Old 04-11-2002, 12:47 PM   #1
Impreza25RS
Member#: 4850
1998 EJ22.5RS-T
more mods coming soon!!
Default Bosch BOV = Junk?
All right whats the deal with this thing? It looks pretty cheesy to me so I was wondering if Im just better off getting an HKS/ Greddy BOV before I install my turbo kit and throw this thing in the trash. What do you guys think? I plan on running 5psi off a Garrett T3/T4 so you know. Thanks once again
Kyle
98RS Owners UNITE!
Impreza25RS is offline   Reply With Quote
Old 04-11-2002, 12:53 PM   #2
AaronB
Worst Mod Ever
Member#: 369
12 Vagon
I personally don't think they are made very well.
AaronB is offline   Reply With Quote
Old 04-11-2002, 01:24 PM   #3
kastle
Frank Army
Member#: 1457
1999 Outback Sport
Steel Blue Mica
As Aaron stated, the Bosch has a tendency to leak, even @ idle... Most people will agree that this is one case where spending the money on a better BOV is worth it.... Just about anything is better, the stock WRX BOV is a good alternative as is the Greddy, HKS and GFB.
kastle is offline   Reply With Quote
Old 04-11-2002, 02:31 PM   #4
Porter
Member#: 486
2004 Forester XT
bug spattered
Guys, not all Bosch BOVs are junk. Just the one you're looking at. The Bosch on my old Saab SPG held over 20 psi without leaking.
Porter is offline   Reply With Quote
Old 04-11-2002, 03:53 PM   #5
kastle
Frank Army
Member#: 1457
1999 Outback Sport
Steel Blue Mica
Porter is right as well... I don't want it to seem like we are bashing Bosch in general.... Just these 5psi BOVs... Wish I had the part number handy so we could reference that...
Old 04-11-2002, 04:32 PM   #6
MELBA
Member#: 9629
2014 Audi S4
Yes don't buy it.
MELBA is offline   Reply With Quote
Old 04-11-2002, 05:15 PM   #7
subachad
Member#: 8488
1993 Impreza GCStyle
Teal
It's a bit of a debate if a BOV is even needed. For the most part, they are put on by auto makers to help make the car more quite.
If the Bosch is really junk, then why would Porsche put them on 400+ hp turbo Porsches?
Personally, I think all the fancy BOV's like the HKS SSBOV for example is a waste of money UNLESS bought for cosmetic reasons. Can anyone truely explain WHY the expensive BOV's are so much better? I can understand if it leaked under boost, but how do you know it's leaking??? Do you have a boost gauge installed in the line coming off your BOV?
Chad
93 1.8T with a Bosch BOV
subachad is offline   Reply With Quote
Old 04-11-2002, 08:34 PM   #8
Scoobie Steve
Member#: 2289
1998 [email protected]
Subaru L Ver 6 STi Type R
AaronB at idle(High Vacuum) the Bosch BOV is wide open so it will (leak) but as soon as you hit the gas and the vacuum goes to 0 it will close and as boost pressure comes on it will help to hold it shut. I've run mine up to 14 psi with NO leaking and for the price it cant be beat! Although finding a good used one in the junkyard is hard(Diaphram always shot) so maybe the longevity of the Bosch unit isnt great.
Scoobie Steve is offline   Reply With Quote
Old 04-11-2002, 09:22 PM   #9
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
I don't know what Bosch BOV you are using, but the one I recommend is factory on a Porsche 993 (I think). In researching the cheap BOV's, many of the cheap Boschs are junk. You just need to be careful which you get as they can all look the same but all be very different. Sorry, I don't have the links to what's good and not but here is the part number for the Porsche part number: part # 993-110-337-5. Price is a whopping $33 brand new.
-Jon
www.nothingserious.net
Old 08-23-2003, 08:40 AM   #10
Bishop74
Member#: 42208
This thread came up in a search, very funny stuff, it's a good thing it's old, I'd hope a few people have found out the diffrence between a BOV and a CBV since then.
"Leaks at idle", I read that and just about wet myself.
Bishop74 is offline   Reply With Quote
Old 08-23-2003, 02:27 PM   #11
boysetsfire
Member#: 6218
2001 2.5rs-t
silverthorn metallic
What would happen if your bov was leaking under boost?
-Marc
boysetsfire is offline   Reply With Quote
Old 08-24-2003, 06:36 AM   #12
ChicksDigWagons
Member#: 20508
1998 Red Wagon
New Turbo Project...
On a MAF based car with a recirculative BOV or "CBV" you'll just lose boost pressure and idle fine.
On a MAF based car with a open BOV you'll have incorrect MAF readings and it will idle for crap.
On a MAP based car you'll also just lose boost pressure but the idle will be fine.
-Brad
PS. I'm still not sure what point Bishop74 was trying to make, some important points were brought up in this thread. Regardless or whether its an open BOV or closed BOV (aka CBV, a term NOBODY uses around here) leaking at idle is not an ideal thing.
ChicksDigWagons is offline   Reply With Quote
FS : cobb accesport, dp, bov bryan04wrx Tri-State Area Private Classifieds 3 06-01-2010 10:49 PM
Forge VTA BOV WeldingHank Private 'Wanted' Classifieds 1 06-01-2010 09:07 AM
Greddy RS BOV and Bosch Platinum +4 Spark Plugs Nitrousspeed Engine/Power/Exhaust 2 03-21-2009 05:15 PM
Bosche BOV leaks over 7 psi, need recs for BOV for 0-12 psi ImprezaRS dot com Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 22 05-10-2001 11:25 PM
