Old 03-21-2009, 07:43 AM   #1
Bklynrex
Member#: 189046
2004 Hybrid-WRX
Default 800cc inector map
Hey guys, does anyone know how to get a PE800cc injector map? I have an '04 WRX with a built 2.5L swap and 2.0L heads running Stage 2 BC cams (272/272) (the headgasket I'm using is Cometic 100mm bore, 1.5mm thickness if that matters). I was running 565cc and a td05. Now i went to a Dominator 2.0 with 800cc injectors. Is there anything I can get to drive the car without it being too rich? I'm not going into boost before a tune so all I need is an economy map or just something similar that the car can move. I'm using Cobb V1. Thank you guys in advance (also made this post on open source threads because I can do either cobb or open source)
Bklynrex is offline   Reply With Quote
Old 03-23-2009, 12:00 PM   #3
nme187
Member#: 117763
You'll need a map with those injectors calibrated for; If your going to a ProTuner then hit them up for a base "limp" map. I wouldn't run your motor at all w/o the injectors tuned for, you'll be running pig rich and wash the oil off your walls.
nme187 is offline   Reply With Quote
800cc inector map Bklynrex Open Source Reflashes 3 03-21-2009 12:31 PM
Need VF22 + FMIC + 800cc Injector Map! wrxwhip UTEC 3 06-09-2007 01:47 AM
Need a utec map for 800cc injectors. oldbluwrx Engine Management & Tuning 6 05-15-2004 07:13 PM
RACE EVENT NEED MAP PE1820 800cc SERGEREYES Engine Management & Tuning 2 07-11-2003 12:51 PM
Need UTEC Map Help! Who has 800cc injectors? RobPA Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 03-17-2003 09:28 PM
