Old 03-09-2009, 08:53 AM   #1
Odyknuck
Member#: 192866
2006 Impreza
Default Turbo drain and Dy Sump with PCV system
I am considering "T"ing into one of my Dry Sump Scavenge lines for the Turbo drain, any thoughts. Also the dry Sump system will be pulling a negative in the crank case. I dont really know how much. My question is what to do with the PCV system. Do I vent the Valve covers to atmoshere and run the "T" from the PCV line to the air intake. What do I need to do here.
Odyknuck is offline   Reply With Quote
Old 03-09-2009, 09:20 PM   #2
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
youre asking questions like this with dry sump....?
Old 03-10-2009, 11:09 AM   #3
Odyknuck
Member#: 192866
2006 Impreza
Please clarify your comment.
Old 03-10-2009, 01:07 PM   #4
ligo12
Member#: 205096
02 a zeppelin
blue
He is just bitching about grammar.
Pull a vacuum on the crankcase to avoid drain percolation.
ligo12 is offline   Reply With Quote
Old 03-10-2009, 03:20 PM   #5
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
no
i was bitching that he has that sick of an engine but doesnt even know how the oil flows in the block
the heads and crankcase share oil drain passages... so if you put vacuum on the CC and vent the heads, youll just be pulling air in through the head vents
Old 03-10-2009, 04:27 PM   #6
Odyknuck
Member#: 192866
2006 Impreza
no
I really am sorry I am not as brillant as you are! So in your Sarcastic and Demeaning way your saying I should pipe the head vents into the Intake system so my Sick motor will feel better.
Old 03-10-2009, 09:24 PM   #7
master c
Member#: 168226
ha typical nasioc response....
i ran my crankcase vents to atmosphere and have the block nipple t'd into the pcv and intake pre turbo...dunno if its right or not
master c is offline   Reply With Quote
Wanted: 3" Turbo Inlet and Big Maf Intake, FMIC enjoithis Private 'Wanted' Classifieds 5 06-14-2010 02:37 PM
Diagram for Oil Catch-Can and PCV System 3:15wrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 109 07-06-2009 02:15 PM
FS: EWG Dump Tube (straight), Replacement turbo oil and coolant lines with washers ScoobyNubieToo! Engine/Power/Exhaust 10 02-15-2009 07:26 PM
PCV System and Vacuum Leak jdeyo6 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 25 07-18-2008 05:41 PM
Perrin BIG Turbo Kits and Front Mounts..with (gasp)....posted prices! Z1 Performance Engine/Power/Exhaust 1 03-08-2008 02:10 PM
