Old 04-11-2002, 01:14 AM   #1
racerwad
Member#: 2564
Default Apexi ITC?
i've checked apexi's website and i am not seeing their ITC. do they still make it? i've found a few vendors that have it, but i find it a bit odd that the apexi's website doesn't have it listed. i was just wondering what people use for timing control IF the apexi unit isn't available? thanks!
andy
racerwad is offline   Reply With Quote
Old 04-11-2002, 01:19 AM   #2
Andrew
Member#: 1170
2005 STi
thats the only piggy back i know of that lets you play with timing for our cars. and no, IIRC, apex-i doesnt make it anymore. personally, im going to be controlling my timing, and everything for that matter with a Link2 ecu.
Andrew is offline   Reply With Quote
Old 04-11-2002, 02:37 AM   #3
KillerTHC
Member#: 4942
01 SRP 2.5 RS-T
Ludespeed Stage 3 Link'd
skywalker should have one for sale pretty soon.
KillerTHC is offline   Reply With Quote
Old 04-11-2002, 02:41 AM   #4
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
8complex had one he was selling a while back..shoot him a PM and see if he still has it.
Jeremy
Old 04-11-2002, 10:21 AM   #5
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Sold mine a few weeks ago. I had heard rumors that they stopped making it, but I kept seeing it available everwhere. *shrug*
Old 04-11-2002, 12:47 PM   #6
KillerTHC
Member#: 4942
01 SRP 2.5 RS-T
i found this in the private classifieds: http://www.i-club.com/forums/showthr...hreadid=170563
Old 04-11-2002, 03:37 PM   #7
racerwad
Member#: 2564
Unhappy
so it really isn't available anymore? and no one else makes a piggyback timing controller?
what are most of you turbo'd RS's doing then to control your timing? this is really directed to people who DO NOT have standalone control (obviously). at any rate, do chips like the torquechip or proecm provide any benefit along with an S-AFC? thanks again.
looking for another solution...
andy
Old 04-11-2002, 04:17 PM   #8
KillerTHC
Member#: 4942
01 SRP 2.5 RS-T
i think split second makes something to control timing... TMC-1 or something to that effect...
Old 04-11-2002, 09:30 PM   #9
STiTuner
Member#: 5778
09 135i
Jet Black
YES to every one...
APEXi no longer supports or produces that product anymore. distributers should have done away with that prodruct about 7 months ago.
Split Sec does make a comperable product but its not as flexible. I think it has like 3-4 points to tune timing.
And there were a few for sale in ther private adds about a week or two ago.
Brad
STiTuner is offline   Reply With Quote
Old 04-13-2002, 02:50 AM   #10
ImprezaRS dot com
over boosted again
Member#: 1458
2015 Forester 2.0 XT
2005 2.5 RS, 2013 Tribeca
The ProECM timing controller keeps getting new features, so isn't out yet but the prototype works in my car...
Till then I use an ITC I bought off JC Sport's car before they shut down, and I can run 3-4 more psi now!
ImprezaRS dot com is offline   Reply With Quote
Old 04-13-2002, 11:14 AM   #11
kensington
Member#: 9113
2k4 WRB STi
RIP#92 Fred"G-Money"Zippy
J&S Ultra SafeGuard. Do a search for the website, I don't recall what it is right now. The one for the WRX is still being tested but the one for th RS has been out for a while, I found a thread in this forum that had very good comments on it, it will automatically pull timing when it detects knock.
kensington is offline   Reply With Quote
Old 04-13-2002, 02:18 PM   #12
racerwad
Member#: 2564
Exclamation thanks
everyone-
thanks so much for the input.
larry-does the prototype proecm chip automatically control timing or is it user definable, like the ITC?
kensington-it's my understanding that the new J&S is also automatic with no user controls. i also vaguely remember someone from J&S saying that the new setup isn't ideal for older RS's, like mine. i'm off to work but i'll look into that when i get back. until then, does this sound right to anyone? thanks.
andy
Old 04-13-2002, 11:06 PM   #13
Graham
Member#: 11931
2001 2.5 RS Turbo
257/FMIC/T3-T04S
Well, STiTuner and myself just installed my ITC today. So far, its running fine, though I think its a bit slower because of the amount of timing retard I have set (3 degrees through the entire RPM band). My J&S is STILL pulling timing, so I think that it is doing so based on engine noise and not pinging.
Right now, when I start the car, I get a hesitation, and sometimes it just stops in the middle of the engine crank, and starts back up again. The hesitation sounds like a really muffled turnover, and I have no idea why its doing this.
Graham....
Graham is offline   Reply With Quote
Old 04-13-2002, 11:56 PM   #14
STiTuner
Member#: 5778
09 135i
Jet Black
the hesitating is wierd actually.
I can advance my timing by like 7 degrees at 800 rpm mark. turn the key to just barely get the car turning over, blip the throttle, and the car will almost die and then start back up again. the closer I leave it to 7 the more it cranks like a normal car. as far as pulling timing the Boxer is a rather loud engine. you can hear my valve train if you listen to my intake. Just remeber though be tankful you have this when you crank up the boost and when summer finally kicks in.
Brad
Old 04-14-2002, 01:33 AM   #15
ImprezaRS dot com
over boosted again
Member#: 1458
The ProECM is programable.
With ITC I only retard 3 degree at 4,000 or so, and 5 degree the top two knobs from 5,000 up.
Starts fine.
Old 04-14-2002, 04:28 AM   #16
KillerTHC
Member#: 4942
01 SRP 2.5 RS-T
if anyone cares i have an unused one that i am willing to sell.
Old 04-14-2002, 05:59 AM   #17
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
the new J&S V2 does not pull timing unless you are in boost therefore you are not pulling needed timing while cruising when you want full timing advance. It has an onboard 2 bar map sensor to monitor intake pressure and detect boost. You can select how many degrees of timing you want to pull per PSI of boot from 1-4 IIRC up to a total of 20 degrees over 6 PSI range. THis is what i plan to run..
jeremy
Old 04-16-2002, 02:33 PM   #18
racerwad
Member#: 2564
Question MSD?
what about MSD's timing control computer. it appears to be well engineered and made by a reputable company. i think i may look into that. does anyone have any experience with this product? thanks.
andy
Apexi ITC question Legacy GTR Normally Aspirated with bolt-on Forced Induction Powertrain 23 10-17-2005 05:50 AM
LI: Apexi SAFC2 AND Apexi ITC Pat L.I. Private 'For Sale' Classifieds 5 01-31-2005 04:42 PM
apexi ITC manual??? bondango Engine Management & Tuning 4 06-25-2003 08:45 AM
Is anyone using an Apexi ITC on their WRX? kenshiro Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 05-01-2003 01:51 PM
J & S safegaurd and apexi ITC cvcsmkr Normally Aspirated with bolt-on Forced Induction Powertrain 16 09-02-2002 03:18 PM
