Old 04-11-2002, 02:39 PM   #1
adamsrs
Member#: 3768
Default FUEL PRESSURE...I need an answer! Thanks!
Ok, i just got a SARD Type R Adjustable Fuel Pressure Regulator. I am running stock injectors and stock fuel rails, but i have modded the rails to run in parrellel rather than series. ( I doubt that makes a difference) I am running 5 psi on a Legacy Turbo setup. What should my IDLE fuel pressure be, and what should my On boost Fuel Pressure be? I have two gauges, one reads PSI, and one reads a weird metric reading. I just want a breif summary of what pressure i should be looking for!
adamsrs
adamsrs is offline   Reply With Quote
Old 04-11-2002, 02:44 PM   #2
KillerTHC
Member#: 4942
01 SRP 2.5 RS-T
Ludespeed Stage 3 Link'd
i think it's 37 psi at idle but i dunno about running/on boost.
KillerTHC is offline   Reply With Quote
Old 04-11-2002, 02:51 PM   #3
adamsrs
Member#: 3768
Thanks for the quick response. Any one know about the on boost?
adamsrs
Old 04-11-2002, 02:54 PM   #4
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Idle should be around 34-35psi... on boost, well... you better ask someone else, fuel pressure and I don't get along too well.
Old 04-11-2002, 02:57 PM   #5
adamsrs
Member#: 3768
Wow do i adjust on boost pressure to be different from idle pressure? Or do they both rise in relative incremnts? 8 Complex, please add me to your ICQ list so that I can talk to you in real time!
adamsrs
Old 04-11-2002, 03:03 PM   #6
KillerTHC
Member#: 4942
01 SRP 2.5 RS-T
err i meant 34. stupid 7 above the 4
Old 04-11-2002, 09:28 PM   #7
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
The SARD unit is just a 1:1 unit, is it not? In any case, you will probably want to bump your fuel pressure up by atleast 6:1 on CA gas. Blaster88 got away with 4:1 but they also have an extra 2 points of octane. The math works out at this with 5psi of boost: 5psi x 6 = 30 psi. So you need 34psi + 30 psi (give or take).
-Jon
www.nothingserious.net
Old 04-11-2002, 09:30 PM   #8
Andrew
Member#: 1170
2005 STi
what stimpy said. it is very bad to be running any form of boost with stock injectors and no RRFPR. 1:1 is just NOT enough.
Andrew is offline   Reply With Quote
Old 04-12-2002, 09:01 PM   #9
adamsrs
Member#: 3768
Are you sure that the SARD peice is not an RRFPR? I thought it was! SO if it;s not then VIVID is a bunch liars!
adamsrs
Old 04-13-2002, 04:55 AM   #10
Avenger
Member#: 1234
There are two types from SARD, a regular one and a Type R one, The type R one is a RRFPR and the regular one is just a 1:1.
This link have the picture of both the regular and the type r model and a little write up.
http://www.takakaira.com/php/template.php3?id=704&cat=2
Avenger is offline   Reply With Quote
Old 04-13-2002, 11:25 AM   #11
adamsrs
Member#: 3768
Supposedly mine is the type R.
adamsrs
I need an answer to this question.... WRX_02_227 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 11-28-2001 04:24 AM
Help, stock bushing won't come out. I need an answer now, please Aspen_2.5RS Transmission (AT/MT) & Driveline 4 09-16-2001 10:20 PM
Need an answer Jay_UK Normally Aspirated Powertrain 7 04-16-2001 06:10 AM
ground control guys... need an answer ASAP burr101 Technical Forum Archive 10 10-06-2000 12:09 AM
Amsoil filter installed - dumb question needs an answer please Joe Lee Technical Forum Archive 3 06-29-2000 06:17 PM
