Go Back   NASIOC > NASIOC General > Motorsports > Autocross
Old 03-08-2009, 03:10 PM   #1
operating engineer
Member#: 62893
2008 STi
Default Too cold for R compound?
First event is coming up next Sat. Forcast is 44 degrees high, what you guys think? I'm running Hankook Z214 245/40/18 (c70), which I gotta scub in Tuesday. Should I just stick with the stock Dunlop in this temp.
operating engineer is offline   Reply With Quote
Old 03-08-2009, 03:18 PM   #2
sachilles
Member#: 115107
02 wrx wagon
61 Morris Mini
You'll have a tough time getting those up to temp, I'd skip using them this time around.
sachilles is offline   Reply With Quote
Old 03-09-2009, 07:42 AM   #3
Craigs
Member#: 24030
07 mazda3
Protoform p2
In the dry, R compounds will always be softer and thus faster than street tires.
Craigs is offline   Reply With Quote
Old 03-09-2009, 07:53 AM   #4
Rexfan
Member#: 50993
02 WRX Wagon
2.5/Blouch Dom 3/Meth/6sp
Start with high air pressures to help get the tires up to temp.
Rexfan is offline   Reply With Quote
Old 03-09-2009, 09:26 AM   #5
racerjon1
Member#: 43612
High pressures will get a single area on the tire up to temp, but will be harder to build the temp up across and through the tire. Lower pressures give less air to heat up heating up a tire faster (then there is also more flex which heats up the tire faster)
I would leave the pressures alone - maybe drop them a pound or two, and just give the first run extra caution.
I have run R-comps when it was as low as 29' outside and that was for a roadrace. For an autocross, I would probably abandon them below 35' but above that I would take my chances.
Jon K
racerjon1 is offline   Reply With Quote
Old 03-09-2009, 09:46 AM   #6
operating engineer
Member#: 62893
2008 STi
I'll problably run them, I'm sure I won't be the only nut out there with them on
Old 03-09-2009, 10:56 AM   #7
wallyman424
Member#: 60357
#17 NASA ST2 Z06
my wang > your wang.
you'll be just fine.
wallyman424 is offline   Reply With Quote
How cold is too cold for Summers? Vacca Rabite Tire & Wheel 18 04-02-2009 06:21 AM
Too Cold for Fiberglass? chewbakarox Car Audio, Video & Security 11 10-21-2004 01:07 PM
What ambient temperature is too cold for R-compounds? Zuffy Motorsports 11 08-21-2004 12:10 PM
What temp is too cold for Raamat install? Rich10 Car Audio, Video & Security 1 10-15-2003 03:57 PM
How cold is too cold for summer tires? roninwarior007 Tire & Wheel 12 10-01-2003 09:12 AM
