Old 03-07-2009, 05:44 PM   #1
Mr.Durden
Member#: 203652
2009 Impreza 2.5i
Satin white
Lightbulb DIY: Painting tail lights Impreza 08-09 5 door
I take no responsibility if anything happens, diy are always to use at your own risk.
Alright, after looking around for some vinyl to put on my tail lights and found that it was almost impossible for me to find this weekend, I decided to paint the lights instead. To begin with, you will need:
-Flat screwdriver
-Ratchet
-10mm socket
-8mm socket
-Extension for ratchet
-Painters tape
-Exacto knife
-Stained glass paint (Can be found in hardware stores)
First you start by removing the 2 screws for the outer tail lights. When those are removed, you slide the light towards you.
Once the outer tail lights are removed you can remove the inner ones. By using the 8mm socket remove the screws located on the side of the lights when you open the trunk.(forgot to take a picture) After those 2 screws are removed, you need to remove the interior panel of the hatch. You will need to pull hard in order to remove the cover, don't worry you wont break anything.
Once the panel removed the last bolt for the inner tail lights is located next to the reverse light bulb, make sure to not drop the bolt.
All lights removed.
Now for the paint, cover the blinker and reverse part with painters tape. Make the contour with exacto knife. All of this is pretty straight forward. Take the spray paint and paint the lights... You can put as many coats as you want to achieve the tint of your choice, you can also add some clear to protect even more. Once everything is dry, reassemble everything.
Hope all of this was of any help sorry if some steps were skipped, this is my first written diy.
Mr.Durden is offline   Reply With Quote
Old 03-07-2009, 05:48 PM   #2
Mr.Durden
Member#: 203652
2009 Impreza 2.5i
Satin white
The paint to use
Old 03-07-2009, 05:55 PM   #3
All4bSpinnin
Member#: 99102
09 135i 6MT FBO
Twin Turbo!
Good job, thanks for the writeup!!
All4bSpinnin is offline   Reply With Quote
Old 03-07-2009, 06:28 PM   #4
eurospek
Member#: 96944
2005 SAAB 9-2X AERO
4eat Stage 2 Protuned
Looks awesome!!!! Much better than vinyl!
eurospek is offline   Reply With Quote
Old 03-07-2009, 06:29 PM   #5
bebechica
Member#: 192098
2009 2.5i Impreza
5DR/SWP/5MT
nice job! too bad my car is leased...
yur rear seats are brown??
bebechica is offline   Reply With Quote
Old 03-07-2009, 06:32 PM   #6
Mr.Durden
Member#: 203652
2009 Impreza 2.5i
Satin white
No, no just the lighting that makes them look like that. Btw my car is leased too
Old 03-07-2009, 07:07 PM   #7
Cereal Killer
Member#: 201789
2008 Impreza 2.5i
Satin White Pearl
Great job! About how long did it take?
Cereal Killer is offline   Reply With Quote
Old 03-07-2009, 07:08 PM   #8
Mechie3
Member#: 120152
Nice! I like it!
Mechie3 is offline   Reply With Quote
Old 03-07-2009, 07:10 PM   #9
98Legacy_757
Member#: 183874
95 Integra SE
w/ 01 ITR exterior!?
looks flawless, and yes is much better than tint
98Legacy_757 is offline   Reply With Quote
Old 03-07-2009, 07:13 PM   #10
Mr.Durden
Member#: 203652
2009 Impreza 2.5i
Satin white
3-4 hours in total. Which means removing the lights, prepping, painting and putting back together.
Old 03-07-2009, 09:34 PM   #11
BURMAT
Member#: 195424
2015 WRX
Good job.. They look much better to me honestly
BURMAT is offline   Reply With Quote
Old 03-07-2009, 09:41 PM   #12
wrxphantom
Member#: 128643
2013 STI Sedan
do you know if this paint is removeable... lets say you don't like it... or you make a mistake
wrxphantom is offline   Reply With Quote
Old 03-07-2009, 11:06 PM   #13
NorthBayResident
Member#: 204200
2008 Impreza 2.5i
soon to do this to my nasty-altezza-style 08 tail lights too haha
NorthBayResident is offline   Reply With Quote
Old 03-08-2009, 09:15 AM   #14
Mr.Durden
Member#: 203652
2009 Impreza 2.5i
Satin white
Regular paint thinner on a rag.
Old 03-08-2009, 10:12 AM   #15
elwray
Member#: 194826
'09 WRX 5dr PP DGM
'07 VTX1300c, '03 VFR800
Wow, that looks fantastic - thanks for the write up and pictures!
You achieved that look without sanding at all?? This is definitely worth a shot!
is this an enamel or lacquer paint?
EDIT:
How many coats did you use to get this degree of tint?
elwray is offline   Reply With Quote
Old 03-08-2009, 12:19 PM   #16
Zordos
Member#: 165121
looks good man. here's mine I did a while back pretty much with the exact same steps and material. 4 coats I think, held up nicely to all the washes, rain, and pitiful snow BC gets haha.
Zordos is offline   Reply With Quote
Old 03-08-2009, 07:31 PM   #17
Mr.Durden
Member#: 203652
2009 Impreza 2.5i
Satin white
EDIT:
Like Zordos said about 4 coats. Yes did it without sanding. The paint is a glass coat paint, not sure if it's enamel, lacquer or something else. It is the thing to use though. Oh, i do know that testors spray paint works too, this one:
I know this one is enamel
Old 03-08-2009, 07:32 PM   #18
elwray
Member#: 194826
'09 WRX 5dr PP DGM
Cool, thanks for the info! I'll be getting to this soon!
Old 03-08-2009, 07:33 PM   #19
Mr.Durden
Member#: 203652
2009 Impreza 2.5i
Satin white
The way those lights should have came out of the factory.
Old 03-08-2009, 07:35 PM   #20
Mr.Durden
Member#: 203652
2009 Impreza 2.5i
Satin white
Just notice in your info that you have a dgm impreza, any pictures of it? Of course you do need to get some when you get it done too.
Old 03-08-2009, 07:37 PM   #21
elwray
Member#: 194826
'09 WRX 5dr PP DGM
Haha, if you were an hour earlier I could have taken some! But no, not yet. I'll snap some tomorrow before I get to work if it's nice out.
Old 03-08-2009, 07:38 PM   #22
Mr.Durden
Member#: 203652
2009 Impreza 2.5i
Satin white
All good!
Old 03-10-2009, 09:14 PM   #23
Mr.Durden
Member#: 203652
2009 Impreza 2.5i
Satin white
Bump. Sweet cheap mod to do!
Old 03-24-2009, 12:48 AM   #24
MarksmanUK
Member#: 205509
2009 WRX
Hey Zordos, lights look great. Did you use the candy apple colour too? Looks darker to me...
MarksmanUK is offline   Reply With Quote
Old 03-24-2009, 01:17 AM   #25
Zordos
Member#: 165121
exact same stuff Mr.Durden used. Krylon stained glass stuff. I used roughly 4 coats
08-09 5 Door Tailight setups austyg243 Member's Car Gallery 31 03-05-2010 09:14 PM
08-09 5 Door Spt Catback 09subihatch MWSOC Private Classifieds 6 11-19-2009 06:58 AM
SPT catback for 08-09 5 door 09subihatch Engine/Power/Exhaust 2 08-13-2009 07:47 PM
WTB: Stock WRX exhaust 08/09 5 Door Debevemos NWIC Private Classifieds 0 07-29-2009 12:17 AM
08/09 WRX Tail Lights vs. 08/09 STI Tail Lights elscoobie20 Interior & Exterior Modification 2 07-22-2009 05:11 PM
