Old 03-10-2009, 01:05 PM   #1
mvcsk8r
Member#: 182483
05 Saabaru 92X HYB
Default Q: 02 wrx heads vs 05 wrx heads?
Are the 02 heads the same as the 05 heads with the exception of the shimless buckets on the 05? Are the valves themselves are the same, so that i could use shimless buckets on the 02 heads? Thanks in advance.
mvcsk8r is offline   Reply With Quote
Old 03-10-2009, 01:18 PM   #2
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
valves, springs, retainers, keepers and buckets are all interchangable. I'm almost positive they are the same casting too.
Old 03-10-2009, 01:39 PM   #3
Fongers
Member#: 118239
2002 Built Wagon
Wife- 2004 Outback SE
Yes they are - I've swapped them around before.
Fongers is offline   Reply With Quote
Old 03-11-2009, 08:46 AM   #4
mvcsk8r
Member#: 182483
05 Saabaru 92X HYB
Thank you gentlemen.
Old 03-11-2009, 08:53 AM   #5
mvcsk8r
Member#: 182483
05 Saabaru 92X HYB
Did the Cams change much? I used my 05 cams in the 02 heads and one fits a little snug even when no lifters are installed.
04 wrx axle vs 05 wrx axle? Caelaorn Transmission (AT/MT) & Driveline 3 03-23-2009 08:36 AM
06 wrx clutch vs. 05 wrx clutch 04AZSTI Transmission (AT/MT) & Driveline 2 08-26-2007 12:26 AM
Diff betwwen 02 WRX Heads VS 05 WRX HEADS? TOMASCS Built Motor Discussion 3 01-08-2007 03:08 AM
06 wrx sedan vs. 05 wrx sedan spirited Newbies & FAQs 85 02-18-2006 04:18 AM
02 wrx clutch vs. 05 wrx clutch aspenwhitewrx Transmission (AT/MT) & Driveline 2 11-07-2005 04:27 PM
Message Board Statistics All times are GMT -4. The time now is 02:20 PM.
