Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Old 03-11-2009, 11:11 PM   #1
nuppy
Member#: 145656
2005 sti
black
Default start up issues! help
Well i spun a rod a bearing a while back and now i have just finished rebuilding the motor. Everything went together smooth and didnt have too many problems until now!
Heres the issue. The engine runs but has a steady miss and will not take r's over 2 thousand. When held at low idle it doesnt sound too bad but anything beyond that it sputters and backfires out the pipe.
Ran a compression test and all cylinders are good. When i had it hooked up to the laptop the timing was all over the place so tomorrow im going to take a timing light to it to make sure the readings are correct.
Current mods include:
bc stage 3 cams
bc valve springs and retainers
TS06 20g with 3in inlet and 8cm exhaust
PE 850cc injectors
AP Fuel rails
Large TMIC
Header with catless TBE
12mm oil pump
nuppy is offline   Reply With Quote
Old 03-12-2009, 02:38 PM   #2
nuppy
Member#: 145656
2005 sti
black
bump anyone?
Old 03-13-2009, 06:16 PM   #3
paintbing
Member#: 59388
2003 WRX - Hybrid
I do my own stunts
Any CEL's?
paintbing is offline   Reply With Quote
Old 03-13-2009, 08:25 PM   #4
Fongers
Member#: 118239
2002 Built Wagon
Wife- 2004 Outback SE
don't bother with the light, just take the timing cover off and check the marks by rotating. The light is more useful for distibutor cars, less for electronic on-coil timing like ours.
Fongers is offline   Reply With Quote
Old 03-13-2009, 10:38 PM   #5
andya
Member#: 200134
If the cam timing is correct, I would be looking for a big air leak between the mass air meter and the throttle body.
andya is offline   Reply With Quote
Help please, Warm start-up issues anotherhalfjap Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 07-28-2009 04:58 PM
HELP! '05 STi start-up issue..... bryansonger Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 09-13-2007 11:42 PM
Start up issues AdvanRGWRX37 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 01-15-2007 11:30 PM
Car Start-up Issues / AP coaster joe Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 12-15-2006 03:38 PM
Start up issues Bahumut Normally Aspirated Powertrain 5 05-18-2001 09:32 AM
