Welcome to the North American Subaru Impreza Owners Club Tuesday May 26, 2015
Old 03-07-2009, 09:11 PM   #1
Hotsho111
Member#: 199136
2007 Impreza
2005 ZX-6R
Default DIY: Custom Clock pod (Uses stock clock!)
So, when I bought my car it came with some pods and after driving around I got a little annoyed at not having a clock. So...I decided to make myself a custom gauge pod that would use the stock clock. Sorry for some of the bad pics.
This was what the pod and gauges looked like before:
First, I bought a clock pod and cut out the back so the gauges had a place to sit. I also cut off the front curved lip as well (you can't really tell in this picture):
After that I cut up the old gauge pod a bit (notice how I cut off a little more on the top left versus the top right...this took me a week or so to fix...so be careful and think before you cut)
After some more shaping, cutting, and sanding. I glued the two pieces together using plastic model glue. I liked the way it came out with a slight bow, like the stock clock had:
I then used some Bondo-Glass (bondo with short-haired fiberglass strands) to join the pieces together (this was my first time applying the stuff...after getting used to it I became a pro and was able to put it on a lot more smooth):
I then sanded it down and shaped it a bit:
I filled in the small holes from the bondo-glass using glazing and spot putty:
After several days of sanding, some more bondoing, and a lot more spot putty, this is what I ended up with. I'm very happy with how symmetrical the piece ended up.
Hotsho111 is offline   Reply With Quote
Old 03-07-2009, 09:11 PM   #2
Hotsho111
Member#: 199136
2007 Impreza
2005 ZX-6R
Even though no one would see it, the bottom looked a little messy so I wanted to paint it to make everything the same color. I didn't do much prep on the bottom and it came out great. I used Duplicolor adhesion promoter and interior flat black. I first sprayed 3 layers of adhesion promoter, painting layers every 2 minutes, and then waited 3 minutes and used the same process with the flat black. I sprayed several layers of the black until it was covered:
and after painting (note where the bondoglass is the paint is still a little wet in this picture. The paint on the bondo-glass took longer to dry then the paint on the pure plastic):
I then taped up the bottom so I could paint the top and bottom below the gauges (it's not possible to paint this from the front in a nice clean motion):
The unfortunate thing was that the tape, wrapped around to the front, took some of the putty out of the tiny holes in the front, so I had to do 1 more layer of it before final sanding and painting.
I forgot to take pictures after I finished sanding the top because I was so pleased with how it turned out I installed it in my car...(sorry for the crappy pics, they were all taken at night):
It's easy to see the clock with the gauges on top
I got some pics of the left and right side and you can't really tell they were ever 2 separate pieces:
If you want I can take some pictures during the day tomorrow so you can see a bit more detail.
Also, I'm going to be installing the BaysonR s204 lip tomorrow (if it doesn't rain) and will eventually paint my subaru emblems and clear my headlights, so if you want I can do write-ups for those too.
Finally, if you have any questions feel free to post here or pm me. I have more pics too.
Old 03-07-2009, 09:37 PM   #3
exrage
Member#: 77366
2004 WRX Wagon stg.2
looks pretty nice. initially i thought the gauges would be sitting too high, but that is not the case...
good work
exrage is offline   Reply With Quote
Old 03-07-2009, 10:27 PM   #4
theguy
Member#: 144244
2006 WRB STi
www.CAMtuning.com
not bad at all
theguy is offline   Reply With Quote
Old 03-07-2009, 10:35 PM   #5
Newbuggy
Member#: 152042
The main reason why I have not gotten a center gauge pod no clock. this is a great alternative.
Newbuggy is offline   Reply With Quote
Old 03-07-2009, 10:38 PM   #6
Heider
Member#: 172173
2005 Impreza WRX
i was a little worried when i saw the first pic, but that actually looks pretty good!
Heider is offline   Reply With Quote
Old 03-07-2009, 10:40 PM   #7
STimedic
Member#: 104765
02 STi :D
2011 PRP FXT T
Have a mold made of it and market it....this = $$$
STimedic is offline   Reply With Quote
Old 03-07-2009, 10:42 PM   #8
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
nice!
Bad Noodle is offline   Reply With Quote
Old 03-07-2009, 11:26 PM   #9
Swany
Member#: 142198
02 WRX
Always bet on black!
Plasti-dip it!!!
Swany is offline   Reply With Quote
Old 03-07-2009, 11:33 PM   #10
IIdiceII
Member#: 90438
best diy/modded clock pod ive seen yet. looks awesome.
IIdiceII is offline   Reply With Quote
Old 03-08-2009, 12:10 AM   #11
GDB FAN
Member#: 105814
Looks good. Just a FYI, they do make clock pods that retain the clock.
GDB FAN is offline   Reply With Quote
Old 03-08-2009, 12:11 AM   #12
Hotsho111
Member#: 199136
2007 Impreza
2005 ZX-6R
Zero sports makes one, but its like 200 bucks...so I figured I'd make my own
Old 03-08-2009, 12:14 AM   #13
GDB FAN
Member#: 105814
Start your own business and sell them for cheap. $$$
Old 03-08-2009, 12:16 AM   #14
Hotsho111
Member#: 199136
2007 Impreza
2005 ZX-6R
I'd love to, but I probably don't have the money to do it.
How many people are interested in something like this?
Old 03-08-2009, 03:49 AM   #15
Twsti07
Member#: 178688
2007 STi
i'd love to mount gauges in a clock pod but i do often wonder what time it is. thus i have no gauge pod. how's the sight line to the clock from the seats?
Twsti07 is offline   Reply With Quote
Old 03-08-2009, 03:54 AM   #16
Hotsho111
Member#: 199136
2007 Impreza
2005 ZX-6R
Twsti, the site line is great. The first night picture was with me sitting in the driver's seat where a person would normally be.
The front of the gauge pod is level with where the top of the clock pod was so it doesn't affect your ability to see it at all (I was also worrying about that when I started)
Old 03-08-2009, 12:04 PM   #17
Hotsho111
Member#: 199136
2007 Impreza
2005 ZX-6R
Hey, I got some pics of the pod during the day...
The new pod is longer than the stock clock pod, so I curved the back so it matches the contour of the interior
Pic from where someone would be when driving and you can easily see the clock
Old 03-08-2009, 12:07 PM   #18
98Legacy_757
Member#: 183874
95 Integra SE
w/ 01 ITR exterior!?
wow that looks spp proffesionally done. that should let you know how i feel about it :]
98Legacy_757 is offline   Reply With Quote
Old 03-08-2009, 12:13 PM   #19
kokopuffs405
Member#: 201772
2008 OH RLY
Alpine White
i want one =)
kokopuffs405 is offline   Reply With Quote
Old 03-08-2009, 12:23 PM   #20
Evo killerz
Member#: 182874
2007 wrx
WR Blue
good job mate
Evo killerz is offline   Reply With Quote
Old 03-08-2009, 03:05 PM   #21
Hotsho111
Member#: 199136
2007 Impreza
2005 ZX-6R
Thanks Evo for getting me motivated to do something
I'm happy with how it came out. I also put on my S204 lip today
Old 03-08-2009, 03:17 PM   #22
Evo killerz
Member#: 182874
2007 wrx
WR Blue
no problem man hope tips n all i gav ya helped
Old 03-08-2009, 03:57 PM   #23
100_Percent_Juice
Member#: 126042
2004 W Ŕ X
That looks freaking great, nice work blending the pods into the clock to make it look factory.
100_Percent_Juice is offline   Reply With Quote
Old 03-08-2009, 04:52 PM   #24
TXwrxWagon
Member#: 191557
2004 WRX Wagon
WRB not so minty fresh
very well done! If you can tweak the next version (hint-hint) to exactly match the factory dash opening & use the OE mounts... I'd pay $100 for that + the core of my OE clock pod.. easily...
The Zero sports is expensive for what you get...
TXwrxWagon is offline   Reply With Quote
Old 03-08-2009, 04:54 PM   #25
InfiniteMotorsports
Member#: 85354
This is one of my favorite types of mods: user created and nicely done!
InfiniteMotorsports is offline   Reply With Quote
DIY: Custom Gauge Pods ccrstanley Interior & Exterior Modification 26 04-02-2010 02:30 PM
hock3yplay3r20/V8killinscooby-WTT autometer clock pod for stock clock quadtard Scammer Central 19 03-06-2009 10:10 AM
Custom Short Ram Intake, stock clock, stock turbo inlet. billfromtr Engine/Power/Exhaust 1 12-18-2007 11:40 PM
ATI clock Pod vs. Defi Clock Pod Dragicon Interior & Exterior Modification 3 05-01-2007 06:45 PM
