Old 03-07-2009, 01:08 PM   #1
ChrisRT
Member#: 125941
200x WRX
Default Will a PS pump from a 1993-1995 Impreza fit a 1998 Impreza?
Does anyone know? I mean will it bolt right up or are the mounting points different?
ChrisRT is offline   Reply With Quote
Old 03-11-2009, 01:37 AM   #2
ChrisRT
Member#: 125941
200x WRX
bump for NEEDED info.
Old 03-11-2009, 08:26 AM   #3
Scooby921
Merci Buckets
Member#: 88606
2016 Cayman GTS
Dark Blue Metallic
It will bolt to the engine and you can put a belt on it. The setup for hoses and reservoir might be different. I know the newer '02+ Impreza has a separate reservoir mounted off to the side on the body rail. The early Impreza has the reservoir on top of the pump. I don't know what setup a '98 Impreza has. Its going to be one or the other.
Scooby921 is offline   Reply With Quote
Can't get a PS pump from Subaru! frsh13 New England Impreza Club Forum -- NESIC 15 01-13-2010 09:48 AM
I need a MAF sensor assy That will fit a 1998 Impreza 2.5RS Psybin Private 'Wanted' Classifieds 5 04-10-2008 10:28 AM
$20 ps pump from EJ20 motor. supermoose Private 'For Sale' Classifieds 0 08-23-2005 11:13 AM
Will the steering wheels from WRX or Forester Turbo fit a '91 Legacy ? Legacy Legacy Forum 6 11-06-2003 10:55 AM
Will the turbo assembly from a '9x Turbo Legacy fit a '95 2.2L Impreza? GTLee Normally Aspirated Powertrain 1 10-23-2001 04:35 PM
