Old 04-11-2002, 01:03 PM   #1
Stealthbmbr
Member#: 13823
2009 Legacy 2.5i SE
C A P S CAPS CAPS CAPS
Default My homemade (stealth box) intake
Weapon R short ram, red anodized.
Stealthbmbr is offline   Reply With Quote
Old 04-11-2002, 01:04 PM   #2
Stealthbmbr
Member#: 13823
2009 Legacy 2.5i SE
I don't know how to attach a double image so here is another.
Old 04-11-2002, 01:06 PM   #3
Stealthbmbr
Member#: 13823
2009 Legacy 2.5i SE
more pics.
Old 04-11-2002, 01:19 PM   #4
Stealthbmbr
Member#: 13823
2009 Legacy 2.5i SE
Aur inlet is behind fog light.
Old 04-11-2002, 01:20 PM   #5
99OBSter
Member#: 14324
1999 OBS 4eat
I must say, nice work!
99OBSter is offline   Reply With Quote
Old 04-11-2002, 01:31 PM   #6
Stealthbmbr
Member#: 13823
2009 Legacy 2.5i SE
Oopps!
Old 04-11-2002, 02:16 PM   #7
Stealthbmbr
Member#: 13823
2009 Legacy 2.5i SE
one more and I'm done.
Old 04-11-2002, 08:52 PM   #8
Poppa smurf
Member#: 8257
2004 STI
Silver\Silver
So did you notice a differance? Nice job by the way.
Poppa smurf is offline   Reply With Quote
Old 04-11-2002, 11:17 PM   #9
goobie
Member#: 8273
2006 WRX Wagon
Default Air filters?
Are you now running two air filters? or have you removed the flat panel filter in the stock box?
Chad
goobie is offline   Reply With Quote
Old 04-12-2002, 01:23 AM   #10
ashtaron14
Member#: 4674
2004 Toyota Vitz
Black Black Black!
Maybe he is running 2 filters cuz he's very sensitive to air pollution... bwahahahahahaha
Sunny
ashtaron14 is offline   Reply With Quote
Old 04-12-2002, 08:07 AM   #11
Stealthbmbr
Member#: 13823
2009 Legacy 2.5i SE
Big difference over factory setup. Not too loud but you can hear it when your wide open. The main thing I wanted was that the lexan blocks the all hot air from the radiator. No air from under the hood gets in the motor, it just pulls air out of the fender.
I had the factory fog covers on and removed them to install the fogs, man, what a difference that made. The small opening next to the fog is NOT big enough to allow the air needed to the motor. She felt like it was running out of air on the top end, which she was. Now, with the fogs in and the opening behind the right fog bigger, she pulls strong to redline. I also used longer bolts and spacers behind the fog light, to move it foward in the bumper to allow more air to flow around it. You can't even notice.
Goobie- I removed the stock panel filter and ran self sticking, window weatherstrip (3/8x3/8) from homedepot around the opening. So the box would seal up. No leaks so far.
I also tried it with the box removed and a piece of 3" hard rubber hose(borrowed from a merc sable) run from the intake to the thottle body. But it would fall off above 5400 rpm and start to sputter and cough. It only ran a [email protected] at Capitol raceway. With the fog cover removed and the box re-installed it ran a [email protected] at Cecil county dragway. I want to go to capitol raceway tonight and see what it will run with the fog light moved foward and the hole behind it opened up larger.
Old 04-12-2002, 12:25 PM   #12
IggDawg
Celebrity Guest Star
Member#: 10648
1998 Acura CL... D:
Mostly kind of red
I think you should send me a copy of your intake since you have my car and all
I like the system, and I can't wait to see what kind of times you get. Keep us posted.
-IggDawg
IggDawg is offline   Reply With Quote
Old 04-12-2002, 12:57 PM   #13
Stealthbmbr
Member#: 13823
2009 Legacy 2.5i SE
I can send you an exact copy of the lexan, then all you need is a filter for the mighty igg bore.
Think I could sell the lexans copies? How much do you think people would pay? They would work great for the rallispec intakes. It would keep the MAF sensor from shaking itself apart. I had a problem with my intake vibrating but solved it, so it might work for the MAF sensor guys too.
Old 04-12-2002, 01:17 PM   #14
IggDawg
Member#: 10648
1998 Acura CL... D:
Mostly kind of red
I should at least wait till I get a real intake. The Igg Bore goes to the front portal too. Thanks for the offer tho. when I do get a real intake, I'll send a ninja to pick this up .
-IggDawg
Old 04-13-2002, 03:14 AM   #15
ImprezaRS dot com
over boosted again
Member#: 1458
2015 Forester 2.0 XT
2005 2.5 RS, 2013 Tribeca
Wouldn't it be easier to just buy a GanzFlow intake
Larry Ganz
www.SubaruPlanet.com
ImprezaRS dot com is offline   Reply With Quote
Old 04-13-2002, 07:56 PM   #16
Josico
Member#: 8219
2002 Impreza RS
Blue Ridge Pearl
Larry Ganz
But then we won't have the fun and fulfilling rewards of making something to call our own!
Josico is offline   Reply With Quote
Old 04-15-2002, 09:20 AM   #17
Stealthbmbr
Member#: 13823
2009 Legacy 2.5i SE
Larry Ganz
No offense but I like mine better, plus it only cost me $50 for the intake. And the lexan, well, that's just what I do for a living. You know, Banner Glass and all. I would like to do your stage 2 mod to the box though.
Old 04-16-2002, 04:20 AM   #18
ImprezaRS dot com
over boosted again
Member#: 1458
No offense taken...
Larry
Old 04-16-2002, 11:50 AM   #19
Stealthbmbr
Member#: 13823
2009 Legacy 2.5i SE
Went to Capitol raceway Friday night. It was about 20 degrees warmer than the last time I ran it and the humidity was 40% higher friday. But the car was only .08 slower than at Cecil county, it went a [email protected] I'm not setting the world on fire with that kind of et, but it is a good baseline to go off of. The only change I made was moving the fog light out and allowing more air to get in around it.
edit: I have since been a [email protected] since then in hotter/worse conditions.
Old 10-21-2003, 11:47 PM   #20
Ahzlon
Member#: 45216
2005 Baja Turbo
that is a VERY sweet set up... now just a question.. does anyone know if the engine compartment is closely identical to the 00 impreza??? cause those two look very close... but thats judging from a pic accual thing...
thanks peoples
Ahzlon is offline   Reply With Quote
Old 10-22-2003, 01:59 PM   #21
Stealthbmbr
Member#: 13823
2009 Legacy 2.5i SE
They are similar but not the same. I put an AEM intake from a 00 rs on my 02 TS and it fit just fine. But the sheild for the 00 is alot smaller.
Homemade cold air intake for the leggy? Mac562 Normally Aspirated Powertrain 6 03-07-2010 08:28 PM
My homemade CF dash thingy (pic) scoobydrew06 Member's Car Gallery 22 06-02-2004 08:20 PM
FS : Prodrive oval Tip Axelback, TXS Stealth, AEM intake HypertonicLobster Private 'For Sale' Classifieds 11 06-01-2004 07:23 PM
Pics of my homemade sailboat! Arr! DO Off-Topic 11 09-19-2003 04:39 PM
Homemade Velocity Stack Intake radrex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 06-10-2002 02:35 PM
