Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 03-08-2009, 10:36 PM   #1
wrxdrivr04
Member#: 156619
2004 WRX 2.5 hybrid
FP EVOIII 16g
Question TGV delete question::: please HELP
ok so here my question to you guys... i am in the process of Doing a 2.5 hybrid in my 04 wrx, im going with sti s/b,stock wrx, fp evoIII 16g (IWG), modd wrx injectors, Walboro, sr*s turbo back, megan racing header and up pipe, Utec delta EM, my question is do you believe it is a good idea to do the TGV deletes , this is going to be daily driven for the most part?
wrxdrivr04 is offline   Reply With Quote
Old 03-08-2009, 10:58 PM   #2
305mouse
Member#: 106792
2005 Saab 92X
Stage Pi w/ VF35
I did the TGV's on my car. During cold starts, the car doesn't respond well till after about a half mile. Then it drives great. On nice cold winter days where it's below 20, it takes a little longer and the car feels like it's gonna stall out, but never does. Just want to forwarn you. I think it's a good thing to do, more airflow into the engine, less restriction.
305mouse is offline   Reply With Quote
Old 03-09-2009, 12:53 AM   #3
Thug Nasty
Member#: 128492
Chapter/Region: HIIC
2002 WRX - Hybrid
less restrictive air flow can't hurt.
Thug Nasty is offline   Reply With Quote
Old 03-09-2009, 08:41 AM   #4
DanBelford
Member#: 30516
2003 WRX
Do it for sure! With all that stuff you are installing, the TGV's should be removed in order for you to sleep at night. If you want to avoid any possible CEL lights just leave the rds and sensor in. Or you can remove everything and get the holes wellded up. I assume you are going to get a custome tune for a AP or EcuTek? Justa talk to hwoever is doing the tune for you about what they are comfertable with and your done. I left the rods inplace with the sensors, the car drives great and has no problems in the cold. The only thinng is that it takes like one or two extra cranks to start in the morning.
DanBelford is offline   Reply With Quote
TGV deletes, and then a boat load of fail. Please help make my car run nicely again. 573 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 11 04-03-2010 11:15 AM
noob with TGV deletes, please help. ravenlunatic Newbies & FAQs 14 06-15-2009 05:28 PM
tgv deletes? will it help my cel codes go bye bye ultramagnus Newbies & FAQs 7 08-14-2007 02:19 PM
APS TGV Delete servo install help!!!!!! All4bSpinnin Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 04-21-2007 01:54 PM
JDM TGV delete concern....please help swift2fly Subaru Conversions 2 05-16-2006 03:37 PM
