Old 03-10-2009, 06:18 AM   #1
verc
Member#: 41754
03 wrx
gt35r, 2.5L, meth
Default Anyone here run dual walbros and huge injectors with all else stock?
Just wondering.... Burschur makes a good dual walbro setup so this would be something like:
- dual walbro
- 1000cc injectors
- stock lines
- stock fpr
- stock rails
Anybody here run that here? I'm not the kind of person that does mods for the sake of mods, I'm just curious if anybody's got a big power DD setup with a simple fuel system, as opposed to a crazy aeromotive and surgetank w/ aftermarket fuel lines, FPR and rails kind of deal.
Thanks
verc is offline   Reply With Quote
Old 03-10-2009, 06:26 AM   #2
n2oiroc
Member#: 141952
15 legacy 16 wrx
i was under the impression that the stock fpr cant handle 2 pumps or even 1 fairly big one.
n2oiroc is offline   Reply With Quote
Old 03-10-2009, 01:31 PM   #3
leonbmx
Member#: 82864
2005 MPS Wagon HTA35
Domtuned Stage $$$$$
I thought Buschur wasn't making them for Subaru's anymore? They aren't on the website anymore...
leonbmx is offline   Reply With Quote
Old 03-10-2009, 01:47 PM   #4
Fongers
Member#: 118239
2002 Built Wagon
Wife- 2004 Outback SE
beyond a single walbro, you'll want to upgrade the rest of the system to parallel fueling at the least.
Fongers is offline   Reply With Quote
Old 03-10-2009, 03:03 PM   #5
blowbyu24
Member#: 84482
2005 STI.UR gt4088r
E85 pro comp sti
- dual walbro
- 1000cc injectors
- stock lines
- stock fpr
- stock rails
Thanks
i used to have dual walbros, 1000cc injectors and a aeromotive fpr and everything else stock
now i have bosch 044, instead of the dual walbros....the one failed and i didn't know until i was going down the track @ 30psi running 15.1 a/f
the 044 seems to work great with the stock fuel system, i have the base fuel pressure at 52psi and have the 044 hard wired to the battery/relay....i do have a hydra ems to control the tune so i can bypass the oem fuel pump controller
blowbyu24 is offline   Reply With Quote
Old 03-10-2009, 04:19 PM   #6
Token-Negro
Member#: 81659
2006 STI / 2010 FXT
Aspen White / Silver
At the least you prob want to do an FPR, not very expensive, and will become a great tool if you have to raise the BFP.
Token-Negro is offline   Reply With Quote
Old 03-10-2009, 09:39 PM   #7
verc
Member#: 41754
03 wrx
gt35r, 2.5L, meth
So you ditched the walbros b/c one of them failed? Why would the bosch be better?
To another poster: yes I just called burschur and they still do the dual setup as one-off core exchanges for $450.
Old 03-10-2009, 09:59 PM   #8
dexterous
Member#: 23553
2005 STI - Insanity!
2014 WRX - Daily
Because if the bosch failed the car would stop running.
dexterous is online now   Reply With Quote
Old 03-10-2009, 10:49 PM   #9
blowbyu24
Member#: 84482
2005 STI.UR gt4088r
E85 pro comp sti
the bosch can handle the flow and like the poster above said the car will not run if it stops rather than lean conditions like the dual walbros
Old 03-10-2009, 11:05 PM   #10
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
I don't know why this keeps going around like some old anecdote, but fuel pumps don't always completely pack up completely at the first sign of trouble.... They actually do work often when on the way out... Just not at 100%.
Read this..
http://www.associatedcontent.com/art...p_on_your.html
Again, any pump can fail, whether you have a single walbro, 2 walbros, or 1 bosch pump, or 10 bosch pumps running the show.
Key is to notice the early signs...
A car coming to a stop on the side of the road or failing to run is not necessarily an early sign of an issue with the pump.
jigga is offline   Reply With Quote
Old 03-12-2009, 11:59 AM   #11
dexterous
Member#: 23553
2014 WRX - Daily
Jigga,
Agreed, but in my experience, its more obvious that something is wrong.
Old 03-12-2009, 02:58 PM   #12
blackacres
Member#: 134821
2006 STI
I actually had a Buschur dual Walbro setup in my parts bin for my new build.
However, my tuner feels the same as blowbyu24 and dexterous on the dual setup.
If one of the dual pumps fails, at high boost/fuel demand levels, you may encounter a leaned out condition, as the remaining single pump can't supply enough fuel. A motor could suffer considerable damage in a very short time if this occured and was not caught right away.
Also, one pump working may not be noticed at lower boost levels, as there may not be any signs that only one pump is working.
As posted above, if the single Bosch begins to fail, you possibly would notice it more easily, if it fails, the engine will not run.
My tuner talked me out of the dual setup and the plans are now to use a Bosch 044 pump, with a new larger fuel supply line, using the original supply line as a return.
IMO, I've got too much invested in my new motor to take a risk that I can avoid. Besides the Buschur setup costs more than the Bosch!
blackacres is offline   Reply With Quote
Old 03-12-2009, 09:40 PM   #13
blowbyu24
Member#: 84482
2005 STI.UR gt4088r
E85 pro comp sti
^^^^good choice man
probably the only reason my motor didn't pop was b/c i was running c16 at the time and that fuel is really hard to make det
Old 03-13-2009, 01:05 AM   #14
ScorpionT
Member#: 195677
It really seems like there isnt much for a drop in fuel solution, Im surprised nobody has made one yet. I might hafta look into building something. With the debate on single vs dual pump, I understand the concern, but Ive personally never had a problem running 2 and even 3 pumps on Supras.
ScorpionT is offline   Reply With Quote
Old 03-13-2009, 03:53 PM   #15
Dutch Scooby lover
Member#: 32452
1998 Impreza Turbo
74F FTW
If you go dual pump,at least go parallel as well.
It wont cost the bank.
I made this setup for under a 100$ (I have the welder myself, add 2 6 packs for the welder if U don't)
Dutch Scooby lover is offline   Reply With Quote
Old 03-13-2009, 07:39 PM   #16
SloRice
Member#: 44351
2004 Mitsubishi Evo
701whp [email protected]
Buschur has built 100's of dual pump setups for the Evo without issue, including mine. Many of the Supra guys are running dual and triple pumps without issues. My STI also had a BR dual Walbro setup in it without issue....actually I had the first one David ever built.
Also, BR's dual pump setup won't overrun the fuel pressure regulator because the second pump is on a hobbs switch that turns it on when it sees positive pressure.
SloRice is offline   Reply With Quote
Old 03-14-2009, 12:30 AM   #17
TDagen
Member#: 163648
2002 Wrx,5.3L,S476r
FNF LSX Swap,E85 and more
fullblown has a subaru double pumper also...
TDagen is offline   Reply With Quote
Old 04-05-2009, 10:52 AM   #18
Zspectrum
Member#: 152933
CT9A
TB
Who makes a dual walbro for the 08 stis?
Zspectrum is offline   Reply With Quote
Old 04-06-2009, 09:25 AM   #19
Huff
Member#: 103020
2004 WRX/STi Swap
Java Black Pearl
Mine is setup the same way with one always on and the other kicking on at 13psi of boost. Custom dual walbro done by Verocious Motorsports. Still with stock FPR.
Huff is offline   Reply With Quote
WTB - 1.06 / dual walbro / 1100+cc Injectors JustA4 Private 'Wanted' Classifieds 0 08-24-2008 11:37 PM
Anyone here run HDPE/track days with stock WRX and COBB stage 1? chimchimm5 Motorsports 11 05-27-2008 01:54 AM
Is it ok to run headers with all else stock? forced03 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 11 01-16-2007 04:58 PM
Anyone here running gutted UP's and DP's? SaabaruMike South West Impreza Club Forum -- SWIC 7 12-04-2006 10:06 AM
Is anyone here running the AEM short Ram with a GFB hybrid BOV? HiFiWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 03-06-2003 10:08 PM
