Vancouver Impreza Club
Old 03-09-2009, 03:37 PM   #1
Joynt93
Member#: 173738
STG2 93' Legacy SS
Can't thouch This
Default Stripped the hex fitting on top of strut ???
what to do?
i threw a pipe wrench on the top of the strut to keep it from spinning, didnt want to grab though.
i am trying to break the nut free to swap springs.
Joynt93 is offline   Reply With Quote
Old 03-09-2009, 03:42 PM   #2
Zefy
Member#: 105104
1979 BRAT / 01 RSTI
99 2.5TS (DEAD)
you pretty much have to use an impact gun now...
and i actually separated a set of struts with the intent of shipping them to you however i quickly realized that i had just taken apart the rear and you need fronts right...?
then it started to snow so i retreated indoors...
Zefy is offline   Reply With Quote
Old 03-09-2009, 05:55 PM   #3
Joynt93
Member#: 173738
STG2 93' Legacy SS
Can't thouch This
i was looking for rear sti 02 03 springs.
so now i need a 16mm impact socket.
any other ideas before i go this route?
i was thinking of lightly disc sanding underneath the bump stop so my pipe wrench could grab?
Old 03-09-2009, 06:10 PM   #4
alcoolaid
Member#: 134949
'07 SWP STi
Instagram | arthurlam89
If you stripped the allen head I doubt a pipe wrench would have enough grip to prevent it from spinning.
Use an impact gun. It will come off in like 2 seconds.
alcoolaid is offline   Reply With Quote
Old 03-09-2009, 06:37 PM   #5
steve
Member#: 4718
Sold my Subaru, and
now I'm so OT
+1 for the impact gun.
I wouldn't do most suspension removal without one.
steve is offline   Reply With Quote
Old 03-09-2009, 07:57 PM   #6
timbits
Member#: 166183
2007 2.5i SE
Newport Blue
+1 impact gun
If you need to rent and electrical one and don't mind coming up to Burnaby, lemme know. You can pay me in beer.
-Tim
timbits is offline   Reply With Quote
Old 03-09-2009, 09:50 PM   #7
Joynt93
Member#: 173738
STG2 93' Legacy SS
Can't thouch This
okay, i burrowed one from work and bought a 16,17,and 19 mm impact sockets to add to the set.
and a 3/4 to 1/2 adapter.
i wish my compressor was working. thanks for the offer tim. i'm going to work on it in a couple minutes.
whoa, is this guy new this is like some ymca ****
Old 03-10-2009, 12:32 AM   #8
Joynt93
Member#: 173738
STG2 93' Legacy SS
Can't thouch This
alright, got er done. the one strut that i stripped is trippin me out. it had a slightly smaller size hex hole than the other 3. i think it would be a 5.5 or 6.5mm hole. so after a good 10 minutes of almost pure impact gun the nut was finally almost off. it took so long because the strut spun freely.
it is still a bitch to get the nut back on because it just doesnt want to spin on easily, the threads look fine on the nut and strut and i have no idea how im going to torque it to spec. at least it is a front one so it is easily accessible once installed.
btw i bought these used and are already off the car for me to work on.
my route for the other three worked out great. i simply layed the strut on the floor and cracked the nut loose with a 17mill. after that i used my hex key attached to vise grips and a socket with a pipe wrench to easily work the nuts off the rest of the way.
now i just have to swap my rear tops on to the new rear struts and it's time for the swap.
thanks guys for ur help
Old 03-10-2009, 01:02 PM   #9
timbits
Member#: 166183
2007 2.5i SE
Newport Blue
When you're impacting that nut off and on, do it in short pulls. Spinning up the shaft enough can kill the seal at the top.
I used soapy water to clean a rubber dishwashing glove and the shaft. Then grab the shaft with your fingers and have somebody else apply impact.
-Tim
Old 03-10-2009, 01:20 PM   #10
Joynt93
Member#: 173738
STG2 93' Legacy SS
Can't thouch This
how would i know if i f'd the seal
Old 03-10-2009, 01:35 PM   #11
timbits
Member#: 166183
2007 2.5i SE
Newport Blue
I wouldn't worry too much about it for now. Just have a look at it after you've driven it for a week or so, and once a week for a short while. If the seal's blown, you'll know...
-Tim
Stripped allen/hex hole on freeze/core plug, any ideas? Block heater install woes. roninsoldier83 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 38 02-12-2014 04:18 PM
I just stripped the hex off a lug Sonic Yellow 2K3 WRX Tire & Wheel 20 11-17-2003 06:20 PM
What's the purpose of the coolant reserve tank/header tank on top of the engine? garface Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 08-28-2003 02:47 PM
dust caps on top of the front struts tmat3 Brakes, Steering & Suspension 0 05-10-2002 12:11 PM
Guage package on top of dash fit TV? Sobelizard109 Car Audio, Video & Security 1 11-02-2001 08:59 PM
