#1 |
Member#: 151683
AIRBOY ADDED!!
Location: Baltimore MD Ambient Temp: 50ish Elevation: ??? Weather: Overcast, cool Tires: Proxes4 Car: 2007 STI Tuner: Hill @ Agile Dyno Info: Dynapack Transmission: 6spd Gear: 4th Peak HP at RPM: 318 @ 5500 rpm Peak Torque at RPM: 345 @ 3900 rpm Baseline hp/tq for a stock on same dyno: 240ish Target Boost: 21psi Target AFR: ?? Fuel: 93 pump Engine/Power Modifications: *SPT short ram+heatshield *Helix Catted DP *Greddy Ti-C *Accessport 2.0 *Stock motor/clutch ![]() Car has 79k miles now, got tuned at 43k... **ADDED 2 quick logs** 2nd gear Code:
(sec) (RPM) (load) (DAM) Adv.(deg)Ign. (deg)PSI WG(%) (V) (Long) (%) 0 3729 0.42 1 49.5 0 -8.85 0.78 2.26 -1.56 0.24 3768 0.56 1 49 0 -6.96 3.14 2.66 -2.34 0.46 3882 1.46 1 29.5 3 2.18 56.06 3.42 -2.34 0.7 3995 1.98 1 18.5 3.5 7.98 61.15 3.84 -2.34 0.92 4163 2.98 1 15.5 4.5 16.97 61.94 4.36 -2.34 1.16 4380 3.32 1 16 4.5 20.74 62.72 4.44 -2.34 1.39 4602 3.29 1 16 4.5 20.88 63.9 4.5 -2.34 1.61 4855 3.23 1 17 4.5 20.3 65.46 4.54 -2.34 1.83 5093 3.17 1 16.5 4.5 19.43 66.64 4.56 -2.34 2.07 5250 3.1 1 16.5 4.5 18.42 68.21 4.58 -2.34 2.31 5508 3 1 17 4.5 17.55 69.78 4.6 -2.34 2.56 5639 2.92 1 16 4 16.97 70.56 4.6 -2.34 2.8 5837 2.84 1 15 4 16.68 71.74 4.6 -2.34 3.03 6015 2.77 1 15 4 16.39 72.52 4.6 -2.34 3.29 6130 2.71 1 16 3.5 15.95 72.52 4.62 -2.34 3.53 6273 2.66 1 17 3.5 15.52 72.52 4.6 -2.34 Code:
(sec) (RPM)(load)(DAM)Ignition Adv. (deg)Learned Ign. (deg)(PSI) Wastegate Duty (%)(V)(Long) (%) 0 2749 1.45 1 19.5 2 2.32 61.94 3.08 -2.34 0.24 2958 1.76 1 17.5 3 4.79 59.58 3.36 -2.34 0.48 3225 2.2 1 13 3.5 8.85 58.41 3.7 -2.34 0.72 3522 2.99 1 12 4.5 15.52 59.19 4.1 -2.34 0.94 3932 3.32 1 14.5 4.5 20.45 58.8 4.28 -2.34 1.18 4411 3.25 1 16 4.5 20.45 62.33 4.42 -2.34 1.42 4848 3.2 1 15.5 4.5 20.01 65.07 4.52 -2.34 1.66 5254 3.1 1 16.5 4.5 18.42 67.82 4.58 -2.34 1.9 5624 2.93 1 16 4 16.97 69.78 4.58 -2.34 2.13 5990 2.75 1 17 3.5 15.95 72.91 4.6 -2.34 2.35 6274 2.61 1 18.5 3.5 15.23 72.91 4.6 -2.34 ![]()
#2 |
Member#: 128389
Vehicle:2006 impreza wrx steel gray |
what did it make?
#3 |
Member#: 171773
South East
Vehicle:04 wrx sti jbp dom 3 xtr w meth! |
hmm 280-290 is my guess
#4 |
Member#: 185106
RMIC
Vehicle:2006 Subaru WRX WRB Mazda protege' |
failsssss
#5 |
Member#: 151683
318whp (5500) + 345wtq (3900rpm) i'll get the graph up sooner or later... Hill said "this thing's a monster" ![]() Thanks again to Agile for the great work! We'll definately be back! |
#6 |
Member#: 2468
South East
Vehicle:08 Audi RS 4 05 AW STi |
^ fun stuff!
How does the car drive? Smoother? |
#7 |
Member#: 151683
the car is running awsome and smooth as butter...
here's a log of 1st through 3rd, not quite all out.. (sec)(RPM)(load)(DAM)(Adv.deg)(Ign.deg)(PSI)(WGDC% )(MAF V) 0.00 3078 0.60 1.00 47.50 0.00 -6.82 1.96 2.40 0.22 3367 1.08 1.00 36.50 1.00 -0.87 10.58 3.14 0.48 3639 1.72 1.00 24.00 4.50 3.19 59.98 3.54 0.69 4332 2.40 1.00 17.00 3.00 9.14 63.11 4.18 0.93 5112 3.14 1.00 19.50 4.50 16.68 67.03 4.60 1.15 5874 2.91 1.00 20.00 4.00 15.95 72.91 4.66 1.37 6581 2.59 1.00 24.50 4.00 14.36 73.30 4.68 1.59 6329 0.99 1.00 -8.00 0.00 -4.93 0.00 2.54 1.80 5897 0.14 1.00 9.00 0.00 -11.02 0.00 1.88 2.02 5272 0.91 1.00 36.00 0.00 -0.73 10.98 3.80 2.23 4797 2.23 1.00 -1.00 3.50 7.98 65.07 4.24 2.44 4934 3.21 1.00 11.50 4.50 17.40 65.86 4.58 2.69 5281 3.18 1.00 19.50 4.50 17.98 68.60 4.64 2.91 5652 2.99 1.00 20.00 4.00 16.68 70.95 4.64 3.11 5990 2.82 1.00 20.50 4.00 15.95 73.30 4.64 3.33 6305 2.69 1.00 22.50 3.50 15.23 73.70 4.68 3.55 6563 2.58 1.00 24.50 4.00 14.79 72.91 4.64 3.78 6874 2.45 1.00 26.50 2.50 11.17 21.95 4.10 4.00 6079 0.21 1.00 9.00 0.00 -9.14 0.00 1.82 4.21 5625 0.29 1.00 34.50 0.00 -9.14 5.88 3.06 4.42 4940 2.00 1.00 20.50 4.00 6.09 66.25 4.16 4.67 4929 3.10 1.00 15.50 4.50 16.68 66.25 4.56 4.89 5099 3.26 1.00 16.50 4.50 19.43 66.25 4.60 5.09 5260 3.19 1.00 16.50 4.50 18.71 68.60 4.64 5.31 5398 3.10 1.00 16.50 4.50 18.13 69.38 4.64 5.53 5572 3.02 1.00 17.50 4.00 17.55 70.56 4.66 5.76 5727 2.95 1.00 17.50 4.00 17.11 71.74 4.66 5.98 5863 2.88 1.00 18.00 4.00 16.82 72.13 4.66 6.19 6001 2.81 1.00 18.50 4.00 16.39 73.30 4.66 6.40 6103 2.76 1.00 19.00 4.00 16.24 73.30 4.68 6.65 6255 2.72 1.00 20.50 3.50 15.95 73.30 4.68 6.87 6381 2.65 1.00 21.00 3.50 15.66 72.91 4.68 7.07 6500 2.61 1.00 22.00 3.50 15.37 72.52 4.70 7.29 6625 2.56 1.00 23.00 4.00 15.37 72.52 4.68 7.51 6785 2.52 1.00 24.00 4.00 15.23 71.74 4.70 7.74 6893 2.48 1.00 24.50 4.00 15.08 68.60 4.72 7.96 6345 0.26 1.00 9.00 0.00 -8.41 0.00 2.04 8.17 6000 0.42 1.00 48.50 0.00 -7.40 18.82 3.58 8.39 5076 2.36 1.00 18.50 3.00 9.14 66.25 4.38 8.60 5181 3.17 1.00 19.50 4.50 17.98 67.42 4.64 8.82 5321 3.17 1.00 19.50 4.50 19.00 67.42 4.66 9.04 5365 3.13 1.00 18.50 4.50 18.71 67.82 4.66 9.26 5375 1.69 1.00 25.50 1.50 -0.58 0.00 2.94 9.48 5450 0.17 1.00 24.00 0.00 -10.88 0.00 1.90 9.71 5372 0.19 1.00 24.00 0.00 -11.46 0.00 1.98 9.93 5217 0.19 1.00 24.00 0.00 -11.46 0.00 1.98 does it look ok? sure feels good ![]() |
#8 |
Member#: 68647
Vehicle:07 STI Rotated 35R Jorge Tuned |
318awhp with a catted dp? Wow! What's this dyno rate a stock 07 at? Do you know what your boost tapers to in 4th?
Looks like a beast! |
#9 |
Member#: 110667
Vehicle:2006 WRX |
That's exactly where he should be with that set-up on Agile's dyno. Good numbers.
#10 |
Member#: 120187
South East
Vehicle:2005 STI Stage2.5 Obsidian Black Pearl |
Not sure if it's my noobness.... The MAFv looks high for that setup. Is it running rich?
#11 |
Member#: 143039
Vehicle:2007 STI Satin White Pearl |
Nice numbers man.
Log some Knock Correction and Knock Learning... |
#12 |
Member#: 116330
South East
Vehicle:2006 300C 5.7 Hemi Grandpa Gold. |
Post AFRs and knock correction?
sotc |
#13 |
Member#: 171773
South East
Do a straight 4th gear pull log from like 2500 rpms and do it until around 6500 rpms. That will be a lot better for us to look at the logs. Yea post knock correction and afr's.
#14 |
Member#: 151683
for some reason even when i was in the afr and knock sections to log, these are the parameters it saved..
(sec)(RPM)(load)(DAM)(Adv.deg)(Ign.deg)(PSI)(WGDC% )(MAFV)(Fuel Trim(Long) 0.00 2407 0.32 1.00 49.50 0.00 -9.86 0.00 1.88 -3.12 0.22 2412 0.40 1.00 49.50 0.00 -8.85 0.00 2.10 -3.12 0.44 2428 0.74 1.00 39.00 0.00 -5.22 7.06 2.56 -3.12 0.66 2439 1.27 1.00 20.50 1.50 0.29 64.29 2.86 -2.34 0.88 2473 1.43 1.00 22.50 3.00 1.45 64.68 2.96 -2.34 1.12 2529 1.61 1.00 21.50 3.50 2.76 63.50 3.02 -2.34 1.34 2554 1.81 1.00 19.00 4.50 4.35 62.72 3.16 -2.34 1.54 2622 1.99 1.00 16.00 4.50 5.95 61.54 3.28 -2.34 1.78 2668 2.19 1.00 15.00 4.50 7.83 60.76 3.34 -2.34 2.00 2736 2.46 1.00 11.00 4.00 10.15 58.80 3.52 -2.34 2.22 2836 2.78 1.00 11.50 4.50 13.20 58.02 3.80 -2.34 2.44 2902 3.11 1.00 10.00 4.50 16.82 57.62 4.10 -2.34 2.66 3010 3.37 1.00 10.00 4.50 19.14 56.45 3.86 -2.34 2.88 3098 3.52 1.00 9.50 4.50 20.45 53.31 3.84 -2.34 3.10 3203 3.55 1.00 10.50 4.50 20.45 52.92 4.10 -2.34 3.32 3302 3.48 1.00 11.00 4.50 20.59 54.88 4.30 -2.34 3.52 3417 3.54 1.00 11.50 4.50 20.59 56.06 4.12 -2.34 3.74 3491 3.57 1.00 12.00 4.50 21.17 56.45 4.18 -2.34 3.96 3589 3.56 1.00 13.00 4.50 21.17 56.84 4.28 -2.34 4.19 3710 3.55 1.00 13.00 4.50 20.88 57.23 4.26 -2.34 4.41 3816 3.53 1.00 14.00 4.50 20.88 57.62 4.30 -2.34 4.65 3928 3.51 1.00 14.50 4.50 20.88 58.02 4.38 -2.34 4.87 4026 3.50 1.00 15.00 4.50 21.03 58.41 4.34 -2.34 5.09 4122 3.46 1.00 14.50 4.50 20.88 58.80 4.42 -2.34 5.31 4213 3.49 1.00 15.00 4.50 20.88 59.19 4.46 -2.34 5.53 4326 3.49 1.00 16.00 4.50 20.88 59.58 4.48 -2.34 5.75 4406 3.47 1.00 16.50 4.50 20.88 59.98 4.50 -2.34 5.97 4518 3.49 1.00 16.50 4.50 20.74 60.76 4.54 -2.34 6.19 4608 3.46 1.00 17.00 4.50 20.88 61.15 4.56 -2.34 6.41 4703 3.44 1.00 17.00 4.50 20.74 61.54 4.58 -2.34 6.63 4793 3.45 1.00 16.00 4.50 20.59 61.94 4.60 -2.34 6.85 4845 3.41 1.00 16.00 4.50 20.45 62.33 4.62 -2.34 7.07 4835 1.84 1.00 27.50 2.50 0.87 0.00 2.56 -2.34 7.28 4712 0.20 1.00 9.00 0.00 -10.59 0.00 1.84 -3.12 7.50 4473 0.21 1.00 9.00 0.00 -11.31 0.00 1.92 -3.12 (sec)(RPM)(load)(DAM)(deg)(deg)(PSI),(WGDC%),MAF (V),Fuel Trim (Long) (%) 0.00,2236,1.08,1.00,21.50,0.50,0.00,33.32,2.66,-2.34 0.26,2250,1.27,1.00,20.50,2.00,0.87,72.91,2.76,-2.34 0.52,2290,1.39,1.00,25.00,3.50,2.03,72.13,2.82,-2.34 0.78,2348,1.51,1.00,25.00,5.00,3.05,70.17,2.92,-2.34 1.04,2385,1.66,1.00,21.00,5.00,4.35,68.21,2.96,-2.34 1.30,2466,1.86,1.00,17.50,5.00,5.66,66.25,3.10,-2.34 1.56,2527,2.03,1.00,14.50,4.50,7.11,65.46,3.18,-2.34 1.82,2615,2.20,1.00,13.50,4.50,8.85,64.29,3.34,-2.34 2.08,2672,2.45,1.00,12.50,4.50,11.02,62.72,3.48,-2.34 2.34,2767,2.69,1.00,12.00,4.50,13.63,61.15,3.68,-2.34 2.59,2852,3.05,1.00,11.00,4.50,16.82,59.58,3.88,-2.34 2.85,2962,3.26,1.00,10.50,4.50,19.14,57.62,4.18,-2.34 3.11,3065,3.41,1.00,10.50,4.50,18.71,58.02,4.18,-2.34 3.36,3204,3.43,1.00,11.50,4.50,20.01,57.23,4.20,-2.34 3.62,3310,3.42,1.00,11.50,4.50,20.30,57.62,4.12,-2.34 3.87,3430,3.45,1.00,12.50,4.50,20.74,57.23,4.12,-2.34 4.13,3527,3.47,1.00,12.50,4.50,20.88,58.41,4.14,-2.34 4.38,3630,3.45,1.00,13.00,4.50,20.74,58.41,4.16,-2.34 4.63,3762,3.43,1.00,14.00,4.50,20.74,58.80,4.24,-2.34 4.89,3873,3.41,1.00,14.50,4.50,20.59,59.19,4.30,-2.34 5.15,3952,3.41,1.00,15.00,4.50,20.74,59.58,4.34,-2.34 5.40,4113,3.38,1.00,14.50,4.50,20.74,59.98,4.36,-2.34 5.66,4225,3.38,1.00,15.00,4.50,20.74,60.76,4.40,-2.34 5.91,4316,3.41,1.00,15.50,4.50,20.74,61.54,4.46,-2.34 6.17,4418,3.41,1.00,16.50,4.50,20.74,61.54,4.48,-2.34 6.42,4528,3.40,1.00,16.50,4.50,20.59,62.33,4.50,-2.34 6.68,4648,3.40,1.00,17.00,4.50,20.74,62.72,4.54,-2.34 6.95,4749,3.37,1.00,17.00,4.50,20.45,63.11,4.54,-2.34 7.21,4834,3.36,1.00,16.50,4.50,20.45,64.29,4.58,-2.34 7.46,4937,3.32,1.00,16.50,4.50,20.16,64.68,4.58,-2.34 7.72,5037,3.29,1.00,17.00,4.50,19.72,65.46,4.60,-2.34 7.97,5145,3.24,1.00,17.50,4.50,19.14,66.25,4.64,-2.34 8.23,5273,3.19,1.00,18.00,4.50,18.85,66.64,4.66,-2.34 8.50,5363,3.14,1.00,18.00,4.50,18.56,67.42,4.66,-2.34 8.76,5427,3.10,1.00,18.00,4.50,18.27,68.21,4.68,-2.34 9.00,5523,3.05,1.00,17.00,4.50,17.84,68.60,4.66,-2.34 9.26,5606,3.01,1.00,17.00,4.00,17.69,69.38,4.66,-2.34 9.52,5680,2.95,1.00,17.00,4.00,17.40,69.78,4.68,-2.34 9.80,5814,2.92,1.00,16.00,4.00,17.26,70.56,4.68,-2.34 10.06,5858,2.88,1.00,16.50,4.00,17.11,70.95,4.68,-2.34 10.30,5967,2.85,1.00,16.50,4.00,16.82,71.34,4.66,-2.34 10.56,6051,2.81,1.00,16.50,4.00,16.82,71.74,4.68,-2.34 10.82,6076,2.78,1.00,17.50,4.00,16.68,71.74,4.70,-2.34 11.09,6196,2.75,1.00,18.00,3.50,16.39,71.74,4.70,-2.34 11.35,6256,2.70,1.00,18.50,3.50,16.39,71.74,4.70,-2.34 11.60,6320,2.69,1.00,18.50,3.50,9.72,37.24,4.22,-2.34 11.86,5834,0.17,1.00,9.00,0.00,-10.88,0.00,1.84,-3.91 12.11,5318,0.20,1.00,9.00,0.00,-11.46,0.00,2.00,-3.91 0.00,2301,0.32,1.00,47.50,0.00,-9.72,0.00,1.80,-3.91 0.25,2317,0.32,1.00,48.00,0.00,-9.57,0.00,1.84,-3.91 0.53,2312,0.35,1.00,48.00,0.00,-9.43,0.00,1.84,-3.91 0.79,2312,0.39,1.00,48.50,0.00,-8.56,0.00,2.08,-3.91 1.04,2338,0.71,1.00,38.50,0.00,-4.79,5.10,2.48,-3.91 1.29,2374,1.25,1.00,20.50,2.00,0.73,68.99,2.80,-2.34 1.55,2447,1.43,1.00,20.00,3.00,2.03,65.86,2.96,-2.34 1.81,2530,1.66,1.00,18.00,4.00,3.77,64.68,3.08,-2.34 2.06,2649,1.92,1.00,17.00,4.50,5.66,61.94,3.22,-2.34 2.31,2771,2.20,1.00,15.00,4.00,8.27,60.37,3.48,-2.34 2.57,2924,2.58,1.00,12.50,4.00,12.18,58.80,3.72,-2.34 2.83,3068,3.12,1.00,13.00,4.50,16.97,57.62,4.10,-2.34 3.08,3258,3.47,1.00,12.50,4.50,20.45,53.70,4.10,-2.34 3.33,3494,3.48,1.00,12.50,4.50,20.88,54.49,4.22,-2.34 3.59,3710,3.47,1.00,14.00,4.50,20.74,56.06,4.34,-2.34 3.85,3887,3.44,1.00,15.00,4.50,20.45,58.02,4.36,-2.34 4.10,4165,3.41,1.00,16.00,4.50,20.59,59.98,4.42,-2.34 4.36,4360,3.42,1.00,16.50,4.50,20.59,61.15,4.50,-2.34 4.61,4566,3.47,1.00,15.00,4.50,20.74,61.94,4.54,-2.34 4.86,4772,3.42,1.00,15.50,4.50,20.45,63.11,4.58,-2.34 5.12,4961,3.36,1.00,16.00,4.50,20.01,64.29,4.60,-2.34 5.38,5187,3.25,1.00,17.00,4.50,19.00,65.46,4.64,-2.34 5.63,5355,3.15,1.00,17.50,4.50,18.13,67.03,4.66,-2.34 5.89,5516,3.05,1.00,17.50,4.50,17.69,68.21,4.68,-2.34 6.14,5705,2.97,1.00,17.50,4.00,17.11,69.38,4.68,-2.34 6.40,5826,2.91,1.00,18.00,4.00,16.82,70.17,4.66,-2.34 6.65,6003,2.82,1.00,19.00,4.00,16.39,71.34,4.66,-2.34 6.90,6180,2.75,1.00,20.00,3.50,16.10,71.34,4.68,-2.34 7.16,6318,2.69,1.00,20.50,3.50,15.81,71.34,4.72,-2.34 7.42,6416,2.65,1.00,21.50,3.50,15.52,71.34,4.70,-2.34 7.67,6549,2.60,1.00,22.50,4.00,15.37,70.95,4.68,-2.34 7.93,6725,2.55,1.00,23.50,4.00,15.37,70.56,4.70,-2.34 8.17,6235,0.43,1.00,9.00,0.00,-8.70,0.00,1.88,-3.91 0.00,4006,1.22,1.00,36.00,2.00,0.29,23.91,3.34,-2.34 0.26,4129,1.88,1.00,21.50,4.00,5.66,60.76,3.82,-2.34 0.52,4444,3.08,1.00,17.50,4.50,15.81,62.33,4.46,-2.34 0.78,4833,3.41,1.00,18.50,4.50,19.87,64.29,4.62,-2.34 1.03,5260,3.21,1.00,20.00,4.50,18.13,67.03,4.66,-2.34 1.29,5670,3.00,1.00,20.00,4.00,16.82,69.78,4.66,-2.34 1.55,6077,2.83,1.00,21.00,4.00,15.81,71.74,4.66,-2.34 1.81,6416,2.66,1.00,23.50,3.50,15.08,71.74,4.68,-2.34 2.07,6682,2.53,1.00,26.00,4.00,14.07,67.03,4.68,-2.34 2.33,6109,0.31,1.00,9.00,0.00,-9.43,0.00,1.96,-3.91 2.58,5484,0.44,1.00,36.50,0.00,-1.74,11.37,3.66,-2.34 2.84,4752,2.49,1.00,3.00,3.00,12.33,63.90,4.38,-2.34 3.10,4903,3.33,1.00,18.50,4.50,19.72,62.72,4.58,-2.34 3.35,5081,3.29,1.00,19.50,4.50,19.43,65.86,4.64,-2.34 3.60,5338,3.17,1.00,19.50,4.50,18.42,67.42,4.64,-2.34 3.86,5458,3.07,1.00,20.00,4.50,17.84,68.60,4.64,-2.34 4.12,5648,3.00,1.00,18.50,4.00,17.40,69.78,4.66,-2.34 4.37,5806,2.89,1.00,19.00,4.00,16.97,70.95,4.68,-2.34 4.62,6007,2.82,1.00,19.00,4.00,16.53,72.13,4.68,-2.34 4.88,6120,2.78,1.00,20.50,4.00,16.24,72.13,4.66,-2.34 5.14,6306,2.71,1.00,21.50,3.50,15.95,72.13,4.70,-2.34 5.39,6451,2.64,1.00,22.00,3.50,15.66,72.13,4.70,-2.34 5.64,6590,2.59,1.00,23.50,4.00,15.52,71.74,4.70,-2.34 5.90,6526,1.39,1.00,-16.00,0.00,-4.06,0.00,3.20,-2.34 0.00,2791,1.54,1.00,20.50,3.00,2.18,21.56,3.12,-2.34 0.26,2840,1.88,1.00,13.50,3.50,5.22,58.41,3.36,-2.34 0.52,2900,2.24,1.00,12.50,4.00,8.85,58.02,3.58,-2.34 0.77,2956,2.72,1.00,9.00,4.50,14.07,58.02,3.80,-2.34 1.03,3025,3.25,1.00,8.50,4.50,19.72,56.84,4.04,-2.34 1.29,3130,3.43,1.00,8.50,4.50,21.61,51.74,3.94,-2.34 1.54,3278,3.43,1.00,9.00,4.50,21.17,52.53,4.08,-2.34 1.80,3380,3.48,1.00,9.50,4.50,20.59,55.66,4.18,-2.34 2.06,3440,3.53,1.00,10.00,4.50,21.03,54.88,4.24,-2.34 2.31,3588,3.54,1.00,11.00,4.50,21.32,55.27,4.26,-2.34 2.57,3657,3.53,1.00,11.00,4.50,21.46,55.27,4.28,-2.34 2.83,3792,3.52,1.00,12.00,4.50,21.32,55.66,4.28,-2.34 3.08,3854,3.50,1.00,12.50,4.50,21.17,56.45,4.34,-2.34 3.34,3950,3.46,1.00,13.00,4.50,21.17,56.84,4.38,-2.34 3.60,4063,3.43,1.00,13.50,4.50,21.32,58.41,4.40,-2.34 3.85,4173,3.45,1.00,15.00,4.50,21.32,59.98,4.42,-2.34 4.11,4318,3.46,1.00,15.50,4.50,21.32,60.37,4.46,-2.34 4.37,4415,3.49,1.00,14.50,4.50,21.32,60.76,4.54,-2.34 4.63,4505,3.48,1.00,15.00,4.50,21.32,61.54,4.54,-2.34 4.89,4621,3.45,1.00,15.00,4.50,21.32,62.33,4.56,-2.34 5.14,4728,3.45,1.00,15.50,4.50,21.17,62.72,4.58,-2.34 5.40,4818,3.42,1.00,15.50,4.50,20.74,63.11,4.60,-2.34 5.66,4903,3.38,1.00,16.00,4.50,20.16,58.02,4.60,-2.34 5.92,4785,0.49,1.00,9.00,0.00,-8.56,0.00,1.80,-3.91 |
#15 | |
Member#: 120187
South East
Look at the load, up to 3.57 on a straight stage 2. Either this car is putting some crazy HP or running extremely rich and needs a MAF calibration. |
#16 |
Member#: 164171
SCIC
Vehicle:08 EvoX <3 Wagon rear prodrive plate frame |
Nice Numbers.
im basically same setup VF43 w/08 sti TMIC 283whp/330tq w/ maxed out airflow (needs intake )turboxs catless dp catted midpipe magnaflow 2.5in Axelback. Walbro 255 stock intake box 20 psi tapering to 17 towards redline. ![]() guess i need a full 3 in and intake to hit 300+ ![]() |
#17 |
Member#: 169955
SCIC
Vehicle:30R BUILT STI /AREA P no limits/ALLIANCE FABn |
Nice #'s Gully, Now get that intake!
#18 |
Member#: 164171
SCIC
#19 |
Member#: 149485
i wish to have ur torque at such early RPM gully.. lol
#20 |
Member#: 164171
SCIC
^ wish hard enough, it might come true!!!
#21 |
Member#: 151683
#22 |
Member#: 198983
VIC
Vehicle:07 Targa C4S Guards Red |
jeezz. i pretty much have the same mods, and this thing looks like it would blow the doors off my car. 295whp and 320whp for me
#23 |
Member#: 82385
SCIC
Vehicle:2007 07sti ptunestg2 pearl WHITe |
yeah in cali we are on piss water 91 I made 292 and 358 torque full three inch turbo back catted and fuel pump. Jon at hb speed said i need injectors for more power...i am just thinking of getting injectors and then upgrading the turbo...he usually tunes those upgrades to 360 or 380 depending... i wish we just had 93 then i wouldn't upgrade to a new turbo hahaha...oh well
#24 |
Member#: 65054
Vehicle:2005 Grannymobile Hitch + Block Heater |
#25 |
Member#: 143251
Vehicle:07 murdered out JRTuned STi 343whp/381wtq |
07's FTW! glad you are happy with your new power i also got tuned at Agile not to long ago here is my graph. i will be returning with a cut out with a couple more mods for a retune .ENJOY!
| Thread Tools | |
| Display Modes | |
| protune stage 2 vs. stage 2.5 WRX | adWRXi | Factory 2.0L Turbo Powertrain | 15 | 03-06-2008 07:06 PM |
| protuned stage 2 or stage 2.5 wrx? | adWRXi | AccessPort | 5 | 03-05-2008 07:21 PM |
| Protune Stage 1 - 07 STI - Verocious Motorsports!! | speedmonkey | AccessPort | 12 | 11-15-2007 11:44 PM |
| The Shop Stage 2 07 STi | STi Mikey | Proven Power Bragging | 18 | 10-21-2007 10:57 PM |
| Stage 2 07 STi | Acejam2k | AccessPort | 1 | 09-07-2007 05:44 PM |
