Old 04-07-2002, 04:34 AM   #1
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Arrow Need DIY Cone-Air intake "prop-up-device" tips for MAF EJ18 (or any MAF car)
Just got a Cone air filter for my car today from rich AKA MPREZYA Poped it right on my stock tubing replacing the airbox... It rattles around a little and I know folks have done some DIY's (Racecarriot I know did one) to help hold up the filter...
I was wondering if anyone had some nice detailed instructions on this? And yes, of course, I searched through what I could remember to search through about it, and didnt come up with squat
I think since im using the stock piping from the MAF back, that my filter is sitting a bit closer to the fender well than others (its almost touching the hole where the MAF stock airbox gets air from) so some of the Weapon-R and other brand intake custom jobs might not fit...
Old 04-07-2002, 12:58 PM   #2
Hawk296
Member#: 14555
1995 Impreza L
Baja
Default me too
I have the same problem with mine. the whole thing rattles around. Since im at school i dont have much tmie for the car anymore so what I did was zip tie it to hold it against the wheel well and reduce rattling for now until i have some time to make up a nice mount.
Hawk296 is offline   Reply With Quote
Old 04-07-2002, 06:07 PM   #3
Hawk296
Member#: 14555
1995 Impreza L
Baja
Default pic
this is mine for now
Old 04-07-2002, 11:39 PM   #4
hobun2
Member#: 16831
2000 Legacy L
Dark blue
Kostamojen - If you stil have your stock air-box, maybe cutting the section which holds it into place an fitting somekind of brace/whatever with rubber or a softer material would hold it into place and reduce/prevent the noise. You might find what you need at a home-harware store.
hobun2 is offline   Reply With Quote
Old 04-08-2002, 12:03 AM   #5
Hawk296
Member#: 14555
1995 Impreza L
Baja
that wouldnt work for me, the MAF sensor bolts up to the box and is flush in the inside leaving no room for a filter to clamp on. I was going to make something that either used the bolt holes ofr the stock airbox or thee also seems to be a hole on the fender behind the hole where airbox got its air from. I was thinking about coming out from that and down or just using the stock holes. Havnt had time to play yet.
Old 04-08-2002, 02:11 AM   #6
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Mines exactly like Hawks. I went in there and tied it down with a zip tie in two locations, and put some foam and doublesided sticky tape in the two spots where the filter were touching stuff so it wouldnt scrape anything... I'd rather have a mount to the bolts from where the bolts that came from the airbox bolt locations were or something like that, and I need the stock airbox in case I need to return it to stock ever.
Old 04-08-2002, 12:23 PM   #7
RaceCarRiot
Member#: 6542
1997 Ver IV
i was gonna say you can check the pics of mine.
i made it for like $3 with parts from a government surplus store. it's basically a piece of angle iron, a flat bar of aluminum that had holes drilled in it, and another piece of aluminum in an L shape that i could bolt the bar to, and vary the height/position since there's a gap that runs through the middle...i bolted it down to the stock holes where the airbox attatches, then ran a zip tie through one of the holes on the bar and around the intake to hold it down. there are also small patches of duct tape where the bracket could rub the fender, so it doesn't scrape through the paint. so yes, it's a real hot rod, now that it has duct tape and zip ties on it.
-adam-
RaceCarRiot is offline   Reply With Quote
Old 04-09-2002, 01:29 AM   #8
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
If I didnt have the huge ABS thingy I could have it just sitting in some foam or something with a zip tie holding it down That thing you have racecar wont fit mine, cause my intake is a little farther away, and that looks aweful complicated too...
Old 04-09-2002, 09:49 AM   #9
Costas
Member#: 13760
1999 Impreza WRX
Rally Blue
I bolted it to the engine, so the intake moves WITH the engine ,
Costas is offline   Reply With Quote
Old 04-09-2002, 11:57 AM   #10
Hawk296
Member#: 14555
1995 Impreza L
Baja
Where on the engine did you bolt it to? Thats the whole problem with mine right now, mine moves WITH the engine too, and in the process of doing so it smacks into everythign else. although after i tied it down it reduced that a lot. Did you make a long bracket? My piping is so long i dont know how I could attach it in such a way. Since the MAF is pretty much in line with the stock airbox mounting points I would think it is easiest to just use those. I am curious though. Ide like to know in detail where you mounted it. Do you have any pictures?
Old 04-09-2002, 12:30 PM   #11
RageHardIntoTheBendies
Member#: 1532
1999 RS, Silverthorn
www.zucru.com
I reused the rubber mounts that were on the stock airbox so there is a little play there.
RageHardIntoTheBendies is offline   Reply With Quote
Old 04-09-2002, 01:12 PM   #12
Hawk296
Member#: 14555
1995 Impreza L
Baja
Neat
Old 04-09-2002, 01:14 PM   #13
Costas
Member#: 13760
1999 Impreza WRX
Rally Blue
I plan on taking a few pics real soon... Initially it was touching the ABS too, so I pushed the pipe back a bit and played with the angles, ...I have an OLD pic (before I put the bolt on..
I bolted it to the manifold...you can see where I photoshop'ed a redl line...close to the air filter.
Old Pic
you may have to shorten the pipe a bit... but I feel much more comfortable with the set up and revving the engine does nothing to make the intake knock into anything..
Theres a thread about it here too
Click Here
Old 04-09-2002, 04:26 PM   #14
Hawk296
Member#: 14555
1995 Impreza L
Baja
Very helpful, thank you. (even though this wasnt my thread)
Old 04-09-2002, 08:20 PM   #15
Josico
Member#: 8219
2002 Impreza RS
Blue Ridge Pearl
just wondering... this is kinda off topic to what you guys are doing, but is there a loss of low end torque even with the stock box still there?
or w/ the MY95s, there is no more stock box near the throttle body? hmm
Josico is offline   Reply With Quote
Old 04-09-2002, 08:52 PM   #16
Member#: 1532
www.zucru.com
I have gained bottom end if anything, at low speeds in fifth there is alot more acceleration than before.
As soon as the temprature get within the right range I will see how my GTec results compare to last year.
Old 04-09-2002, 09:59 PM   #17
Hawk296
Member#: 14555
1995 Impreza L
Baja
I dont quite understand what you mean. The 95's didnt have a 2nd box in front of thethrottle body if thats what you meant, we just have the airbox in front of the MAF. the biggest difference i saw was the sound, lol.
Old 04-10-2002, 03:09 AM   #18
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
RHITB: Ooh, I like that, and I saw the stuff today at home debot to make that too Does it work as a heat shield as well?
Update: Ya, went to home depot today and bought some insulation foam for now... I looked at some of the metal work stuff to see if I could make anything and couldnt tell, so I just bought $3 of some sticky foam, and a 3 foot length peice of 1.5" x 1.5" foam that I used to make a "ring" that went around the end of the intake so now it doesnt touch anything and its kindof like that $15 foam intake insulator that K+N sells anyway exept just one smidgen of it Ill take a pic thursday and post it...
Old 04-10-2002, 04:13 AM   #19
Josico
Member#: 8219
2002 Impreza RS
Blue Ridge Pearl
yeah i guess that's the difference?... there is another airbox where the filter sits in for my MY02 RS... and people said that if we use an intake like the weapon R which uses a cone filter and no stock air box, it will lose low end torque.
what i was wondering is if i use some sort of tubing and then use the stock air box w/o filter and have a cone filter at the end, what kind of results should i expect... hmm
Old 04-10-2002, 09:38 AM   #20
Hawk296
Member#: 14555
1995 Impreza L
Baja
Yeah, ive heard the same thing, But with my car being old school and having a tiny engine, I just cant help you out on that one sorry.
Old 04-10-2002, 02:24 PM   #21
Josico
Member#: 8219
2002 Impreza RS
Blue Ridge Pearl
no problem... just asking to see if anyone knew the answer
Old 04-10-2002, 03:17 PM   #22
Member#: 1532
www.zucru.com
Kostamojen: the Heat sheald is Lexan painted with heat resistant paint It works great!
Oh and a good tip, if you want it to look pretty get some door edge moulding to finish of the edges.
Old 04-10-2002, 07:07 PM   #23
Josico
Member#: 8219
2002 Impreza RS
Blue Ridge Pearl
you mean you can buy HEAT RESISTANT paint?!?... i didn't know that ... hmmm so how good are those compared with other things suggested like header wrap?
edit: how good as in insulating the heat out... and separating the two sections?...
Old 04-11-2002, 02:18 PM   #24
Member#: 1532
www.zucru.com
If your painting an intake pipe or similar you can use Ceramic based to paint which will have similar effect to ceramic coating.
The paint I uaed is for Indutrial boilers etc it is supposed to stop reduce the transfer of radiated heat.
I have not measured my intake temp so I'm not sure of how good of a job it does.
Old 04-11-2002, 03:00 PM   #25
Josico
Member#: 8219
2002 Impreza RS
Blue Ridge Pearl
thanks... i'll look into it, it is probably the cheaper route...
Need a Stock air intake hose for a 03 or 02 cXc5120 Private 'Wanted' Classifieds 5 10-13-2007 09:10 AM
DIY Cold Air / Intake Air Temp ?'s popcrux Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 20 07-07-2005 11:18 PM
DIY Cold Air Intake from flexible exhaust tubing? bigpaulo Normally Aspirated Powertrain 11 06-18-2002 09:50 AM
('93-'01) DIY Cold Air intake - Pics on my site! Jessie James Impreza Forum 2 05-22-2001 11:44 PM
DIY cold air intake! really cool! Kevex Technical Forum Archive 28 06-30-2000 11:34 PM
