD use them, but you need custom pistons
Old 11-06-2009, 03:13 PM   #9
CKxx
Member#: 33458
Your BOV sounds lame
93 RX7+09 Forester
Interesting...
A lot of rods mfgrs list both EJ20 and EJ25(STi) for the same rods.
CKxx is offline   Reply With Quote
Old 11-06-2009, 06:10 PM   #10
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Oil Dry Sump Goodness
Many answered this in one of the other Rod vs Rod threads just now. Here it is again
New 2L/2.5L rods are 5.135" long. The rods that measure 5.180" were all for the older blocks with 48mm rod journals, meaning phase 1 crank.
Get rods to match your crank. A phase 1 with 48 mm rod journal = 5.180" and a Phase 2 with 52mm journal = 5.135"
mick_the_ginge is offline   Reply With Quote
Old 11-08-2009, 10:14 PM   #11
preza95
Member#: 229407
1995 Impreza ???
red
may want to consider using aftermarket rods that are forged such as the ones Scat offers,especially if you plan on run the car at higher rpms. Also if should take away the headache of measurements,since you're not planning to do a stroker kit
preza95 is offline   Reply With Quote
WTB: ej207 RA or JDM STi heads (or built ej205 heads) saab-on-the-cobb Private 'Wanted' Classifieds 6 03-11-2011 08:20 PM
New style OEM STI rod bearings. Devan M Built Motor Discussion 0 04-10-2008 02:24 PM
FS: OEM STI Rods, Pistons, and Cams Evil Imports Engine/Power/Exhaust 18 04-03-2008 05:04 PM
FS VA:04 OEM STI Rods and Pistons,Perrin Lightweight Crank Pulley billy720 MAIC Private Classifieds 4 06-05-2007 02:09 PM
OEM STI rods Starkiller Built Motor Discussion 0 03-16-2007 05:35 PM
