Old 03-09-2009, 08:48 AM   #1
Odyknuck
Member#: 192866
2006 Impreza
Default WRX 440 Injectors in the 2000 RS
Is the air assist system needed when you replace the stock Injectors with the 440s. Can it be removed and capped? Will the ECU throw a code? The 440s do not have this feature and do not go down into the chamber past the air port. Also how have you guys been mounting the Injectors in the Intake manifold in regards to the "O" rings. I have the Railitech kit however I can not get them to work. I dont have there Instructions.
Odyknuck is offline   Reply With Quote
Old 03-09-2009, 09:15 AM   #2
Skidd
Member#: 1853
GC6 Supercharged
STM
From the setups I've seen, you can remove and cap the AirAssist garbage.
Skidd is offline   Reply With Quote
Old 05-20-2009, 04:01 AM   #3
svenghali
Member#: 43870
WHat, exactly is the Air Assist system you are speaking of? I have a 2000 RS and I dont recall seeing this when I put in my RC 440s.
svenghali is offline   Reply With Quote
Old 05-26-2009, 09:23 AM   #4
Odyknuck
Member#: 192866
2006 Impreza
There are air lines on the front side of the Intake manifold that feed the Injectors. They are fed thru a solinoid that is mounted on the front passenger side of the Intake manifold.
Old 05-26-2009, 09:38 PM   #5
freeride
Member#: 49783
2000 2.5rsti&98wagon
SRP/white
yea helps (so they say) with better fuel mix/mileage. It isn't hooked directly to the injectors just to the fuel lines.
freeride is offline   Reply With Quote
Old 05-26-2009, 11:10 PM   #6
Skidd
Member#: 1853
GC6 Supercharged
STM
Fuel Lines? The air-assist garbage is actually not hooked to the fuel lines in anyway. The vacuum is connected to the manifold at the base of the injector boss. I can't say I 100% understand exactly how or what it's supposed to do though.
WTB: stock WRX 440 injectors mx5logan Private 'Wanted' Classifieds 2 04-22-2010 07:19 AM
FS: 2002 WRX 440 injectors GC8WSI Engine/Power/Exhaust 4 03-04-2009 12:20 PM
Do rear 04+ WRX seats fit in a 2000 RS? SSLegacyGT Interior & Exterior Modification 1 07-14-2005 08:47 PM
Stock WRX 6cd radio in a 2000 RS? workin4audi Car Audio, Video & Security 1 08-22-2004 02:04 AM
WTB: Stock WRX 440 injectors 02mazdap5turbo Private 'Wanted' Classifieds 6 08-20-2004 07:41 AM
