Welcome to the North American Subaru Impreza Owners Club Friday June 24, 2016
Old 03-07-2009, 10:27 PM   #1
hectowrx
Member#: 109155
2003 white wrx ej205
[email protected] feel the panic!
Default has anybody came across this? radiator hose!!!
ok guys so im in the break in of my new built motor , and everything seems ok . i installed a koyo radiator for my current set up along with the gates radiator hoses and factory fans. Everything seem ok after 500miles i decided to go wot at 18 psi for a bit to see how it handle , everything felt ok so as the readings of my gauges. When i came back decided to check the engie bay , and to my surprise i found shavings of blue plastic on my alternator and front of motor area , not a hole lot but it was noticeable. So i started looking and realized that the top radiator hose wich is blue was hitting the fan on the radiator . Now my question has anybody come across this ? I did trim the hose the first time I installed it, to make up space because of the new radiator. The hose need to bee trimed in order to fit propertly . This was done but still the fans hit the hose . I thik the hose is not inflating or anyhtig like that , or else im screwed but i doubt it ,any inputs?
hectowrx is offline   Reply With Quote
Old 03-07-2009, 11:05 PM   #2
blkwagon
Member#: 102857
RHD sedan sti swap
high on meth
yes happend to my samco hose...i just trimmed it shorter so it wouldn't hit the fans. worked perfect.
blkwagon is offline   Reply With Quote
Old 03-08-2009, 03:30 AM   #3
NickVu
Member#: 27525
03 wrx wagon
yellow
same here. have a koyo 3" in a 2003 wrx, i'm not sure how much the samco ones expand but in my case the stock ones did expand over time. when i installed it new, there was 1/2" clearance to the fan. after some months it started touching the fan.
NickVu is offline   Reply With Quote
Old 03-08-2009, 08:58 AM   #4
hectowrx
Member#: 109155
thanks guys for your replys , i think the problem is the koyo rad is very big and does not leave you with much room to play specially with the stock fans , let you guys know if i correct this !!!
Old 03-08-2009, 07:24 PM   #5
robbieshonda
Member#: 122306
2002 Sti PTE 6262
Interlagos Blue 551/441
Same as them. Trim the engine side of the hose so it pulls it away from the fan blades.
robbieshonda is offline   Reply With Quote
I came across this.......thing......on ebay.. Fach Off-Topic 17 09-20-2004 01:19 PM
Looking for turbo and came across this..GT turbos.. Porkchop-WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 08-26-2004 10:36 AM
Came across this while searching. Poor boy/fast car Off-Topic 28 03-04-2004 05:10 PM
Tim, i came across this pic. Looks familier VSM EXtasy Mid Atlantic Impreza Club -- MAIC 2 06-25-2002 10:26 AM
Came across this WRX Image... personal concept? StevieD Texas Impreza Club Forum -- TXIC 3 03-15-2002 07:50 AM
