Old 03-15-2009, 09:46 AM   #26
AtomicFrawg
Member#: 197739
2009 WRX
Obsidian black pearl
Right the 225 hp run was just a baseline pull with a CAI not tune. The 250hp pull was OTS cobb stage 2 map. The final 270 hp run was the protune.
As soon as its safe (roads dry up) Ill go do a road pull and post the info.
AtomicFrawg is offline   Reply With Quote
Old 03-15-2009, 12:22 PM   #27
panapower
Member#: 158467
2011 several
several cars
Originally Posted by sackytar View Post
Just outta curiosity why do the logs look to turbulent (choppy) vs the other tune?
which graph are you referring to? perhaps I can help answer this question.
panapower is offline   Reply With Quote
Old 03-15-2009, 01:56 PM   #28
AtomicFrawg
Member#: 197739
2009 WRX
I have desided not to post my data. Panapower is my tuner and can answer these questions =)
Old 03-17-2009, 12:31 AM   #29
sodak78
Member#: 53209
2004 protuned FXT
uh... "I won't post it".... That makes no sense, only trying to help.
The way to learn about your car is to understand what the datalogs tell you, not what one person tells you about your datalogs. That is where I was trying to help you out.
I will bet you a nickel you have knock at 3700-3800rpm. Look at your hp curve dip down suddenly, then go up slowly again after the event on your recent tune... I am sure your tuner sees this as well. I would look for a clean datalog with no timing pulls to be entirely happy with any sort of pro-tune.
If you don't want to "share" and get help/comment, why did you post it in this public forum in the first place? This seems like the definition of hypocrisy.
Good luck with your set-up. Very nice increase, none the less.
sodak78 is offline   Reply With Quote
Old 03-17-2009, 07:30 AM   #30
AtomicFrawg
Member#: 197739
2009 WRX
I understand man. And I thank you for your time. But I wanted my tuner to see the data logs before I posted it here. I guess I should have worded that post diff. Plus I have no real way of posting it. I will be glad to send you a copy. Pm me your email addy.
He did give it a clean bill of health and there was no timing being pulled.
Just as a side note. It does the same thing on pretty much all the pulls, even the stock non tuned ecu.
Old 03-17-2009, 10:35 AM   #31
panapower
Member#: 158467
2011 several
several cars
thanks for your insight to this as we are always learning in this tuning world. As was mentioned earlier, we didnt see any type of knock on the logs. What you're looking at on the TQ curve is relative to the spike in the boost levels. If you look at the very next chart you will see as the boost spikes up thus causing the TQ level to also spike at that point. If you look at the OTS run and if you are familiar with what knock looks like on a dyno dynamics chart, there you will see some indications of knock and timing being pulled because of knock. Whereas the protune is nice and smooth.
Old 03-17-2009, 06:58 PM   #32
Lboogie
Member#: 171611
2014 FiST
Blk
So ~325hp/350tq (@ the crank) isn't a good result anymore?
Lboogie is offline   Reply With Quote
Old 03-17-2009, 08:15 PM   #33
sodak78
Member#: 53209
2004 protuned FXT
I am not talking about your trque curve. Look at your hp curve at the aforementioned rpm point out to 4K. Should it rise, then fall by 10-13 hp "mysteriously" right before 4K? If I am wrong, I am wrong. Just trying to help.
Old 03-18-2009, 01:27 AM   #34
CorrPerformance
Member#: 153056
I was just talking to a experienced Subaru tuner about this datalog and he looked at it and gave it the good bill of health on it. He looked at the chart as well and checked out the pimple that was mentioned earlier and concluded to say that it could very well be the way that the new Windows GUI DD interprets the data and draws the charts. Here are the logs from this car on the street a couple days after the actual tune. As I said before there is much for me to still learn about these ECUs and glad that there are ppl here on this forum that take the time to shot constructive critiques to help a fellow member out. At the end we all learn in this journey.
Well I have sat here and tried to properly post the datalog, but to no avail last night. I woke up this morning and figured it out. The owner dataloged many sensors, but I only posted the ones that actually are important to see what the ECU is doing. If any one has any further question, please dont hesitate to ask.
Code:
(RPM) (load)  (DAM)  	IgAdv.  LIgn.  	KC  	KL  	(PSI)  	(AFR)  	MAF  	ECT  	IAT  	VSS
731  	0.26  	1  	15  	0  	0  	0  	-10.15  14.15  	1.18  	190.4  	80.6  	0
731 	0.27 	1 	14 	0 	0 	0 	-10.01 	14.15 	1.24 	190.4 	80.6 	0
734 	0.27 	1 	13.5 	0 	0 	0 	-10.01 	14.26 	1.18 	190.4 	80.6 	0
742 	0.28 	1 	12.5 	0 	0 	0 	-10.01 	14.26 	1.24 	190.4 	80.6 	0
765 	0.27 	1 	10.5 	0 	0 	0 	-10.01 	14.38 	1.24 	190.4 	80.6 	0
773 	0.3 	1 	13 	0 	0 	0 	-9.57 	14.26 	1.26 	190.4 	80.6 	0
740 	0.51 	1 	24.5 	0 	0 	0 	-7.25 	14.61 	2.16 	190.4 	80.6 	0
1499 	0.75 	1 	22.5 	2.5 	0 	0 	-3.19 	14.84 	2 	192.2 	80.6 	1.86
1697 	0.53 	1 	37.5 	0 	0 	0 	-6.82 	14.38 	1.86 	192.2 	80.6 	3.11
1138 	0.57 	1 	36.5 	0.5 	0 	0 	-6.38 	14.26 	1.74 	192.2 	78.8 	4.97
1086 	0.64 	1 	31.5 	1.5 	0 	0 	-5.08 	14.72 	1.8 	192.2 	78.8 	6.21
1199 	0.65 	1 	31 	1.5 	0 	0 	-4.93 	14.26 	1.84 	192.2 	78.8 	7.46
1427 	0.63 	1 	31 	1.5 	0 	0 	-5.22 	14.15 	1.92 	192.2 	78.8 	8.7
1610 	0.64 	1 	28.5 	1.5 	0 	0 	-5.66 	15.18 	1.9 	192.2 	78.8 	9.94
1824 	0.59 	1 	33 	1 	0 	0 	-5.8 	14.38 	2.04 	192.2 	77 	11.18
2060 	0.66 	1 	29 	1.5 	0 	0 	-4.64 	14.61 	2.2 	192.2 	77 	12.43
2380 	0.9 	1 	24.5 	3.5 	0 	0 	-2.61 	15.3 	2.58 	192.2 	77 	14.29
2821 	1.09 	1 	28 	4 	0 	0 	-1.02 	14.26 	2.8 	192.2 	75.2 	16.78
3359 	1.17 	1 	32.5 	4 	0 	0 	0.44 	14.61 	3.02 	192.2 	73.4 	19.88
3952 	1.36 	1 	29 	5 	0 	0 	1.89 	14.38 	3.32 	192.2 	73.4 	23.61
4671 	1.71 	1 	25 	5.5 	0 	0 	4.5 	12.99 	3.7 	192.2 	71.6 	27.96
5470 	1.81 	1 	24.5 	5 	0 	0 	5.51 	11.15 	3.88 	194 	71.6 	32.93
6276 	1.76 	1 	27 	4 	0 	0 	5.51 	11.15 	3.96 	194 	69.8 	37.9
6590 	0.55 	1 	16.5 	0 	0 	0 	-8.12 	11.15 	2.06 	194 	71.6 	39.77
5589 	0.2 	1 	26.5 	0 	0 	0 	-10.88 	14.49 	2.22 	194 	71.6 	39.77
4117 	1.29 	1 	28.5 	4.5 	0 	0 	1.31 	14.49 	3.46 	194 	73.4 	41.63
4506 	2.5 	1 	16 	6 	0 	0 	12.04 	11.15 	4.16 	194 	73.4 	45.36
5048 	2.76 	1 	15 	6 	0 	0 	15.37 	11.15 	4.34 	194 	73.4 	50.33
5513 	2.81 	1 	14 	6 	0 	0 	15.95 	11.15 	4.42 	194 	73.4 	55.3
5992 	2.77 	1 	14.5 	6 	0 	0 	15.66 	11.15 	4.52 	194 	73.4 	59.65
6393 	2.63 	1 	16.5 	5.5 	0 	0 	14.5 	11.15 	4.54 	194 	73.4 	64
6780 	2.48 	1 	18 	5 	0 	0 	13.92 	11.15 	4.46 	194 	75.2 	67.73
6288 	0.17 	1 	16.5 	0 	0 	0 	-10.59 	12.88 	1.94 	194 	75.2 	68.35
4850 	0.22 	1 	16.5 	0 	0 	0 	-10.88 	20.35 	2 	194 	77 	67.73
4651 	0.22 	1 	24 	0 	0 	0 	-11.17 	20.35 	1.96 	194 	77 	66.49
4489 	0.22 	1 	24 	0 	0 	0 	-11.31 	20.35 	1.94 	194 	77 	65.24
4446 	0.22 	1 	24 	0 	0 	0 	-11.31 	20.35 	1.92 	194 	78.8 	64
4352 	0.21 	1 	24 	0 	0 	0 	-11.31 	20.35 	1.92 	194 	78.8 	62.76
4219 	0.21 	1 	24 	0 	0 	0 	-11.31 	20.35 	1.9 	194 	78.8 	61.52
4126 	0.21 	1 	24 	0 	0 	0 	-11.17 	20.35 	1.9 	194 	78.8 	59.65
4000 	0.21 	1 	24 	0 	0 	0 	-11.17 	20.35 	1.88 	194 	78.8 	57.79
3845 	0.22 	1 	24 	0 	0 	0 	-11.02 	20.35 	1.84 	194 	78.8 	55.92
3728 	0.22 	1 	24 	0 	0 	0 	-10.88 	20.35 	1.86 	194 	78.8 	53.44
3577 	0.22 	1 	24 	0 	0 	0 	-10.88 	20.35 	1.78 	192.2 	78.8 	51.57
3446 	0.22 	1 	24 	0 	0 	0 	-10.73 	20.35 	1.8 	192.2 	78.8 	49.71
3321 	0.22 	1 	24 	0 	0 	0 	-10.59 	20.35 	1.8 	192.2 	78.8 	47.85
3191 	0.23 	1 	24 	0 	0 	0 	-10.59 	20.35 	1.78 	192.2 	78.8 	45.98
3050 	0.22 	1 	24 	0 	0 	0 	-10.59 	20.35 	1.72 	190.4 	78.8 	44.12
2905 	0.22 	1 	24 	0 	0 	0 	-10.59 	20.35 	1.72 	190.4 	78.8 	42.25
2785 	0.21 	1 	24 	0 	0 	0 	-10.73 	20.35 	1.7 	190.4 	78.8 	40.39
2660 	0.22 	1 	24 	0 	0 	0 	-10.73 	20.35 	1.68 	188.6 	78.8 	37.9
2528 	0.23 	1 	24 	0 	0 	0 	-10.73 	20.35 	1.68 	188.6 	78.8 	36.04
2380 	0.23 	1 	24 	0 	0 	0 	-10.73 	20.35 	1.66 	188.6 	78.8 	34.18
2261 	0.24 	1 	24 	0 	0 	0 	-10.73 	20.35 	1.62 	188.6 	78.8 	32.31
2116 	0.24 	1 	24 	0 	0 	0 	-10.59 	20.35 	1.58 	186.8 	78.8 	30.45
1726 	0.25 	1 	21.5 	0 	0 	0 	-10.44 	20.35 	1.52 	186.8 	78.8 	28.58
1236 	0.25 	1 	12.5 	0 	0 	0 	-10.59 	20.35 	1.32 	186.8 	78.8 	26.72
914 	0.27 	1 	12 	0 	0 	0 	-10.15 	20.35 	1.32 	186.8 	78.8 	24.23
1080 	0.26 	1 	12 	0 	0 	0 	-10.3 	20.35 	1.28 	186.8 	78.8 	21.13
1085 	0.24 	1 	12 	0 	0 	0 	-10.59 	13.45 	1.28 	185 	80.6 	18.02
1005 	0.24 	1 	12 	0 	0 	0 	-10.59 	13.69 	1.28 	185 	80.6 	14.29
904 	0.27 	1 	12 	0 	0 	0 	-10.3 	14.49 	1.3 	185 	80.6 	10.56
918 	0.28 	1 	16 	0 	0 	0 	-10.3 	14.49 	1.26 	185 	80.6 	8.08
999 	0.24 	1 	14 	0 	0 	0 	-10.44 	13.91 	1.24 	185 	80.6 	4.97
761 	0.24 	1 	16 	0 	0 	0 	-10.3 	13.8 	1.26 	185 	80.6 	4.97
775 	0.35 	1 	21.5 	0 	0 	0 	-9.14 	15.3 	1.42 	185 	80.6 	4.97
879 	0.56 	1 	32 	1 	0 	0 	-5.95 	15.87 	2.38 	185 	80.6 	5.59
1270 	0.89 	1 	15.5 	4 	0 	0 	-1.74 	13.57 	2.02 	185 	80.6 	7.46
1668 	0.84 	1 	21 	3 	0 	0 	-2.9 	14.61 	2.18 	185 	80.6 	9.94
2006 	0.85 	1 	26 	3.5 	0 	0 	-3.05 	14.38 	2.3 	185 	78.8 	12.43
2315 	0.85 	1 	23.5 	3 	0 	0 	-3.48 	14.95 	2.44 	185 	77 	14.29
2667 	0.84 	1 	32.5 	2.5 	0 	0 	-3.92 	14.26 	2.52 	185 	77 	16.16
2990 	0.86 	1 	38 	1 	0 	0 	-3.63 	14.72 	2.6 	185 	75.2 	18.02
3348 	0.9 	1 	38 	0 	0 	0 	-3.05 	14.26 	2.76 	185 	73.4 	19.88
3788 	0.99 	1 	36 	1 	0 	0 	-2.03 	14.49 	2.96 	185 	73.4 	22.99
4247 	1.1 	1 	30.5 	2.5 	0 	0 	-1.45 	15.18 	3.32 	185 	71.6 	25.48
4877 	1.55 	1 	27.5 	5.5 	0 	0 	2.9 	12.53 	3.64 	185 	69.8 	29.2
5575 	1.52 	1 	27.5 	5 	0 	0 	2.61 	11.39 	3.72 	185 	69.8 	33.55
5798 	0.39 	1 	34 	0 	0 	0 	-9.72 	11.15 	1.98 	185 	69.8 	35.42
5232 	0.22 	1 	31.5 	0 	0 	0 	-10.88 	16.22 	3.04 	185 	69.8 	36.04
3875 	1.59 	1 	10.5 	5 	0 	0 	4.79 	13.8 	3.6 	185 	69.8 	38.52
4280 	2.81 	1 	15.5 	6 	0 	0 	15.66 	11.15 	4.22 	185 	69.8 	43.5
4820 	3.03 	1 	15 	6 	0 	0 	17.84 	11.15 	4.36 	185 	71.6 	48.47
5373 	2.96 	1 	14.5 	6 	0 	0 	17.4 	11.15 	4.5 	185 	71.6 	54.06
5820 	2.87 	1 	13.5 	6 	0 	0 	16.39 	11.15 	4.56 	186.8 	73.4 	58.41
6276 	2.67 	1 	16 	6 	0 	0 	14.79 	11.15 	4.56 	186.8 	73.4 	62.76
6321 	0.71 	1 	24 	0 	0 	0 	-6.96 	11.15 	1.92 	186.8 	73.4 	65.24
4847 	1.09 	1 	28 	3 	0 	0 	0.58 	14.95 	3.6 	186.8 	75.2 	65.87
4714 	2.94 	1 	15 	6 	0 	0 	17.26 	11.73 	4.38 	186.8 	75.2 	68.35
4987 	3.05 	1 	15 	6 	0 	0 	19 	11.15 	4.42 	186.8 	73.4 	72.08
5180 	3.01 	1 	15 	6 	0 	0 	18.42 	11.15 	4.48 	186.8 	73.4 	75.81
5472 	2.96 	1 	14 	6 	0 	0 	18.13 	11.15 	4.52 	188.6 	73.4 	79.54
5676 	2.93 	1 	14 	6 	0 	0 	17.55 	11.15 	4.54 	188.6 	71.6 	82.64
5896 	2.65 	1 	16 	6 	0 	0 	16.24 	11.15 	4.28 	188.6 	71.6 	85.75
5486 	0.21 	1 	23 	0 	0 	0 	-10.44 	13.34 	2 	188.6 	71.6 	85.13
4590 	0.19 	1 	15.5 	0 	0 	0 	-11.31 	20.35 	1.92 	188.6 	73.4 	84.51
3951 	0.22 	1 	24 	0 	0 	0 	-11.02 	20.35 	1.88 	188.6 	73.4 	83.88
3403 	0.23 	1 	24 	0 	0 	0 	-10.59 	20.35 	1.82 	188.6 	73.4 	82.64
4112 	0.21 	1 	24 	0 	0 	0 	-11.31 	20.35 	1.9 	188.6 	73.4 	81.4
4152 	0.21 	1 	24 	0 	0 	0 	-11.31 	20.35 	1.86 	188.6 	75.2 	80.16
4058 	0.21 	1 	24 	0 	0 	0 	-11.31 	20.35 	1.84 	188.6 	75.2 	78.29
3954 	0.22 	1 	24 	0 	0 	0 	-11.17 	20.35 	1.86 	188.6 	75.2 	76.43
3854 	0.21 	1 	24 	0 	0 	0 	-11.17 	20.35 	1.84 	188.6 	75.2 	74.56
3748 	0.21 	1 	24 	0 	0 	0 	-11.02 	20.35 	1.84 	188.6 	75.2 	72.7
3645 	0.22 	1 	24 	0 	0 	0 	-11.02 	20.35 	1.82 	188.6 	75.2 	70.21
3572 	0.22 	1 	24 	0 	0 	0 	-10.88 	20.35 	1.82 	186.8 	75.2 	68.35
3479 	0.22 	1 	24 	0 	0 	0 	-10.73 	20.35 	1.8 	186.8 	75.2 	66.49
3349 	0.22 	1 	24 	0 	0 	0 	-10.73 	20.35 	1.78 	186.8 	75.2 	64.62
3261 	0.22 	1 	24 	0 	0 	0 	-10.73 	20.35 	1.78 	186.8 	75.2 	62.76
3188 	0.22 	1 	24 	0 	0 	0 	-10.73 	20.35 	1.76 	185 	75.2 	61.52
3113 	0.22 	1 	24 	0 	0 	0 	-10.73 	20.35 	1.76 	185 	75.2 	60.27
3084 	0.22 	1 	24 	0 	0 	0 	-10.59 	20.35 	1.74 	185 	75.2 	59.03
3011 	0.22 	1 	24 	0 	0 	0 	-10.59 	20.35 	1.72 	185 	75.2 	58.41
2978 	0.22 	1 	24 	0 	0 	0 	-10.59 	20.35 	1.72 	185 	75.2 	57.17
Thanks,
Alberto
CorrPerformance is offline   Reply With Quote
Old 03-18-2009, 07:40 AM   #35
AtomicFrawg
Member#: 197739
2009 WRX
Thanks Alberto and Jay. I had no doubt that You guys would not have let me leave if you thought it was not right.
Chris
Old 03-18-2009, 09:12 AM   #36
CorrPerformance
Member#: 153056
Code:
2913  	0.21  	1  	24  	0  	0  	0  	-10.73  20.35  	1.72  	183.2  	75.2  	56.54
2862 	0.21 	1 	24 	0 	0 	0 	-10.73 	20.35 	1.7 	183.2 	75.2 	55.3
2830 	0.21 	1 	24 	0 	0 	0 	-10.88 	20.35 	1.68 	183.2 	75.2 	54.68
2792 	0.22 	1 	24 	0 	0 	0 	-10.73 	20.35 	1.68 	183.2 	75.2 	54.06
2742 	0.22 	1 	24 	0 	0 	0 	-10.88 	20.35 	1.68 	183.2 	75.2 	53.44
2731 	0.22 	1 	24 	0 	0 	0 	-10.73 	20.35 	1.68 	181.4 	75.2 	52.82
2684 	0.22 	1 	24 	0 	0 	0 	-10.73 	20.35 	1.66 	181.4 	75.2 	52.2
2730 	0.4 	1 	16.5 	0 	0 	0 	-8.12 	20.35 	2.34 	181.4 	75.2 	51.57
2687 	0.63 	1 	38 	1 	0 	0 	-6.38 	17.02 	2.3 	181.4 	73.4 	51.57
2680 	0.62 	1 	44 	0 	0 	0 	-6.82 	14.49 	2.24 	181.4 	73.4 	52.2
2684 	0.62 	1 	45 	0 	0 	0 	-6.82 	14.61 	2.26 	181.4 	73.4 	52.2
2694 	0.63 	1 	45 	0 	0 	0 	-6.53 	14.61 	2.3 	179.6 	71.6 	52.2
2725 	0.67 	1 	45 	0 	0 	0 	-6.09 	14.38 	2.32 	179.6 	71.6 	52.2
2732 	0.93 	1 	36.5 	2 	0 	0 	-2.9 	15.41 	2.72 	179.6 	71.6 	52.82
2765 	1.08 	1 	31.5 	3.5 	0 	0 	-1.45 	14.15 	2.7 	179.6 	69.8 	53.44
2807 	0.74 	1 	44.5 	0 	0 	0 	-5.22 	14.72 	2.14 	179.6 	69.8 	54.06
2794 	0.33 	1 	45 	0 	0 	0 	-9.57 	14.15 	1.76 	179.6 	69.8 	54.06
2780 	0.21 	1 	27.5 	0 	0 	0 	-10.88 	14.49 	1.68 	179.6 	69.8 	54.06
2761 	0.21 	1 	24 	0 	0 	0 	-10.73 	20.35 	1.7 	179.6 	69.8 	53.44
2744 	0.22 	1 	24 	0 	0 	0 	-10.73 	20.35 	1.68 	179.6 	69.8 	52.82
2715 	0.22 	1 	24 	0 	0 	0 	-10.73 	20.35 	1.68 	177.8 	69.8 	52.2
2696 	0.22 	1 	24 	0 	0 	0 	-10.73 	20.35 	1.7 	177.8 	69.8 	52.2
2651 	0.22 	1 	24 	0 	0 	0 	-10.73 	20.35 	1.68 	177.8 	71.6 	51.57
2625 	0.23 	1 	24 	0 	0 	0 	-10.73 	20.35 	1.68 	177.8 	71.6 	50.95
2620 	0.23 	1 	24 	0 	0 	0 	-10.73 	20.35 	1.68 	177.8 	71.6 	50.33
2584 	0.23 	1 	24 	0 	0 	0 	-10.73 	20.35 	1.68 	177.8 	71.6 	50.33
2562 	0.23 	1 	24 	0 	0 	0 	-10.73 	20.35 	1.66 	177.8 	71.6 	49.71
2551 	0.22 	1 	24 	0 	0 	0 	-10.73 	20.35 	1.68 	177.8 	71.6 	49.09
2530 	0.33 	1 	28.5 	0 	0 	0 	-9.43 	20.35 	2 	177.8 	71.6 	49.09
2533 	0.39 	1 	32.5 	0 	0 	0 	-9.14 	16.44 	1.94 	177.8 	71.6 	49.09
2511 	0.34 	1 	32.5 	0 	0 	0 	-9.72 	14.38 	1.82 	177.8 	71.6 	48.47
2516 	0.25 	1 	31 	0 	0 	0 	-10.73 	13.69 	1.64 	177.8 	71.6 	48.47
2496 	0.23 	1 	24 	0 	0 	0 	-10.88 	15.53 	1.68 	177.8 	71.6 	47.85
2478 	0.23 	1 	24 	0 	0 	0 	-10.88 	20.35 	1.66 	177.8 	71.6 	47.85
2448 	0.23 	1 	24 	0 	0 	0 	-10.73 	20.35 	1.66 	177.8 	71.6 	47.22
2401 	0.23 	1 	24 	0 	0 	0 	-10.73 	20.35 	1.66 	177.8 	71.6 	46.6
2359 	0.23 	1 	24 	0 	0 	0 	-10.73 	20.35 	1.64 	177.8 	71.6 	45.36
2288 	0.23 	1 	24 	0 	0 	0 	-10.73 	20.35 	1.6 	177.8 	71.6 	44.12
2207 	0.23 	1 	24 	0 	0 	0 	-10.88 	20.35 	1.6 	177.8 	71.6 	42.87
2114 	0.24 	1 	24 	0 	0 	0 	-10.73 	20.35 	1.6 	176 	71.6 	41.01
2034 	0.24 	1 	24 	0 	0 	0 	-10.73 	20.35 	1.58 	176 	71.6 	38.52
1716 	0.24 	1 	21.5 	0 	0 	0 	-10.59 	20.35 	1.48 	176 	71.6 	36.66
1246 	0.24 	1 	12 	0 	0 	0 	-10.73 	20.35 	1.28 	176 	71.6 	33.55
954 	0.24 	1 	12 	0 	0 	0 	-10.59 	20.35 	1.26 	176 	73.4 	31.07
1248 	0.2 	1 	14 	0 	0 	0 	-11.02 	20.35 	1.26 	176 	73.4 	28.58
1909 	0.19 	1 	24 	0 	0 	0 	-11.17 	13.8 	1.54 	176 	73.4 	24.85
2365 	0.22 	1 	24 	0 	0 	0 	-11.17 	15.3 	1.62 	176 	73.4 	21.75
2179 	0.2 	1 	24 	0 	0 	0 	-11.46 	14.61 	1.48 	176 	73.4 	19.26
1817 	0.2 	1 	24 	0 	0 	0 	-11.17 	14.61 	1.52 	176 	73.4 	16.78
1737 	0.21 	1 	23 	0 	0 	0 	-11.17 	15.07 	1.46 	176 	73.4 	15.53
2264 	0.34 	1 	8.5 	0 	0 	0 	-9.14 	14.26 	2.28 	176 	73.4 	13.67
2342 	0.42 	1 	32.5 	0 	0 	0 	-8.56 	13.91 	1.92 	176 	73.4 	14.91
2497 	0.5 	1 	33 	0 	0 	0 	-7.83 	14.84 	2.3 	176 	71.6 	14.91
2793 	0.9 	1 	30 	3 	0 	0 	-3.34 	14.38 	2.6 	176 	71.6 	16.78
3229 	1 	1 	33 	2 	0 	0 	-1.89 	14.72 	2.88 	176 	69.8 	19.26
3723 	1.31 	1 	30 	5 	0 	0 	1.31 	14.61 	3.3 	176 	68 	22.37
4624 	2.15 	1 	21 	5.5 	0 	0 	8.41 	12.88 	4.02 	176 	66.2 	27.96
5644 	2.35 	1 	17 	5 	0 	0 	10.73 	11.27 	4.26 	176 	66.2 	34.18
6531 	2.13 	1 	24 	4.5 	0 	0 	9.14 	11.15 	4.24 	176 	64.4 	39.77
6159 	0.17 	1 	16.5 	0 	0 	0 	-10.73 	12.31 	1.98 	176 	66.2 	41.01
4356 	1.75 	1 	23 	5.5 	0 	0 	4.79 	14.03 	3.84 	176 	66.2 	43.5
4848 	3.1 	1 	15 	6 	0 	0 	18.56 	11.15 	4.44 	176 	68 	49.09
5394 	3.05 	1 	15 	6 	0 	0 	18.13 	11.15 	4.54 	176 	68 	54.06
5858 	2.88 	1 	14 	6 	0 	0 	16.53 	11.15 	4.58 	176 	68 	59.03
6317 	2.73 	1 	15.5 	6 	0 	0 	15.23 	11.15 	4.56 	176 	69.8 	63.38
6659 	2.55 	1 	17.5 	5 	0 	0 	14.5 	11.15 	4.48 	176 	69.8 	67.11
6305 	0.22 	1 	16.5 	0 	0 	0 	-10.01 	11.85 	2.04 	176 	69.8 	67.73
5284 	0.2 	1 	16.5 	0 	0 	0 	-11.02 	18.28 	2 	176 	69.8 	66.49
4453 	0.22 	1 	24 	0 	0 	0 	-11.46 	20.35 	1.92 	176 	71.6 	63.38
4188 	0.22 	1 	24 	0 	0 	0 	-11.46 	20.35 	1.88 	176 	71.6 	60.27
3959 	0.21 	1 	24 	0 	0 	0 	-11.31 	20.35 	1.86 	176 	71.6 	57.17
3770 	0.21 	1 	24 	0 	0 	0 	-11.17 	20.35 	1.84 	176 	71.6 	54.06
3598 	0.22 	1 	24 	0 	0 	0 	-11.02 	20.35 	1.8 	177.8 	73.4 	51.57
3420 	0.21 	1 	24 	0 	0 	0 	-11.02 	20.35 	1.8 	177.8 	73.4 	49.71
3264 	0.22 	1 	24 	0 	0 	0 	-10.73 	20.35 	1.76 	177.8 	73.4 	47.22
3158 	0.22 	1 	24 	0 	0 	0 	-10.73 	20.35 	1.72 	177.8 	73.4 	45.98
3105 	0.21 	1 	24 	0 	0 	0 	-10.73 	20.35 	1.72 	177.8 	73.4 	45.36
3038 	0.21 	1 	24 	0 	0 	0 	-10.88 	20.35 	1.72 	177.8 	73.4 	44.12
2979 	0.21 	1 	24 	0 	0 	0 	-10.73 	20.35 	1.7 	177.8 	73.4 	43.5
2914 	0.21 	1 	24 	0 	0 	0 	-10.88 	20.35 	1.7 	179.6 	73.4 	42.25
2856 	0.21 	1 	24 	0 	0 	0 	-11.02 	20.35 	1.68 	179.6 	73.4 	41.01
2778 	0.21 	1 	24 	0 	0 	0 	-11.02 	20.35 	1.66 	179.6 	73.4 	39.77
2681 	0.21 	1 	24 	0 	0 	0 	-11.02 	20.35 	1.66 	179.6 	73.4 	38.52
2592 	0.21 	1 	24 	0 	0 	0 	-10.88 	20.35 	1.66 	179.6 	73.4 	37.28
2528 	0.22 	1 	24 	0 	0 	0 	-11.02 	20.35 	1.66 	179.6 	73.4 	36.66
2496 	0.22 	1 	24 	0 	0 	0 	-10.88 	20.35 	1.64 	179.6 	73.4 	36.04
2451 	0.22 	1 	24 	0 	0 	0 	-10.88 	20.35 	1.6 	179.6 	73.4 	35.42
2376 	0.22 	1 	24 	0 	0 	0 	-10.88 	20.35 	1.62 	179.6 	73.4 	34.8
2320 	0.22 	1 	24 	0 	0 	0 	-10.88 	20.35 	1.6 	179.6 	73.4 	33.55
2268 	0.22 	1 	24 	0 	0 	0 	-10.88 	20.35 	1.6 	179.6 	73.4 	32.93
2220 	0.23 	1 	24 	0 	0 	0 	-10.88 	20.35 	1.6 	179.6 	73.4 	32.31
2189 	0.22 	1 	24 	0 	0 	0 	-11.02 	20.35 	1.58 	179.6 	73.4 	31.69
2155 	0.23 	1 	24 	0 	0 	0 	-10.88 	20.35 	1.6 	179.6 	73.4 	31.07
2123 	0.22 	1 	24 	0 	0 	0 	-10.88 	20.35 	1.56 	179.6 	73.4 	30.45
2089 	0.22 	1 	24 	0 	0 	0 	-10.88 	20.35 	1.58 	179.6 	73.4 	29.83
2041 	0.23 	1 	24 	0 	0 	0 	-10.73 	20.35 	1.56 	179.6 	73.4 	29.83
2019 	0.23 	1 	24 	0 	0 	0 	-10.73 	20.35 	1.56 	179.6 	73.4 	29.2
2077 	0.96 	1 	18 	3.5 	0 	0 	-1.31 	20.35 	2.42 	179.6 	73.4 	29.83
2139 	1.07 	1 	26 	4 	0 	0 	-0.87 	14.49 	2.56 	179.6 	71.6 	31.07
2220 	1.13 	1 	26 	4.5 	0 	0 	-0.73 	14.49 	2.58 	179.6 	71.6 	32.31
2317 	1.11 	1 	27.5 	4.5 	0 	0 	-1.02 	14.49 	2.58 	179.6 	69.8 	33.55
2402 	0.83 	1 	41 	1 	0 	0 	-4.5 	14.61 	2.06 	179.6 	69.8 	34.8
Old 03-18-2009, 09:19 AM   #37
CorrPerformance
Member#: 153056
Code:
3007  	1.08  	1  	32  	3.5  	0  	0  	-1.16  	14.72  	2.86  	183.2  	66.2  	30.45
3244 	1.28 	1 	27 	5 	0 	0 	1.31 	14.03 	3.08 	183.2 	66.2 	32.31
3498 	1.61 	1 	23 	6 	0 	0 	4.06 	13.23 	3.36 	183.2 	64.4 	35.42
3849 	2.2 	1 	20 	6.5 	0 	0 	9.72 	11.15 	3.8 	183.2 	64.4 	39.15
4333 	2.52 	1 	16 	6 	0 	0 	11.31 	11.15 	4 	183.2 	64.4 	43.5
4753 	2.42 	1 	16.5 	5.5 	0 	0 	10.88 	11.15 	4.04 	183.2 	64.4 	47.85
5155 	2.4 	1 	17.5 	6 	0 	0 	11.02 	11.15 	4.2 	183.2 	64.4 	52.2
5568 	2.41 	1 	17 	5.5 	0 	0 	11.02 	11.15 	4.24 	183.2 	64.4 	55.92
5918 	2.38 	1 	17 	5.5 	0 	0 	10.88 	11.15 	4.34 	183.2 	64.4 	59.65
6313 	2.24 	1 	20.5 	5 	0 	0 	9.86 	11.15 	4.32 	183.2 	66.2 	62.76
6527 	1.82 	1 	28 	4 	0 	0 	4.64 	11.15 	3.18 	183.2 	66.2 	65.87
5979 	0.17 	1 	24 	0 	0 	0 	-11.17 	12.65 	2.06 	183.2 	66.2 	65.24
4637 	2.28 	1 	17 	5.5 	0 	0 	9.57 	13.45 	4.26 	183.2 	66.2 	67.73
4911 	3.2 	1 	15 	6 	0 	0 	19.58 	11.15 	4.46 	183.2 	66.2 	71.46
5124 	3.16 	1 	15.5 	6 	0 	0 	18.85 	11.15 	4.54 	183.2 	66.2 	75.19
5377 	3.09 	1 	15.5 	6 	0 	0 	18.13 	11.15 	4.54 	183.2 	66.2 	78.91
5638 	3.02 	1 	14.5 	6 	0 	0 	17.55 	11.15 	4.56 	185 	66.2 	82.02
5844 	2.6 	1 	17 	6 	0 	0 	14.79 	11.15 	4.26 	185 	66.2 	85.13
5848 	0.34 	1 	30 	0 	0 	0 	-9.72 	12.65 	1.98 	185 	66.2 	84.51
5679 	0.19 	1 	24 	0 	0 	0 	-11.31 	20.35 	2.02 	185 	66.2 	82.02
5514 	0.19 	1 	24 	0 	0 	0 	-11.46 	20.35 	1.98 	185 	66.2 	79.54
5248 	0.2 	1 	24 	0 	0 	0 	-11.46 	20.35 	2 	185 	68 	76.43
5021 	0.2 	1 	24 	0 	0 	0 	-11.46 	20.35 	1.98 	185 	68 	72.7
4744 	0.21 	1 	24 	0 	0 	0 	-11.46 	20.35 	1.98 	185 	68 	69.59
This should be the zones where he was doing WOT, the rest of the datalog shows nothing but vacuum zones and cruising.
Old 03-20-2009, 12:17 AM   #38
bboylocob
Member#: 151809
2007 WRX
i believe it is the way the new dd software interpets the data. Mine does the same and is knock free on more then 1 street log. I have done several and on differ days in differ temps and have been knock free. I sec. These guys they are great guys and great tuners they are very picky when it comes to tunning meaning the write every change they make down.and will not stop till it is done right.
bboylocob is offline   Reply With Quote
Old 03-21-2009, 01:22 PM   #39
sackytar
Member#: 149262
03WR Rally/XTDD/98SJ
PrimerGrey
Nice I wish those guys were in Mi. With that said whos knows a good tuner relatively close to Grand Rapids Mi???
sackytar is offline   Reply With Quote
will 08/09 sti side skirts fit 08/09 wrx sedan? slowgrey08 Newbies & FAQs 3 08-04-2015 08:24 AM
09 sti front bumper on a 09 wrx sedan? jburke Interior & Exterior Modification 4 09-15-2009 07:55 PM
Available brake upgrades,09 WRX ? ? Brack Brakes, Steering & Suspension 5 02-13-2009 04:31 PM
Lips for 09 WRX Sedan joshua27 Interior & Exterior Modification 2 01-13-2009 04:46 PM
Anyone else local (DC area) have an 09 WRX sedan? irish44j Mid Atlantic Impreza Club -- MAIC 3 10-13-2008 05:18 PM
