Alaskan Impreza Club
Old 03-11-2009, 03:52 PM   #1
Marlons101
Member#: 137569
WRX Twinscroll
Dez in yo mouth!
Default HELP wiring in Gauges.
Hey, is anybody free this weekend to help install some gauges? Im not the best wiring guru and I just need them wired in for now if anybody can help meeees out?
Marlons101 is offline   Reply With Quote
Old 03-11-2009, 03:54 PM   #2
QwikEVO
Member#: 44172
2006 Lancer Evo 9
Plasti-Dip is for TOOLS
What kinda gauges?
QwikEVO is offline   Reply With Quote
Old 03-11-2009, 03:57 PM   #3
Marlons101
Member#: 137569
WRX Twinscroll
Dez in yo mouth!
cheap ass prosports.
Old 03-11-2009, 04:00 PM   #4
QwikEVO
Member#: 44172
2006 Lancer Evo 9
Ok, you misunderstood me.
What kinda gauges? (volts, boost, engine temp)
Old 03-11-2009, 04:01 PM   #5
Marlons101
Member#: 137569
WRX Twinscroll
Dez in yo mouth!
boost egt and oil pressure.
I just need them wired in so i can connect my boost gauge. Ill do all the other ish later on
Old 03-11-2009, 04:05 PM   #6
QwikEVO
Member#: 44172
2006 Lancer Evo 9
Are there any "how to's" on this forum?
Boost shouldn't be that hard. Just find a good source for boost pressure somewhere. You can check out a "how to" for installing a boost controller to find those places on the WRX's.
Oil pressure shouldn't be that hard, you'd just have to tap into the wire for your ECU that has the signal.
EGT? hmm....I'm not too sure on that one. Never had to install one. I just put in a wideband and use that.
Old 03-11-2009, 04:07 PM   #7
Marlons101
Member#: 137569
WRX Twinscroll
Dez in yo mouth!
I know how to do all this stuff. But its more wires than normal and I actually have the how to. but Im not a schemtic or electrician so im not to fond on doing it myself. a simple mechanical gauge and you wouldve never seen this thread.
Old 03-11-2009, 04:21 PM   #8
AK SloPok
Member#: 56464
12 Ram
Easiest thing to do is tap into the stereo harness, you have ground, power, igintion and illumination. As I recall the prosports will daisy chain too.
AK SloPok is offline   Reply With Quote
Old 03-11-2009, 05:31 PM   #9
QwikEVO
Member#: 44172
2006 Lancer Evo 9
Right, but then your backlighting will be on all the time that your ignition is on. Would you really want that?
I would only tap the backlighting to the harness with the headlight power, so when I turn on my headlights, the backlighting turns on.
Old 03-11-2009, 05:35 PM   #10
Kiwi Fella
Modest Mouse
Member#: 27323
2000 RSTi
Yeah its nice when you do it that way.
Kiwi Fella is offline   Reply With Quote
Old 03-11-2009, 05:38 PM   #11
QwikEVO
Member#: 44172
2006 Lancer Evo 9
You'd be surprised how many corners people cut when they install electrical stuff.
Man, I've seen some doozies while installing car stereos...holy crap.
Old 03-11-2009, 05:44 PM   #12
Imprezed04
Member#: 202396
2004 STi
Send a PM to Seascooby. He helped wire in my boost gauge, and has done his own as well. Looks very good where it is and functions exceptionally well.
Imprezed04 is offline   Reply With Quote
Old 03-11-2009, 05:45 PM   #13
Marlons101
Member#: 137569
WRX Twinscroll
Dez in yo mouth!
trust me alex is hard to get ahold of. been tried that.
Old 03-11-2009, 06:25 PM   #14
t4nk
Member#: 129905
2005 WRB WRX
2003 F-350SD, 7.3PSD
prosports require constant power.. they really arent all that hard to hook up.
1 constant power
1 switched power (i used the fuse for my headlights..) to switch colors if you even want that feature.
1 ground
And then the signal wire coming from the solenoid
t4nk is offline   Reply With Quote
Old 03-11-2009, 06:27 PM   #15
t4nk
Member#: 129905
2005 WRB WRX
oh and i think the solenoid has a ground and constant as well
Old 03-11-2009, 10:14 PM   #16
907bob
Member#: 117127
2005 sti
Obama Can't Gymkhana
i had to tap into the ignition for the acc power haha i had all kinds of problems hooking my electric prosport boost gauge up. tried to find some how to guides and had trouble finding a decent one.
i wish i saw this one before i hooked my boost gauge up i would have ran the vacuum hose like this
http://www.rexnet.com.au/forum/index...howtopic=79436
http://forums.nasioc.com/forums/show....php?t=1036365
found a couple wiring diagrams that were nice here
http://www.northursalia.com/modifica...ng/wiring.html
hope that does you some good, mine ended up kinda shoddy because i was in a hurry and didnt have all the correct stuff so i gotta re do it this summer.
907bob is offline   Reply With Quote
Old 03-12-2009, 12:58 AM   #17
Imprezed04
Member#: 202396
2004 STi
Impreza WRX STi
not if u got his number
Old 03-12-2009, 01:44 AM   #18
02redwagone
Member#: 87067
02 Old but tasty
SRP
Mine is taped to the parking lights (stock boost gauge harness behind radio) No DRLs of course and superbrightleds.com for markers. Bling Bling and boost guage all day erry day.
But that's right hand drive? Wouldn't it be a long haul just to tap that location for USDM configure cabin? Just stealthily tap the stock purge valve standard location it will be less noticeable than there. Due simply to it being under the TMIC or A/C lines 90% right through the big grommet in the bulkhead to gauges.
kenney
02redwagone is offline   Reply With Quote
Old 03-12-2009, 03:37 AM   #19
Marlons101
Member#: 137569
WRX Twinscroll
Dez in yo mouth!
you must be silly if you dont think i have his number mister.
Old 03-12-2009, 02:38 PM   #20
Marlons101
Member#: 137569
WRX Twinscroll
Dez in yo mouth!
friday after work anybody?
Old 03-12-2009, 02:40 PM   #21
FstWrx907
Member#: 202303
03 Impreza WRX
hahah why dont you get gabe to help you....O wait he wants your exahust and your not giving it to him...
FstWrx907 is offline   Reply With Quote
Old 03-12-2009, 03:05 PM   #22
Alaskan EJ20
Member#: 160040
2002 Bugi / 1993 L
Symmetry Tuning
hahahahahahah^^^^ maybe, i told you i would do it, and qikevo there's a little more to these gauges then tapping into the stock sensors output wires, each gauge has an individual sensor and in this system it looks like the boost sensor needs to be powered, the EGT gets tappped in the headers and plugs in and the Oil P. sensor is missing, but he just wants them lit, these gauges 4 wires to light them red, black, orange, and white which are most likely switched p., ground, illumi, and dimmer, but im not sure so if someone would verify that would be great, thanks
Alaskan EJ20 is offline   Reply With Quote
Old 03-13-2009, 06:31 PM   #23
Marlons101
Member#: 137569
WRX Twinscroll
Dez in yo mouth!
OK! Got my gauges wired up last night... from a write up on nasioc that wired it into the clock pod....well they lite up, but when i started the car they burnt the fuse out? or did i fry my wires? I tried to replace the fuse and just plug the clock in...nothing. No clock. No stero. help me?
Old 03-13-2009, 06:49 PM   #24
d-dub
Member#: 177961
05 wrx
I wired mine into the clock and they have been fine since december. Wonder why you would have blew a fuse...
d-dub is offline   Reply With Quote
Old 03-13-2009, 07:16 PM   #25
Alaskan EJ20
Member#: 160040
2002 Bugi / 1993 L
Symmetry Tuning
come over after work ill fix it, check the radio fuse
help wiring up gauges where the clock use to be civichunter2 Electrical & Lighting 13 10-02-2006 05:32 PM
Gauge wiring --in process--HELP klie5111 Electrical & Lighting 4 06-11-2005 06:13 PM
Wiring help for boost gauge MaximusRex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 04-10-2002 01:08 PM
Need Help with EGT Gauge Wiring CommandoRabbit Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 07-19-2001 08:45 PM
