Old 07-09-2009, 04:42 PM   #26
09NewfieWRX
Member#: 59036
2013 Outback
Venician Red
Cool
That looks so much better i'll have to tackle that job to
09NewfieWRX is offline   Reply With Quote
Old 07-12-2009, 02:15 PM   #27
Kurikaze
Member#: 174252
2014 BRZ
i so have to try it
Kurikaze is offline   Reply With Quote
Old 07-15-2009, 06:42 AM   #28
09NewfieWRX
Member#: 59036
2013 Outback
Venician Red
I can't find that Krylon paint anywhere around here May have to resort to the Testor's paint.
Old 07-20-2009, 10:31 PM   #29
kimfamilyy
Member#: 213867
2009 WRX
Do people recommend spraying clearcoat after paint is dried? Or just spraying krylon red pain is good enough to last for awhile?
kimfamilyy is offline   Reply With Quote
Old 07-24-2009, 04:50 PM   #30
OxCitywrx09
Member#: 216362
2013 WRX
That krylon stained glass stuff is hard to find in the stores. usually only available through special order. However i was able to find the trust transparent candy apple red. Going to paint my tails by this weeked . I was talking to the guys at the hobby place where i got it and they sed that its not going to be necessary to shoot my tail lights with a clear.. Can anyone here confirm this?
OxCitywrx09 is offline   Reply With Quote
Old 07-24-2009, 06:17 PM   #31
u2_m4r1n3
Member#: 189606
E46 M3
Ti Silver
Nice write uP! going to try it today!
u2_m4r1n3 is offline   Reply With Quote
Old 07-24-2009, 11:13 PM   #32
09NewfieWRX
Member#: 59036
2013 Outback
Venician Red
Wink
Yeah, i have to do the same for the paint, can't find that Krylon anywhere.
BTW, while your at it, don't forget to do the 3rd brake light in the rear spoiler.
Old 08-03-2009, 04:01 PM   #33
09NewfieWRX
Member#: 59036
2013 Outback
Venician Red
Cool
Well, got the paint today, so needless to say...I went at the lights!
I used the Testor's Transparent Candy Apple red and after a few coats..voila!
I also did the 3rd brake light.
Old 08-03-2009, 04:13 PM   #34
T WRX rawr
Member#: 215168
2006 WRX stage 2 OS
Very slick. I really like that look, 10x better than stock.
T WRX rawr is offline   Reply With Quote
Old 08-03-2009, 11:05 PM   #35
tastybrew
Member#: 177355
2008 Impreza 2.5i
Nice job! Did you prep the lights by sanding or use any adhesion promoter?
tastybrew is offline   Reply With Quote
Old 08-07-2009, 08:11 AM   #36
penrod
Member#: 218495
2008 WRX Wagon 4EAT
Are there any other colors? I've got a black 08 hatch and wanted something more like a tinted/ smoked color.
Another thing; how hard is it to remove that back chrome piece. I'd like to get that painted black as well. If I can do it myself with good results, even better.
penrod is offline   Reply With Quote
Old 08-07-2009, 08:45 AM   #37
elwray
Member#: 194826
'09 WRX 5dr PP DGM
'07 VTX1300c, '03 VFR800
^ if you're only going to be painting the brake light but leaving the reverse white, you could pretty much use anything you want. I know there are "smoke" sprays out there made specifically for that. You COULD probably get away with doing the whole thing, too, if you felt so inclined.
elwray is offline   Reply With Quote
Old 08-07-2009, 08:56 AM   #38
guru_method
Member#: 189118
Chapter/Region: PRSIC
2003 S.Yellow WRX
2008 BMW 335i
Newfie, i like that your lights look almost matte, very nice look. I don't know if they look that in person but I like it.
BTW Mr.Durden, i like your socket wrench set, high end stuff
guru_method is offline   Reply With Quote
Old 08-07-2009, 01:03 PM   #39
Super_HKS
Member#: 154434
2009 WRX Hatch <@_@>
I did this on a 2009 wrx if anyone has one its a tad bit different. check it out
http://forums.nasioc.com/forums/show....php?t=1820318
Super_HKS is offline   Reply With Quote
Old 08-07-2009, 01:17 PM   #40
elwray
Member#: 194826
'09 WRX 5dr PP DGM
How much of the testor's did it take to git 'r done?
I've still got to find this paint and do it already... although I'm considering smoking the outer ring instead of red on my DGM 09.... Either way something has to be done!
Old 08-07-2009, 02:13 PM   #41
09NewfieWRX
Member#: 59036
2013 Outback
Venician Red
Wink
one can is all you need, it's more than plenty. I bought 2 just incase I needed it since there only little cans.
I may go back and clear coat it like Super_HKS has done, it looks shiner and better imo.
But for now, it's still looking a hell of alot better than stock!
Either way, it's a easy DIY for anyone to do.
Old 08-08-2009, 12:58 PM   #42
fellstar
Member#: 205280
2012 Jeep Wrangler
Bright Silver
Before:
After:
fellstar is offline   Reply With Quote
Old 08-08-2009, 01:13 PM   #43
Subiebobby
Member#: 181046
2002 wrx wagon
psm aps s/r55, meth 6 spd
Awesome! thats how they should have looked from the factory imo, flawless
Subiebobby is offline   Reply With Quote
Old 08-10-2009, 03:38 PM   #44
biohazard75
Member#: 206341
2009 Impreza WRX STI
did mine also;
4 coats of Testors Candy Apple Red
2 coats of Krylon UV clear gloss
wet sanded after UV was dry, messed up a little; thin spotted the outer lights in 2 places and could have sanded the clear sections a bit more, regardless, pleased as punch with the results:
biohazard75 is offline   Reply With Quote
Old 08-22-2009, 09:24 PM   #45
Bark3rd
Member#: 205531
16 Jeep GC Ltd.
Originally Posted by biohazard75 View Post
did mine also;
Im in the middle of this now using Testors. Are you glad that you wet sanded or do you wish you hadnt bothered? Im getting a little bit of spatter "dots" here and there, could I wet sand before the clear coat goes on? What did you use to wet sand with? Did you shoot another coat of clear after wet sanding? Ivew done 4 light coats already of the Testors red and it doesnt look dark enough yet.
Bark3rd is offline   Reply With Quote
Old 06-15-2010, 04:12 AM   #46
DutchOven
Member#: 220629
2010 White WRX Hatch
2015 White WRX Limited
good writeup, thanks. i went with the overlays first, which was a mistake. I will redo them after they start to peel and paint them using this diy.
DutchOven is offline   Reply With Quote
Old 06-15-2010, 11:13 PM   #47
Bark3rd
Member#: 205531
16 Jeep GC Ltd.
I painted mine last year with the testors and now they are a faded pink color. Not really wanting to deal with it again. Where can we buy real red tail lights for an 09?
Old 06-17-2010, 03:22 AM   #48
Midevil
Member#: 175065
2011 SWP WRX
INTERNET TOUGH GUYS? LOL
You cant buy real red tailights. Both paints on this thread shown to fade over time. You will have to redo your tailights. Use paint thinner, or a headlight restoration kit to strip the old paint, or a combination of both like I had to. Use Duplicolor Metalcast Red spray paint with a spray clearcoat.
Here is my journal if you want to see pics and more info.
http://www.iwsti.com/forums/gr-membe...rlays-pg3.html
Midevil is offline   Reply With Quote
Old 06-17-2010, 09:04 AM   #49
Bark3rd
Member#: 205531
16 Jeep GC Ltd.
Midevil: but didnt you end up stripping the paint and going with overlays? Thats what Im wanting to do, I have had great luck with the yellow headlight overlays, they are bulletproof so gonna try the tail overlay. What brand did you use and exactly how did you strip the paint from the lights? Did it just come right off? Im worried about paint thinner reacting with the plastic
Old 06-17-2010, 02:14 PM   #50
JBH2989
Member#: 249218
2013 stg1 WRX
Midnight blue
This is probably a silly question, but when painting the rear lights, do you color the inside of the lenses or the outside?
Also, has anyone reported problems with the paint thinner clouding up the plastic?
JBH2989 is offline   Reply With Quote
08-09 5 Door Tailight setups austyg243 Member's Car Gallery 31 03-05-2010 09:14 PM
08-09 5 Door Spt Catback 09subihatch MWSOC Private Classifieds 6 11-19-2009 06:58 AM
SPT catback for 08-09 5 door 09subihatch Engine/Power/Exhaust 2 08-13-2009 07:47 PM
WTB: Stock WRX exhaust 08/09 5 Door Debevemos NWIC Private Classifieds 0 07-29-2009 12:17 AM
08/09 WRX Tail Lights vs. 08/09 STI Tail Lights elscoobie20 Interior & Exterior Modification 2 07-22-2009 05:11 PM
