Old 03-10-2009, 05:24 AM   #1
nojokesniper
Member#: 192623
Default ej25d -> ej251
im doing a motor build, but i couldnt seem to find an ej25d locally but ive found an ej251, i will just be using the block halves and pistons but i was wondering will all my accesories like water pump, oil pump, gears/pulleys and other stuff bolt on to the ej251? i thought the only change between the ej25d and ej251 were they became SOHC and they had bigger rod journals, but if im mistaken and i have to buy specific parts for the motor ill just keep llooking for an ej25d
nojokesniper is offline   Reply With Quote
Old 03-10-2009, 06:48 AM   #2
Storm
Member#: 5218
96L Most Over-
Developed Beater
It's a good base to start from. All your bolt on parts will fit and the result of that block with those heads is a little bump in compression that helps in making a bit more power.
The only thing you may have to change, is the mounting bracket for the timing belt tensioner. It bolts right up to the block too, so no worries there.
Jay
Old 03-10-2009, 06:49 AM   #3
nojokesniper
Member#: 192623
awesome thanks thats just what i wanted to hear, i will be building it with ej22t rods and crank so i will be dropping the compression so i can run boost
EJ25D -> V4 STI head conversion Splinter Normally Aspirated with bolt-on Forced Induction Powertrain 4 06-21-2009 09:35 PM
FS: EJ25D and EJ251 Letze 1993 - 2001 Impreza Specific Parts 14 02-10-2009 07:14 PM
Clarification Phase 1 EJ251 v. Phase 2 EJ251 tranny mounting bolts and flywheel quest HillbillyLes Transmission (AT/MT) & Driveline 0 07-10-2008 09:43 PM
P&P EJ251 & EJ25D Heads DSM_Outback 1993 - 2001 Impreza Specific Parts 8 12-23-2007 02:28 PM
PM road trip: from MN > SD > WY > MT > WY > ID > NV > UT > CO > NE > IA > MN. Input? Protege Menace Off-Topic 29 10-04-2007 11:25 PM
