Old 03-07-2009, 02:07 PM   #1
Pykar
Member#: 140275
2000 Impreza
Blue Ridge Pearl
Default Hybrid Turbo
Does anybody heard about hybrid turbo???
I mean, put an hot section of a turbo "X" and the cold section of a turbo "Y" together.
I heard about a mix of a cold section of a VF23 and the hot section of a VF39 and I look to get some information about it. It seems to get some good reasult in therory (low end torque and high end hp with a ball bearing turbo)
So, can anybody get some info about it???
PS: I'm french canadian, so I'm sorry for my english, I will do my best
Pykar is offline   Reply With Quote
Old 03-07-2009, 07:42 PM   #2
wrxSLEEPER03
Member#: 189820
2009 STI
Just get the VF34, It's an awesome balance between all the "VF" turbos. I personally have it on my 03 bugeye and put down 340whp on 21psi. I wouldn't go "hybrid". Get the 34 and you'll be pleased with the response and power. Good luck!
wrxSLEEPER03 is offline   Reply With Quote
Old 03-08-2009, 07:11 AM   #3
jeffmoorman
Member#: 105736
2011 135i
lemans blue
well the vf23 is already a "hybrid turbo" of a vf22 and something else, im not sure which.
jeffmoorman is offline   Reply With Quote
Old 03-08-2009, 07:56 AM   #4
GDB FAN
Member#: 105814
Not on a 2.0L, sorry.
I've personally never heard of anyone making hybrids out of any VFxx's before. You might get better responses in the Proven Power Bragging forum.
GDB FAN is offline   Reply With Quote
Old 03-08-2009, 09:18 AM   #5
Pykar
Member#: 140275
2000 Impreza
Blue Ridge Pearl
Hum, yes I know about some of the VFxx that already be hybrid like the VF23. I also heard about the good result of that VF34.
My goal is to achive low end torque as much as possible. I actually have a 2.5L WRX with the TD04 and get 263hp and 290lb-tq on the Lachute Performance dyno (on motor).
I would like to get a good all around turbo that can break the 300 on each measure.
I like things that are not OEM and out of the box. I also like to do something first, that's why I look for hybrid turbo
Try a new combinaison of cold and hot housing of turbo.
Old 03-08-2009, 03:26 PM   #6
xXFiendXx
Member#: 155689
What correction factor, and what kind of dyno? My 2.0 liter put down 350whp/350wtq on an 18g on e-85 at 22 psi. So I dont believe your numbers for a minute. My numbers were on a 1.15 CF on a dyno dynamics dyno
xXFiendXx is offline   Reply With Quote
Old 03-09-2009, 12:12 PM   #7
Pykar
Member#: 140275
2000 Impreza
Blue Ridge Pearl
Can you please debate on his numbers on PM or elsewhere.
It is not against you and I don't know if you are good or not, but it may held to a long debate not related to this posts and this will not help my search.
Thanks,
Back to topic
Old 03-09-2009, 04:33 PM   #8
GDB FAN
Member#: 105814
I wouldn't consider that a hybrid because thats what makes them what they are. (if that makes sense?)
A VF39 with a 20G wheel would be a hybrid.
Old 03-10-2009, 10:04 AM   #9
kirkdunkan
Member#: 205260
Cool!!
kirkdunkan is offline   Reply With Quote
Old 03-10-2009, 10:32 PM   #10
Pykar
Member#: 140275
2000 Impreza
Blue Ridge Pearl
The VF23 is the cold section of the VF22 and the same hot section as the VF24.
I know that is an hybrid, but it is also an "official" VF.
That it is not what I search.
In other words, can we use any hot section with any cold section of any VF serie turbo???
Old 03-28-2009, 09:10 PM   #11
EJ20TT
Member#: 91012
1994 WRX STi type R
You can swap the various turbine housings between some of the VF turbos.
For example you can put a p18 housing on a vf22 for better spool if you wanted.
Some exhaust housings will not fit or will need to be machined to do so.
VF23 and 24 share the same compressor. The 23 has a p20 exhaust housing the vf24 a p18 housing. It doesn't make them a hybrid as thats what manufactors do.
"I heard about a mix of a cold section of a VF23 and the hot section of a VF39 and I look to get some information about it. It seems to get some good reasult in therory (low end torque and high end hp with a ball bearing turbo)"
IMO the difference would be small and not worth doing.
I think you would need to machine the vf39 exh housing to fit a vf23. The p18 from a vf34 will swap straight onto a vf23.
All that would achieve is a vf24 which IHI already make !
A vf34 is a better turbo than a vf23 or 24.
EJ20TT is offline   Reply With Quote
Who has a Turbo Specialties IHI/Garret hybrid turbo/ STi_Pete Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 09-29-2002 10:45 AM
New Turbo Specialties Hybrid Turbo Blue02WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 06-09-2002 09:16 PM
New hybrid turbo! Division By Zero Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 45 03-04-2002 06:18 PM
Turbo specialities Hybrid turbo frist impressions nmyeti Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 96 02-28-2002 12:36 PM
I drove the hybrid turbo mikaust Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 01-03-2002 06:18 PM
