Old 03-09-2009, 02:00 AM   #1
blkwagon
Member#: 102857
RHD sedan sti swap
high on meth
Default ACL Race bearing clearance questions
Today i went to assemble my short block and ran into a problem when checking the clearance for the rod bearings. I am using ACL race bearings and plastigauges to check for the clearances. All the clearance came out to .051mm which is right above the factory limit. After reading around i found the the "race" series bearings are .001" on the loose side over stock. Should i ditch the ACL and go pick up a set of oem so i can get it with in spec??This is going to be my daily driver and occasionally track and Auto X. Any input from people with experience would be great.
blkwagon is offline   Reply With Quote
Old 03-09-2009, 05:12 AM   #2
n2oiroc
Member#: 141952
15 legacy 16 wrx
have a machinist measure them. plastigauge isnt a very accurate way to check. and a little on the loose side is good, you dont want tight bearings!
n2oiroc is offline   Reply With Quote
Old 03-09-2009, 07:37 AM   #3
coxy
Member#: 198711
1989 MV Brumby TC
Stick with the ACL bearings if you read my reply on the spun bearings thread and use a good 10W 40 oil they will be fine,also seems people here have issues with Mobil 1,personally I have used Mobil 1 racing 4t 15W 50 oil in many high performance and race engines with no ill effects unlike say the cheaper grades of some in theory high quality oils such as Motul.
Castrol used to sponsor my rally car so I know that for instance they are only a marketing company,castrol oils are blended here in Australia by valvoline proibably the same in the US.
My oils came direct from the chemists and I learnt a lot from them as what I was supplied were exotic blends such as AH39/76 all lab spec development oils they did have their own labs for product development but manufacture is farmed out.Castrol syntec was one of the oils I tested and it's good stuff in the right grade for the application,10W30 is for granny's shopping trolley.
coxy is offline   Reply With Quote
Old 03-09-2009, 10:39 AM   #4
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Oil Dry Sump Goodness
ACL race bearings come in a couple of flavors, H and HX, the HX's are the oversized ones meaning they have more clearance. If you have HX then use H. 0.051mm is about 2 thou which is a little loose for a stock pump. I run 2 thou for rods, 1.5 thou mains.
If you have H's then they should be the same size as stock bearings
mick_the_ginge is offline   Reply With Quote
Old 03-10-2009, 01:51 PM   #5
GodSquadMandrake
Member#: 175435
1986 RX7
Sunrise Red
My clearances were like half of what yours are so I would say that's probably not a good idea to assemble a new engine that far on the loose end. It doesn't have any room to spare. What is the advantage of the ACL bearings? I just used Topline bearings.
GodSquadMandrake is offline   Reply With Quote
Old 03-10-2009, 02:24 PM   #6
907Bum
Member#: 183634
02 wrx/ 92 ss
Booze fueled :)
Mick i think hit it on the head, check which box you picked up you may not have the "h's"
907Bum is offline   Reply With Quote
Old 03-10-2009, 04:28 PM   #7
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Topline bearings are more like the stock, ACL Duraglide or Clevite 77 bearings. ACL RACE bearings are different, much harder surface, tri-metal
Old 03-10-2009, 04:46 PM   #8
seanathanq83
Member#: 173241
2002 s256 twinscroll
now with one more gear
i will be getting ACL bearings, how do i know which ones to order? and i want the H correct?
seanathanq83 is offline   Reply With Quote
Old 03-10-2009, 04:49 PM   #9
blkwagon
Member#: 102857
RHD sedan sti swap
high on meth
well i got my part numbers and they are the "H" bearings. Would OEM be slightly thicker?? The crank only has 11k on it and same with the block so i wouldn't think it would be worn out.
Old 03-10-2009, 04:57 PM   #10
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
http://www.aclperformance.com.au/us/...rings_crus.htm
Subaru EJ16, EJ18S, EJ20E, EJ20T, EJ22, EJ22T, EJ25, EJ25T
Rod bearings
4B8320H (for 48mm journal) (older crank)
4B8320HX
4B8296H (for 52mm journal)
4B8296HX
Main
5M8297H (Thrust in #3 pos) (Older cranks and cases)
5M8297HX
5M8309H (Thrust in #5 pos)
5M8309HX
H Standard oil clearance
HX +0.001" extra oil clearance
I felt like one of these because I had not see this little smile before.
Some people manage to spin out bearings with 100miles. Unless you measure the crank/case you will have no idea of the real clearances. Stock bearings should be the same thickness as ACL "H".
Old 03-10-2009, 05:14 PM   #11
blkwagon
Member#: 102857
RHD sedan sti swap
high on meth
well ill measure the crank...the motor never actually spun a bearing just had a cracked rigland. Ill try to measure it tonight after work and ill see.
Old 03-10-2009, 05:47 PM   #12
seanathanq83
Member#: 173241
would there be any need for HX? i will be running a v8 207, and want to be able to rev to 8500-9k, would the H be fine?
Old 03-10-2009, 06:20 PM   #13
Team Scream
Member#: 121532
2006 FXT/STi 6MT
01 Aerosim GC8 Coupe
Wrong,
While using a bore gauge and a mic is a good way to check, plasti-gauge is absolutely an accepted method for measuring clearance(s) very accurately.
Team Scream is offline   Reply With Quote
Old 03-10-2009, 06:31 PM   #14
turboL
Member#: 111735
96 Legacy2.0GTSOLD
Bimmer Tech
Originally Posted by Team Scream View Post
Wrong,
not so much, i mean i was taught to use it (plastigage) by a machinist. but i trust real tools.
http://www.carcraft.com/techfaq/116_...ter/index.html
im putting a stock shortblock together this week, using ACL bearings however. I will monitor room temp and mic/dial everything out as well as use plastigage and report my findings.
turboL is offline   Reply With Quote
Old 03-10-2009, 06:35 PM   #15
blkwagon
Member#: 102857
RHD sedan sti swap
high on meth
Wrong,
yea the guy who did my heads and my machining on my motor recommended me to use plasitgauge
Old 03-10-2009, 07:33 PM   #16
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
That depends on what clearances you want to run. My last block used a mix of H, HX's and some polishing to get my desired clearances on rods and main. Sometimes you will get what you want with standard and a polish, sometimes you need to go with a bearing designed to provide more clearance.
The only problem with Plasitgauge is that it can be inaccurate if the crank or rod shifts when it's inplace. Any shift smears it out and makes the reading useless. When done right it can be as accurate as tooling. However their lies the problem, it's easy to screw it up.
Old 03-10-2009, 07:38 PM   #17
blkwagon
Member#: 102857
RHD sedan sti swap
high on meth
so mick for a good daily driver what would be the desired clearance for the mains and rods? It is a ej25 with eagle rods and cp 100mm pistons???
Old 03-10-2009, 07:48 PM   #18
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Power levels? Stock Oil pump? Reving to what?
Daily driver, stock pump, stock rev limit, I would do 1 thou mains and 1.2/1.5 thou rods.
Old 03-10-2009, 08:04 PM   #19
blkwagon
Member#: 102857
RHD sedan sti swap
high on meth
right now stock vf39 until i fix the 6 speed i have and maybe as big as dom III. but stock rev limit and stock pump. i've been reading bout moding the stock pump for more pressure but not sure if its a good idea for me or not.
Old 03-10-2009, 08:36 PM   #20
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
1 thou mains and 1.2/1.5 thou rods seems about right.
What do the other builder think?
Old 03-10-2009, 09:57 PM   #21
seanathanq83
Member#: 173241
im going to talk to mine and see what he suggests, but mine will be a v8 207 with big port heads, reving to atleast 8500. with 92.5mm pistons, 12mm oil pump, and twin scroll 20g
Old 03-11-2009, 07:42 PM   #22
wrxsti.l
Member#: 156973
2002 ADM WRX STi
STi Black/Blue
I don't see a problem with 2 thou clearance - that is spot on the money imho.
The original rebuild on my EJ207 (done by Subaru) ran just a touch over 1 thou of clearance (using ACL race series bearings) and it spun a bearing within 24 hours of being rebuilt (I actually suggested to them to run looser but they didn't listen). After that failure it was rebuilt with 2 thou clearance and I have not had a problem.
I am a firm believer of that tried and true saying "1 thou clearance for every inch crank diameter".
wrxsti.l is offline   Reply With Quote
Old 03-14-2009, 07:50 PM   #23
scobbyfouette
Member#: 175134
i built a lot of engine for me and friends
i usually manage to get more then 1,5 thou at a minimum, 2 thou at best !
i run mine right a 2 thou, no oil pressure issue, no spun bearing issue neither
i assemble a ej20K at 1,8 thou a month ago, stock everything... MAYBE the oil pressure was a little lower then before, but nothing to worrie about .. i maybe should have shim the oil pump, but it is Ok !
subaru are weird... they should assemble there engine a bit looser on the bearing and on the piston pin.. that would make better engine that dont do piston slap, or spun bearings !!
scobbyfouette is offline   Reply With Quote
Old 03-14-2009, 07:51 PM   #24
scobbyfouette
Member#: 175134
oh i forgot, 2 thou for rod, 1.5 for crank is what i use
Old 03-14-2009, 08:32 PM   #25
blkwagon
Member#: 102857
RHD sedan sti swap
high on meth
well i went back today and played around and ended up with them between .0015 and .002 so i guess ill give it a shot. Hopefully i can get my gaskets and finish it up
BNIB: Carrillo hbeam rods and acl race bearings Ctracer911 Engine/Power/Exhaust 0 01-06-2010 08:24 PM
ACL Race bearings - dino oil only? Geek Guy Built Motor Discussion 17 11-03-2009 04:02 PM
acl race bearings herbine2001 Built Motor Discussion 4 07-20-2009 11:49 PM
Calico Coated ACL Race Bearings alcoolaid Engine/Power/Exhaust 4 04-27-2009 07:29 PM
WTB ACL Race Bearing vangstaboi86 Private 'Wanted' Classifieds 4 11-14-2008 03:04 PM
