Welcome to the North American Subaru Impreza Owners Club Wednesday April 1, 2015
Old 03-10-2009, 10:58 PM   #1
vanillajuice
Member#: 139321
2004 WRX 2.5 Hybrid
Java Black Pearl
Default BC 272 cams....pronounced lope
so a local guy has the same cams as me BC 272/272....his idle sounds stock as where mine has a very pronounced lope, think this could just be due to the need to tune? or something else? of course hes on 2.5 litre heads and im on the 2 litre heads....any ideas?
vanillajuice is offline   Reply With Quote
Old 03-10-2009, 11:34 PM   #2
NXNLINE
Member#: 186893
2004 WRX
SILVER
Default Hey Pal
Got my 04 WRX back today with a new rebuilt motor! Yes it has the BC stage II cams, my car sounds stock and it has a tune installed from PDX, can't really hear the lope, but still runs great and has pleanty of power! My new motor has only 74 miles on it!!!!!!!!!!!!!!!!!!!!!!!!
NXNLINE is offline   Reply With Quote
Old 03-11-2009, 01:42 AM   #3
vanillajuice
Member#: 139321
2004 WRX 2.5 Hybrid
Java Black Pearl
hmm...ya what the heck is goin on with mine?
Old 03-11-2009, 01:56 AM   #4
06WHTWRX
Member#: 173690
2005 Ferd
F-TeenThousand
You said he has 2.5 heads, does he have AVCS? If he does that could have something to do with it.
06WHTWRX is offline   Reply With Quote
Old 03-11-2009, 11:19 AM   #5
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
the heads I don't think are making the difference...and shouldn't. the lope on your setup could very well be from cam timing being off. Who did the install?
Old 03-11-2009, 11:20 AM   #6
dunk
Member#: 15359
Could also be due to differences in engine speed at idle.
-Duncan
dunk is offline   Reply With Quote
Old 03-11-2009, 11:26 AM   #7
Homemade WRX
Member#: 33782
96 bastard child
-Duncan
very true...I would assume they'd have check that though...fuel and ignition can change the sound too.
Old 03-11-2009, 11:34 AM   #8
andya
Member#: 200134
I did... Things not mentioned..
1: Ultra light aluminum flywheel
2: 2.5l hybrid from a 2l
3: Base map guess
4: port work not optimum for low end (knife edge runners)
Rich idle mix... runs decent off idle.
andya is offline   Reply With Quote
Old 03-11-2009, 02:30 PM   #9
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
With AVCS heads (and active AVCS) you have less overlap at idle. That will affect lope to some extent wouldn't it? That's the reason I've been told STi always idle better with identical cams than non-AVCS cars do.
Old 03-11-2009, 02:43 PM   #10
andya
Member#: 200134
AVCS are 0 at idle
Old 03-11-2009, 02:51 PM   #11
kellygnsd
Member#: 32669
LINK G4 hybrid STi
Originally Posted by andya View Post
AVCS are 0 at idle
That's a relative number. Compared to non-AVCS cams the centerline of the intake cam will be different at idle
Old 03-11-2009, 03:09 PM   #12
andya
Member#: 200134
TRUE ^
Old 03-11-2009, 03:23 PM   #13
selvar05WRX
Member#: 165524
1997 S14 608rwhp
Super Black
its probably just where your idle is set... i have BC 280's in my car and at idle they sound more like 264's by my car idles at 1200rpm... if i bump it down to 700-800rpm is becomes VERY rough to the point where the car shakes pretty bad
selvar05WRX is offline   Reply With Quote
Old 03-11-2009, 05:37 PM   #14
vanillajuice
Member#: 139321
2004 WRX 2.5 Hybrid
Java Black Pearl
yea mine is set at 800rpm, and yes it shakes and sounds rough, idle is no longer rich tho, still does it, guess its just too low of an idle?
Old 03-13-2009, 12:48 AM   #15
socalLGT
Member#: 89752
08 STI
In my experience, cammed 2.0L cars tend to idle a little lumpier than cammed 2.5L Subarus. I tuned a couple hybrids in the past couple weeks, one with BC 280 cams and another with Kelford 272. Both needed a 1000-1050 rpm idle to have good albeit still lopey idles. In comparison all the 2.5L Subarus with Cosworth and Kelford cams that I have tuned all idle near stock with no notable lope even with idle set at 850-900 rpm.
socalLGT is offline   Reply With Quote
Old 03-13-2009, 01:03 AM   #16
andya
Member#: 200134
Thanks for the heads up socal... I wondered about that because the 2.5l has the intakes retarded which reduces valve overlap hence a smoother idle.
Old 03-13-2009, 09:50 AM   #17
Homemade WRX
Member#: 33782
96 bastard child
sorry, I wasn't even thinking about the actual AVCS function but just head differences...knife edging could effect it however.
the BC cams have the same lob whether its wrx or STi however I don't recall the difference in LSA/LCA
which brings the question; did you get ej20 cams or ej25 sti cams for the hydrid build? if the wrx, did you change the LSA so it would be corrected for the 2.5L bottom end?
Old 03-13-2009, 11:07 AM   #18
benw
Member#: 103320
2005 wingless
aspen white
I'm the local guy. I think it could be related to the tune since the OP's car is using a email base tune and I have been working on mine and constantly tweaking it from the get-go, and the car idles smoothly at 700-800 RPM. There is really not a pronounced lope. However, when you take the car above 4000RPM it begins to sound very mean and way different than a stock STI.
Just for grins, I upped the idle to 850, 950, and 1050 RPM and did not notice any positive benefits whatsoever, so I left it at stock. Car pulls 19 in/hg at hot idle like that.
benw is offline   Reply With Quote
Old 03-13-2009, 10:11 PM   #19
kellygnsd
Member#: 32669
LINK G4 hybrid STi
My Cosworth 275 cams(Kelford 199-E equivalent) have a centerline of 113 for intake and exhaust, the AVCS versions list centerline as variable on intake and 113 for the exhaust.
Remember AVCS was designed for emissions as well as performance and excessive overlap does not equal good emissions. Excessive overlap isn't good for fast low end turbo spool either but for some reason tuners can increase spool by fiddling with the AVCS maps and comparatively true STi long-blocks tend to spool turbos better than hybrid 2.5L motors.
If you run AVCS cam gears with non-AVCS cams you end up with an intake cam that's retarded ~5 degrees. I'm running 2.0L cams on my hybrid BTW.
Old 03-13-2009, 11:23 PM   #20
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Here's a video showing different idles with diffrent air-fuel ratios.
http://www.youtube.com/watch?v=CPNM5S9CxBA
Idle speed will determine how ROUGH it is. The lower the rougher, the leaner the rougher.
FuJi K is offline   Reply With Quote
Old 03-14-2009, 12:25 AM   #21
vanillajuice
Member#: 139321
2004 WRX 2.5 Hybrid
Java Black Pearl
ya i have the 2 litre cams also....as i have 2 litre heads
Old 03-14-2009, 01:18 AM   #22
Defiant Autospeed
Vendor
Member#: 155450
2007 FXT
Thicker head gaskets? The thicker cometics that so many people use throw cam timing off just ever so slightly (by moving the heads out away from each other just a touch, not nearly enough to equal a full tooth, just enough to make a big lope on a mild cam. My 2.0/2.5 hybrid WRX sounded like a V8 with a HUGE cam.
Defiant Autospeed is offline   Reply With Quote
Old 03-14-2009, 10:13 AM   #23
v8upsetr
Member#: 179447
07 OBP Sti
MSPT Tuned Camed fp RED
My bc 272 sound almost stock on my 07 sti idle set at 900 rpms
v8upsetr is offline   Reply With Quote
Old 03-14-2009, 11:00 PM   #24
vanillajuice
Member#: 139321
2004 WRX 2.5 Hybrid
Java Black Pearl
im on sti head gaskets
Old 03-15-2009, 12:41 AM   #25
EJ20_lee
Member#: 106799
2004 built 257 tomei
powered ^.^
any misfires with those cams?
EJ20_lee is offline   Reply With Quote
FS: BC 272 cams Brand new! for 2.0 heads ryan_west06 Engine/Power/Exhaust 15 10-14-2009 04:25 PM
NEED: BC 272 cams for 04 wrx evo 3ater Engine/Power/Exhaust 1 09-03-2009 05:35 PM
maximum AVCS with BC 272 cams for EJ257? benw Built Motor Discussion 10 12-20-2008 12:31 PM
BC 272 cams ryanviola Engine/Power/Exhaust 36 11-24-2008 08:09 PM
ej20 wrx bc 272 cams. ej20 wrx heads NITROS Engine/Power/Exhaust 24 08-01-2008 03:40 AM
