Old 12-17-2009, 08:32 PM   #76
2shea
Member#: 216489
2007 STI
Originally Posted by hybrid gti 2 View Post
Been thinking of making some for my rpm sub frame. Where would I get the sheet metal?
onlinemetals.com sells aluminum sheets for cheaper than anywhere else I've seen. Check out the web for deals near you. Just remember that the stronger the metal you use the thinner and lighter of a piece you can use for the same protection. The last thing any of us wants is extra weight up front in an already front heavy car. I know "Opinions are like ********. Everyone got one and no one wants to here yours." but just do the research and find out what is right for your budget and skill set and you can't go wrong. If I was Bill Gates I would use titanium. Paul Allen stainless steel. But I think aluminum fits most budgets.
2shea is offline   Reply With Quote
Old 12-17-2009, 10:46 PM   #77
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
yea I think aluminum is fine. I just want to protect the engine area.
Old 02-24-2010, 08:50 PM   #78
MainFrame
Member#: 218739
2002 WRX hybrid
bump this because I'm about to make mine..
One thing I didn't see mentioned here is that the more rigid to aluminum is, the more likely it is to crack and break. Personally I would want my skid plate to bend if I hit something, rather than crack, and transfer all the shock to the mounting points. I experienced this first hand with sti aluminum control arms, I hit a curb, and instead of bending the damn thing just snapped in half.
Also, I may be wrong, but I believe 4000 series, and 6000 series aluminum is heat treated. So welding it would ruin the heat treating.
I'm thinking either 3003 or 5052 @ 3/16".. looks like onlinemetals only has 5052 in that thickness, so I might use that if I can't find it cheaper locally.
Does anyone think it would be worth it to hammer dimples into the skidplate? I know some cars are using dimpled underbodys now to improve aerodynamics. I suppose it would probably be pointless work, just wondering what people's thoughts are..
MainFrame is offline   Reply With Quote
Old 02-24-2010, 10:03 PM   #79
02boxer
Member#: 139853
2002 wrx....its tsxy
dimpling probably won't have much is any noticeable or measurable effect...not worth the effort.
Do you think you will be in many situations where you will actually puncture a 3/16" sheet, I mean short of hopping on some small boulders?? Not being a D, just posing a question. It's gonna take a good bit of concentrated force to get through it. Even then, the sheet won't tear. If anything you'll put a patchable hole on it.
However, it seems harder doesn't necessarily mean brittle....it normal climate. 6061 T6 has a shear strength of 30,000 psi, 3003 is generally 23,000 psi at best.
Something to think about
chris
02boxer is offline   Reply With Quote
Old 02-25-2010, 01:29 AM   #80
MainFrame
Member#: 218739
2002 WRX hybrid
Well, 1/8" would probably be fine for me.. I'll just have to see what I can find for cheap locally.
It's not like I plan on hitting anything, but I just had my motor rebuilt, and my headers wrapped.. I had to drive it 100 miles and change the oil for analysis. Between one evening, and the next afternoon, 100 miles, my header wrap is torn to shreds . Which tells me a skid plate is a must. (I was being extra careful not to hit anything)
Really, I just need something to keep water and debris from spraying into the engine compartment, and keep road debris from f***ing up my header wrap.
(right now my headers have about 2" ground clearance, but I'm sure it will be a little better as soon as I switch to my backup suspension while I'm waiting for my coilovers to be overhauled)
Old 02-25-2010, 01:42 AM   #81
02boxer
Member#: 139853
indeed.....unless you are offroading...you wont need to go nutso. I made a 1/8" 6061 sheet....and feel good about it. Don't get mislead by it being 1/8"....its SOLID. Pick up a 3.5'x3.5' sheet.....you'll feel it. It ways a good 10-15 lbs or so
chris
Old 02-25-2010, 01:51 AM   #82
MainFrame
Member#: 218739
2002 WRX hybrid
I'm sure 3003 will be plenty strong as well.. I'll just have to see what I can find for the best price.
Is 3.5' wide enough? I'm wanting to cover as much as possible. I was thinking about starting with a 3'x4', but if I could get away with 3'x3.5'x1/8" of 3003 that shouldn't cost too much.
Old 02-25-2010, 02:26 AM   #83
02boxer
Member#: 139853
i had a 3.5'x3.5' sheet...trimmed the front a bit and the back half corners and it was good....it's about 3.5' rail to rail, measuring from the outsides. The front is notched to accommodate my lightbar and is a tad long (tuck on the inside of the bottom of the bumper)
chris
Old 02-25-2010, 08:53 PM   #84
2shea
Member#: 216489
2007 STI
I made mine last weekend out of .071 thick 7075 T6. It is super light at about five pounds. I beat the hell out of the pieces I cut off to test it and it is plenty strong. Also I jacked up the car with the skid plate and it didn't even leave a mark or a bend. It's 3' x 4' and fits staight under the front bumper without bending which is cool because it takes a super strong break to bend this stuff. I will take a picture when I change my oil next time and post it.
Old 02-25-2010, 09:19 PM   #85
MainFrame
Member#: 218739
2002 WRX hybrid
BTW, if anyone's going to order online, this place is considerably cheaper than onlinemetals.com.
http://www.onlinemetalstore.com/item...omments=&qty=1
Old 03-30-2010, 06:51 PM   #86
MainFrame
Member#: 218739
2002 WRX hybrid
Finally bought my aluminum. I drove to Discount Steel in Ft. Worth and picked up a drops piece of 1/8" 5052, 4' x 3' for $40. If there's anyone else out there wondering where they can get aluminum sheet at a reasonable price I highly recommend calling Discount Steel and asking if they can send you a drops sheet of whatever you want. I believe 5052 was $1.70/pound.
Old 04-13-2012, 04:29 PM   #87
Rally Snow
Member#: 193614
02 Aspen WRX
need blinker fluid change
Lol I'm just imagining a cop pulling somebody over and wanting to check under the hood only to see a street sign bolted to the bottom of the car hahahaha!
Rally Snow is offline   Reply With Quote
Old 04-13-2012, 04:40 PM   #88
ZOMG.STi
Member#: 191857
RIP Matthew Denice
'05 2.5RS / '03 S2K
How do people find these threads from YEARS ago?
ZOMG.STi is offline   Reply With Quote
Old 04-17-2012, 09:30 PM   #89
microsnook
Member#: 313952
2006 STi
SGM DOM 3xt-r
By searching. I need to make a skid plate! Or just buy one
microsnook is offline   Reply With Quote
Old 08-04-2012, 12:14 PM   #90
mrchyes
Member#: 294069
98 Forester
Green
im going to go to a junkyard to buy some signs soon!
mrchyes is offline   Reply With Quote
Old 08-04-2012, 01:02 PM   #91
brew02wrx
Member#: 259970
2002 wrx cobb stg2+
psm proper fitment
Its called searching O_O
brew02wrx is offline   Reply With Quote
Old 08-04-2012, 09:26 PM   #92
MakuseruSukotto
Member#: 293159
2005 WRX
CGM
Sorry I don't have any better pictures.
Off with the old
And on with the new.
MakuseruSukotto is offline   Reply With Quote
Old 08-17-2012, 11:20 AM   #93
madlife
Member#: 136612
SRP
I found this on here sometime ago.. I was about to have someone fab it up for me, but I realized that I need a cutout for my headers. If anyone can mod this diagram for a cutout for headers, that would be great; otherwise, Ill probably have them make it, plop my plastic one on top, and trace it out..
madlife is offline   Reply With Quote
Old 08-17-2012, 02:05 PM   #94
gregroot198521
Member#: 280844
2006 STi
You could use spacers to lower it down under the headers. Kind of pointless to put on a skid plate and purposefully put in a point of failure in it.
gregroot198521 is offline   Reply With Quote
Old 08-17-2012, 03:33 PM   #95
madlife
Member#: 136612
SRP
I was going to have a "spacer" area created around the headers, not space the whole thing lower.
Old 08-18-2012, 11:06 AM   #96
thirdjoker
Member#: 282296
2005 wrx sti
psm
saved
thirdjoker is offline   Reply With Quote
Old 10-01-2012, 09:53 AM   #97
bigmaninjapan
Member#: 299064
2008 VF52 WRX Sedan
2005 Forester 2.5XS
It's amazing what boredom in a Monday morning meeting will do for your imagination. Glad I found this thread as I'm going to give this a go.
bigmaninjapan is offline   Reply With Quote
Old 10-01-2012, 11:37 AM   #98
dirtbikeridr12
Member#: 209896
03 2.35L bugeye
holset he351ve @23psi
I'll put up some pics as soon as I can, but my skid plate is from a Nissan Titan, looks factory
dirtbikeridr12 is offline   Reply With Quote
Old 10-14-2012, 06:05 PM   #99
trick_subie
Member#: 175001
2006 WRX TR
I've had thus sign on my wall for a number of years. I decided to make it more useful.
trick_subie is offline   Reply With Quote
Old 10-14-2012, 07:24 PM   #100
boostjuice
Member#: 89492
2006 STi
doing this asap
boostjuice is offline   Reply With Quote
FS: 02-07 impreza aluminum mini skid plate/splash guard ten80 Exterior/Styling 3 12-15-2008 10:26 AM
Brush Guard, skid plates, fender liners, and front end aero. Chi_San Interior & Exterior Modification 0 11-20-2007 10:28 PM
WTB: for GC8 L Coupe, clear lights, jdm tails, short shifter, diff guard, skid plates compleckz Private 'Wanted' Classifieds 1 04-20-2007 10:07 AM
FS/T: Stock splash guard (skid plate thing) Stover954rr Private 'For Sale' Classifieds 9 12-07-2005 12:08 PM
Need a skid plate (the stock splash guard isnt very tough!) yellowblaze Baja Forum 3 08-14-2005 08:55 PM
