Old 03-09-2009, 09:27 PM   #1
S L O W W R X
Member#: 95109
Default JDM Version 8 Head...Spark Plug question
What plugs are you guys running in your JDM heads, I think mine ended up with the wrong plugs in them and I can't seem to find which plug is right wrx or sti or a different plug all together.
S L O W W R X is offline   Reply With Quote
Old 03-09-2009, 10:14 PM   #2
seanathanq83
Member#: 173241
2002 s256 twinscroll
now with one more gear
i would like this too, i am building my v8 207 at the moment
seanathanq83 is offline   Reply With Quote
Old 03-09-2009, 11:05 PM   #3
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Oil Dry Sump Goodness
The JDM 2.0 heads use the shorter WRX plug
mick_the_ginge is offline   Reply With Quote
Old 03-09-2009, 11:07 PM   #4
seanathanq83
Member#: 173241
is there a certain heat range? or is it the stock wrx heat range
Old 03-09-2009, 11:16 PM   #5
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Stock is a 6, most run the 7, very few run the 8
Old 03-10-2009, 12:49 AM   #6
S L O W W R X
Member#: 95109
Thanks I thought that was the case but when I pulled them out I was starting to second guess myself.
Old 03-10-2009, 02:01 AM   #7
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
I think I will be running plugs for STi so it's further away from the head... reducing the hairline cracks. The piston's dome does NOT come up more than the block deck.
FuJi K is offline   Reply With Quote
Old 03-10-2009, 10:37 AM   #8
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
You better hope that the exposed threads don't carbon up otherwise you are going to destroy the spark plug hole threads when you try and remove them.
Old 03-11-2009, 03:33 PM   #9
Pavlo
Member#: 23015
95-> GC8
Black, blue and blue
Stock = PFR6B (good quality platinum plug)
Cooler = PFR7B (one grade cooler than above)
Cooler still = BKR8EIX (iridium 8, but really a long life plug rather than a performance plug)
Race = R7434-8 (hand assembled, dual irdium retracted electrode race plug)
Mad mofo race = R7434-9 (cooler version of above)
Pavlo is offline   Reply With Quote
Old 03-11-2009, 06:14 PM   #10
seanathanq83
Member#: 173241
are the race versions NGK also? where can you get those
Old 03-11-2009, 06:40 PM   #11
phlegmon
Member#: 26223
2012 GTR - on E85
07 STi twinscroll XTR
phlegmon is offline   Reply With Quote
Old 03-11-2009, 06:55 PM   #12
Rasmusson14
Member#: 77658
2004 ej207, ppg dogs
3" green, ITS ALL 4 SALE!
Coppers.......cheap and very reliable spark. Switch out every other oil change.
Rasmusson14 is offline   Reply With Quote
Old 03-11-2009, 07:04 PM   #13
seanathanq83
Member#: 173241
yea i used copper and with all the tuning and adjusting i have done, i can tell they are getting fouled out, i really need to change them, i will be going back to regular heat range and iriduims, but when i get the engine built i will be using 1 step colder, maybe race who knows
WTB: JDM Version 8 heads + ecu 74KILLER Private 'Wanted' Classifieds 9 04-13-2007 07:58 AM
WTB: STI JDM Version 8 heads 74KILLER Private 'Wanted' Classifieds 0 04-03-2007 06:18 AM
Wtb: Jdm Version 8 Heads 74KILLER Private 'Wanted' Classifieds 0 03-29-2007 09:31 AM
JDM Version 8 heads and ecu 74KILLER Private 'Wanted' Classifieds 2 03-21-2007 11:39 PM
JDM version 8 heads thechase Subaru Conversions 21 06-16-2004 04:55 AM
