Old 03-09-2009, 03:31 PM   #1
emsmap
Member#: 159334
02 WRX, 99RS, 96L
AP3,PPG, BW S256
Default What spark plugs do you all use?
I have a 2002 wrx and the factory plugs are NGK PFR6Gs and I was wondering what other plugs you all use and if you have any luck with them. I have NGK Irridiums in now and my tuner said he doesn't like to tune with them because he has bad luck with misfires. The stock plugs each are 10.00. Just wondering what other people use. I am running a vf39 with all supporting mods.
emsmap is offline   Reply With Quote
Old 03-09-2009, 03:33 PM   #2
csmithwrx'05
Member#: 171293
'05 WRX Hybrid
EJ257 w/Blouch 18G 8cm^2
I have only used NGK Iridiums and have never had an issue w/them tuning or otherwise.
csmithwrx'05 is offline   Reply With Quote
Old 03-09-2009, 03:46 PM   #3
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
using autolites oem replacements in my wrx..no probs so far.
mxpunk is offline   Reply With Quote
Old 03-09-2009, 03:56 PM   #4
emsmap
Member#: 159334
02 WRX, 99RS, 96L
AP3,PPG, BW S256
Me either, I have tuned my car several of times with my laptop and I haven't gotten any of misfires. My tuner is VERY popular so I followed his advice and took them out. I am going to go get some plugs today but was just wondering what people used
Old 03-09-2009, 04:33 PM   #5
Tut4u2
Member#: 40424
05 STi
I use the stockers. I have tried the one step colder iridium and my car misfired like crazy.
Tut4u2 is offline   Reply With Quote
Old 03-09-2009, 04:39 PM   #6
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
ngk copper, 1 colder, changed every year.
bkr7e.
Old 03-09-2009, 04:43 PM   #7
gtfaded
Member#: 142322
2002 wrx
wrb
regular ol' ngk's copper
gtfaded is offline   Reply With Quote
Old 03-09-2009, 06:00 PM   #8
djerickd
Member#: 3782
02 WRX WFC#040
Clean on 19's
djerickd is offline   Reply With Quote
Old 03-09-2009, 06:36 PM   #9
sigurd
Member#: 128721
2002 impreza WRX
psm
ngk copper.
sigurd is offline   Reply With Quote
Old 03-09-2009, 08:23 PM   #10
emsmap
Member#: 159334
02 WRX, 99RS, 96L
AP3,PPG, BW S256
well I just ordered the factory OEM plugs from advance. They are the laser platnums
Old 03-09-2009, 09:13 PM   #11
WYSubaru
Member#: 154884
2005 Baja turbo
NGK platinum.
WYSubaru is offline   Reply With Quote
Old 03-09-2009, 09:48 PM   #12
AWD_TY
Member#: 183584
BLACK
i use brisk racing plugs in my 02 wrx. they are great for the money.
you can get them for a really decent price at
www.perrinperformace.com
AWD_TY is offline   Reply With Quote
Old 03-10-2009, 04:30 PM   #13
Bacon117
Member#: 118500
02 Silver Wagon
"Stage 2"
You do know its not made out of copper right? and ALL ngk plugs have the same COPPER CORE in them, regardless if the are standard nickel, platinum, or iridium. It is more accurate to call them Nickel plugs.
Bacon117 is offline   Reply With Quote
Old 03-10-2009, 06:12 PM   #14
emsmap
Member#: 159334
02 WRX, 99RS, 96L
AP3,PPG, BW S256
Is the correct gap on my car (2002 wrx) .030? Thats what advance auto parts computer says and thats what the plugs are. My tuner said to gap them at .028 though
Old 03-10-2009, 06:40 PM   #15
Bacon117
Member#: 118500
02 Silver Wagon
"Stage 2"
That difference is too small to really matter. But if you buy the PFR6G (factory plug for 2002 wrx), it is already gapped at .030. You don't need to re-gap. BTW, try to avoid gapping or even checking precious metal plugs (iridium, platinum) as you can easily damage the precious metal. A nickel plug, like BKR6ES or BKR6E, you can gap all you want.
Old 03-10-2009, 07:28 PM   #16
tribalwrx
Member#: 32993
vf39 Best trap 110
Best ET 12.51 Dale tuned
1-step colder ngk copper's are working with my vf39 plus meth injection without a hitch
tribalwrx is offline   Reply With Quote
Old 03-11-2009, 07:43 AM   #17
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
i don't care what the plug is made out of--i'm not putting one in that hasn't had its gap checked.
if you're ****ing up your plugs and breaking electrodes while checking gap then you're a ham-fisted idiot who shouldn't be working on your car in the first place.
jm2c
ken
Old 03-11-2009, 10:19 AM   #18
Bacon117
Member#: 118500
02 Silver Wagon
"Stage 2"
jm2c
ken
If you insist on checking it, just know that you need to be a a lot more careful than with a nickel plug. Use a pin or wire type gage. DO NOT use the "coin" wedge style or flat feeler gages. When using the pin type, gently slide it into the gap, rotating the pin if necessary. DO NOT FORCE IT. This is the type of tool you should use if you must check the gap: http://www.autozone.com/R,824580/sto...B7D32F9425419C
Old 03-11-2009, 01:59 PM   #19
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
anyone who forces any kind of feeler gauge isn't using it properly. see: ham-fisted idiot.
Old 03-11-2009, 03:19 PM   #20
Bacon117
Member#: 118500
02 Silver Wagon
"Stage 2"
Happens a lot more often than you could imagine. Even "proffesionals" screw it up from time to time.
Old 03-12-2009, 10:05 PM   #21
Borjaq
Member#: 4812
04 STi
Blk
NGK Copper's
Borjaq is offline   Reply With Quote
Old 03-13-2009, 01:01 AM   #22
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
I have most indubitably made paperweights out of $$ sparkplugs
I even(usually) buy an extra plug or have an extra(or 2 ) around just in case.
some of the iridium plugs can be destroyed by knocking the tiny---think grain of salt size here....iridium pad off of the center electrode....and you dont even know you did it
Old 03-13-2009, 08:22 AM   #23
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
that's why you should buy the $2 coppers, scotty!
Old 03-13-2009, 11:44 AM   #24
02blueru
Member#: 80012
04 BMW M3
Ducati 620 Dark / 08' 848
+1 for the coppers. They get the job done and are much cheaper although you need to swap them out more often. I gap mine to 0.028
02blueru is offline   Reply With Quote
Old 03-13-2009, 12:51 PM   #25
yeos
Member#: 133855
2009 STi SparkSilver
Dom Tuned @ MPS
NGK coppers
yeos is offline   Reply With Quote
What torrent sites do you all use? greenshoes3 Off-Topic 27 07-24-2008 04:13 PM
What spark plug do you recommend for 2000 RS? Longitude Service & Maintenance 4 04-23-2002 10:04 PM
What grade oil do you all use? codemunky Service & Maintenance 23 04-17-2002 01:19 PM
What Octain gas do you all use here in CO. Scoober01 Rocky Mountains Impreza Club Forum -- RMIC 14 04-23-2001 07:13 PM
OT: What Cell Phone cariers do you all use? IMPREZAmike New England Impreza Club Forum -- NESIC 12 10-04-2000 12:34 AM
