Old 03-11-2009, 09:41 PM   #1
vanillajuice
Member#: 139321
2004 WRX 2.5 Hybrid
Java Black Pearl
Default compression ratio
so after asking around, everyone seems to have a different answer, does anyone actually know what the compression ratio for a 2.5 litre block with wiseco forged pistons(stock bore) and the 2 litre heads and sti head gaskets?
vanillajuice is offline   Reply With Quote
Old 03-11-2009, 09:46 PM   #2
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
You will be near 9.0:1
However.... what are those rated at??? I need that info to know... It will be higher always
FuJi K is offline   Reply With Quote
Old 03-11-2009, 09:48 PM   #3
vanillajuice
Member#: 139321
2004 WRX 2.5 Hybrid
Java Black Pearl
what are what rated at?
Old 03-12-2009, 03:06 PM   #4
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
those pistons, what's their advertised compression ratio??? advertised for STi EJ257?
Old 03-12-2009, 03:42 PM   #5
AWDWRXLOVER
Member#: 50267
02 built hybrid
sr55/meth/sick speed
here is what Maxwell Power told me based on 8.2 cp s
8.95:1 with factory HG
8.57:1 with 0.040"
8.38:1 with 0.051"
if you get ots weiscos they are 8.9 so it would be higher than that.
AWDWRXLOVER is offline   Reply With Quote
Old 03-12-2009, 03:48 PM   #6
andya
Member#: 200134
I think he just soiled himself... What pistons did you get again? I did not pay attention..
andya is offline   Reply With Quote
Old 03-12-2009, 07:22 PM   #7
vanillajuice
Member#: 139321
2004 WRX 2.5 Hybrid
Java Black Pearl
wiseco 99.5 bore
Old 03-12-2009, 08:17 PM   #8
WrXtaCy2003
Member#: 85036
2013 PBP sti ltd
05 LGT 35r 30psi..busted
its about 9.1-9.2. Advertised by wiseco for an sti is 8.9. But with a stock sti headgasket with wrx heads, it is going to be between 9.1 and 9.2. And your gonna love it. I have this setup and LOVE it. I got off the cometic gasket about 5 months ago, and I'll never go back.
DK
I have the 100mm bore so my CR is even a little higher
WrXtaCy2003 is offline   Reply With Quote
Old 03-12-2009, 08:20 PM   #9
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
depends on how much you've decked the block and heads
seriously...its nothing but math depending on the previous two questions, beyond what you've supplied.
Old 03-12-2009, 08:51 PM   #10
vanillajuice
Member#: 139321
2004 WRX 2.5 Hybrid
Java Black Pearl
decked the block and heads? the hell does that mean? lol
Old 03-12-2009, 09:10 PM   #11
andya
Member#: 200134
The block was new... the heads????? MYSTERY!
Old 03-12-2009, 09:15 PM   #12
vanillajuice
Member#: 139321
2004 WRX 2.5 Hybrid
Java Black Pearl
haha oh god those heads, lol....btw ^^this guy is da man!
Old 03-12-2009, 09:17 PM   #13
MrSlowbaru
Member#: 129231
2005 wrx
cgm
get the 98-99 legacy outback 2.5 NA twin cam motor headgasket. it is really thick and will help bring down the CR
MrSlowbaru is offline   Reply With Quote
Old 03-12-2009, 09:25 PM   #14
vanillajuice
Member#: 139321
2004 WRX 2.5 Hybrid
Java Black Pearl
oh i dont want the CR down...i want it UP! about 9:1 is around where i want it :-D
Old 03-12-2009, 11:34 PM   #15
Homemade WRX
Member#: 33782
96 bastard child
then just cc them...that's what you'll ultimately have to do with them anyhow to get a 'true' CR
Old 03-12-2009, 11:54 PM   #16
andya
Member#: 200134
It's an inside joke.. They were ported/butchered by original owner, re-worked by one machine shop, then worked again by our local machinist. They are as good as they can get without turning them into Top Fuel drag heads. The chambers were just cleaned up a little and minimal material removed.
I like giving Josh a hard time about them and he's a good sport. After all he now has a running hot rod!
Old 03-13-2009, 12:29 AM   #17
vanillajuice
Member#: 139321
2004 WRX 2.5 Hybrid
Java Black Pearl
^^haha yea...this thing picks up alot quicker than the 2 litre did. loving it so far!
Compression ratio? Naturally Aspirated Normally Aspirated Powertrain 31 11-30-2003 10:37 PM
('93-'01) what is the compression ratio on a... wop Impreza Forum 9 06-15-2001 05:34 AM
Boost and compression ratios 98mpreziveRS Normally Aspirated Powertrain 4 03-29-2001 06:58 PM
Compression Ratio for 98-01 RS Delhi Normally Aspirated Powertrain 4 03-14-2001 03:00 PM
Compression ratio question fellfrosch7 Normally Aspirated Powertrain 12 03-14-2001 12:43 AM
