Go Back   NASIOC > NASIOC Subaru Models > Baja Forum
Old 03-09-2009, 04:23 PM   #1
BrunoShield
Member#: 155944
2003 Baja
Black Granite Pearl
Default Well, my Baja finally needs service. Check Engine light on.
Code for catalytic converter output below threshold or something. Basically, I need a new cat, right? So what are the options? O3 NA, AT, no mods, 144,000 miles. It's a driver and I'm happy with it as it is.
No, I haven't checked on the dealer part, but it's basically the entire exhaust from what I can see, and that means serious money. I'm unemployed at the moment so money is a very real issue. Options? Alternate sources? Price? I can turn wrenches and I have a garage, plus a goodly amount of tools, so I should be able to replace it myself, maybe.
A little direction or a source for a reasonably priced part would be wonderful. I'm just not about to put $900 into a new exhaust system. I'll run it until it's time to renew my plates and then I'm screwed I guess. Unless clearing the code and error holds long enough to pass emissions.
BrunoShield is offline   Reply With Quote
Old 03-09-2009, 06:28 PM   #2
BajaGuy68
Member#: 127720
2015 WRX
Lightning Red
Sorry to hear about that. Do you remember the code #? Could it be something as simple as an o2 sensor?
BajaGuy68 is offline   Reply With Quote
Old 03-10-2009, 08:24 AM   #3
jeromes
Member#: 192299
2011 Forester XT
Default Check Eng Light
This code throws on my daughters 2000 Forester all the time, (about 3yrs now). Car runs great, no problems. I just keep clearing the code.
jeromes is offline   Reply With Quote
Old 03-10-2009, 10:00 AM   #4
speedymatt
Member#: 54910
2003 BAJA Classic
Silver/Silver/& uh Silver
same with my 03 baja. it only has 46k on it and i got that code. cleared it and started it and it stalled right away then threw the same code. i replaced the sensor and it ran fine until it started making this very scarey sound like a pulley wobbling. after checking everything the sound lead me to the front cat. i tested it with a rubber mallet and sure enough it rattled bad when hit so the cat needs replaced.
the factory part from the likes of subarupartsforyou is around $800. personally i'm going with an ebay one for half that. its actually two cats produced by eastern catalytic and a third party has welded then up for the 2.5L. look under your car to make sure thats the one you need. i've been told that 03 was the switching point for some of subarus catalytic design. some are actually attached to the header pipe, others have a flange between the two and they can be replace seperately and then there is the one that is both in one pipe.
speedymatt is offline   Reply With Quote
Old 03-13-2009, 03:45 PM   #5
braveit1
Member#: 44810
2003 Baja w/Snuglid
Black & Silver
I have the check engine light as well at 65K. Dealer says its the Cat and under warrenty still. Light comes on and off at will. Next time I take it in I wll get it taken care of.
braveit1 is offline   Reply With Quote
Old 03-14-2009, 10:55 AM   #6
deadlydave
Member#: 131119
1996 Impreza LWRXSTI
91 BMW 318is
Isn't factory 'smog' equipment under federally-mandated warranty for 8 years 80k miles?
deadlydave is offline   Reply With Quote
How can I read my check engine light on my 94 Impreza? ZZcorollaVV_Ti Newbies & FAQs 2 12-04-2007 12:53 PM
Engine vibrating, check engine light on codemunky Service & Maintenance 2 09-15-2002 07:50 AM
Need help- check engine light coming on, think I am pushing around 20 psi scoobydoo02 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 05-04-2002 09:01 PM
Check Engine Light on my WRX... Anyone?? mturmel Canada Region Forum 4 07-05-2001 01:18 AM
Need Help-Check Engine light is on AndyHidley Technical Forum Archive 3 05-19-2000 01:35 PM
