Old 04-11-2002, 04:42 PM   #1
Blindeye_03
Member#: 4418
2016 Focus ST
Unhappy Decelerating noise
Whenever I am slowing down for a stop light (car is in neutral and I am on the brakes, *lightly or hard*) my car feels like something is grinding.
It doesnt really make any sounds except like a road noise sound...And in the brake pedal it feels like there is a slight vibration as well (at the same time).
my suspension mods:
version 5 struts, eibach springs and 20mm sway bar, as well as 205/55/16 falken azenis tires
Thanks!
-justin
Blindeye_03 is offline   Reply With Quote
Old 04-11-2002, 04:58 PM   #2
FUBAR
Member#: 2132
11 STi Sdn
Sparkling Slvr Met
Nevermind I saw what MY you have after I hit submit, sorry
FUBAR is offline   Reply With Quote
Old 04-11-2002, 04:59 PM   #3
romanom
Member#: 16215
2002 WR WRX wagon
Default Re: Decelerating noise
my suspension mods:
Thanks!
-justin
Possibles (assuming it's the brakes):
Dust build up on rotors and pads. Have them cleaned
DTV, disk thickness variation. Have rotor turned
Or maybe both.
You can try cleaning yourself, you can buy "Brake Cleaner" at any auto store.
The turning part needs to be done by a pro.
Any NVH through the steering wheel?
romanom is offline   Reply With Quote
Old 04-11-2002, 05:03 PM   #4
Blindeye_03
Member#: 4418
2016 Focus ST
I feel nothing in my steering wheel when I brake.
The car has 27.5k miles on it and about 35 autocrosses under its belt, and still has the stock brakes (I have had the car for a little over a year).
-justin
Old 04-11-2002, 05:09 PM   #5
romanom
Member#: 16215
2002 WR WRX wagon
-justin
Ok, well what you described is basically the arch-typical symptons of DTV (which can be caused by just dust built up).
But, with you mileage and auto-x background I would just check the pad thickness.
Are any of the rotor badly grooved?
Old 04-11-2002, 05:14 PM   #6
Blindeye_03
Member#: 4418
2016 Focus ST
The pads are a little over halfway worn and the rotors have no grooves, last time I checked.
So I should just go to a brake place and have the rotors turned? Or should I wait till my 30k mile service??
thanks!
-justin
Old 04-11-2002, 05:21 PM   #7
romanom
Member#: 16215
2002 WR WRX wagon
thanks!
-justin
I think your OK for now, but if you start feeling it through the steering wheel or it gets worse. Then have it checked out.
But, like I said. Go buy some Brake Cleaner and give the rotors a shot. It's just an aresol can. Or get a high pressure air hose and blast the rotors. You can also go find a safe place and get a few hard stops from moderate speeds, like 35MPH.
AGAIN ASSUMING IT IS THE BRAKES . But I'd bet on the brakes.
It may, I repeat may, be something setting off the ABS. Like bad tires But I doubt it.
Old 04-11-2002, 05:24 PM   #8
Blindeye_03
Member#: 4418
2016 Focus ST
How would the tires be bad?, Like flat spotted you mean?
They are about 4 months old...
I just know when I get the money (soon) I will be replacing pads, ss lines and getting better dot4 fluid (right now I have NAPA brand CRAP dot4).
THANKS!!
-justin
Old 04-11-2002, 05:28 PM   #9
romanom
Member#: 16215
2002 WR WRX wagon
THANKS!!
-justin
Just that one tire (for whatever reason) is locking up a bit. But like I said I doubt this is an issue.
Please go read this thread (in-full) it will give you a great background on brakes:
http://www.i-club.com/forums/showthr...hreadid=159647
WRX deceleration noise update TheWRX Warranty Issues & SOA Problems 429 05-12-2016 11:25 PM
Deceleration Noise Issues: Clutch Only. WRX Pilot Warranty Issues & SOA Problems 147 12-20-2002 08:41 PM
Deceleration Noise Issues: Clutch Only Dat Southern California Impreza Club Forum -- SCIC 13 04-19-2002 04:44 AM
Deceleration noise similar to WRX liberty Warranty Issues & SOA Problems 1 02-13-2002 09:44 PM
Deceleration Noise Poll (popular demand) FargoRS Warranty Issues & SOA Problems 0 12-06-2001 11:43 AM
